Question about Copystar CS-2030 Copier
WHAT DOES CODE C7990 MEAN ON A COPYSTAR CS-1820
  • 200 Answers
Waste toner reservoir overflow
problem (when the total number of
copies is 100 thousand sheets or
more)
• After E31 is displayed, 1,000 sheets
are copied. Or waste toner exceeds
5 g.
Defective waste
toner sensor or
engine PWB.
Shake the process unit from side to side
and turn the power switch off and then on.
If the problem cannot be solved, replace
the process unit.
After replacing the process unit, turn the
power switch off and then on. If the problem
cannot be solved, replace the waste
toner sensor or the engine PWB.
Posted on Apr 05, 2011
Error occured call service person C7990
What to do if the current display is "Machine Failure Call Service C7990" but few days ago it displays "Toner Waste Box is Full".?
May 23, 2012 | Kyocera Copystar CS-1820 Black and White...
My photocopier has been displaying this error code message C-7990 a photocopier kyocera KM-1500
C7990 is
Waste toner reservoir overflow problem (when the total number of copies is 100 thousand sheets or more)
• After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5 g.
Defective waste toner sensor or engine board (KP-5061).
Shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be solved, replace the process unit. After replacing the process unit, turn the power switch off and then on. If the problem
cannot be solved, replace the waste toner sensor or the engine board (KP-5061).
I hope this is helpful,
Shawn
Mar 05, 2011 | Kyocera Copystar CS-1820 Black and White...
How to put an IP address on the CopyStar CS-1820 printer
putting an ip to 1820, just go to system menu, scroll down look for the network setting, you will find ip address, then fill it up.
Apr 21, 2009 | Copystar CS-1820 Copier
Cs 1820, shows code co220
error code is for a communication problem between two of the internal printed circuit boards. I would just open machine toner door and close to see if it resets if not , you'll have to find a dealer for repair
Apr 04, 2009 | Copystar CS-1820 Copier
Kyocera cs 1820 or copystar = error message = 3200
3200 is a problem with the exposure lamp. If you are in a dirty enviroment, the problem could be dirty mirrors under the scanner glass.
Apr 02, 2009 | Kyocera Copystar CS-1820 Black and White...
KYOCERA copystar CS-1820 ERROR C6000
Your problem is heat related, or the lack of heating at least. one of 2 things went wrong here... either the fuser unit overheated causing the thermal fuse (aka the thermostat) to blow, or the heating lamp in the fuser unit is blown. Basically the 6000 code is displayed when your machine fails to reach the correct temparature at a specific time. Unfortunately you will have to call a service person to check which to of the mentioned components are at fault and to replace that component for you. After replacing, the component the code will still be displayed as a safety measure, so the service representative will need to clear the code via the machine's service mode
Sep 22, 2008 | Kyocera Copystar CS-1820 Black and White...
Copystar CS-2030 Copier Logo
264 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
