Question about iLO (2 GB) MP3 Player
USB Flash Drive
I have generic USB Flash Drive 8GB USB 2.0. After plug in, the files are saved on it. The files remain there as long as the flash Drive is connected to the computer. But once the flash drive is safely removed from the computer and plug in again to check the saved files, no thing is left there ( completely blank). The flash drive has been formatted for a number of times but still giving the same problem. Can you advise me to remove this problem? Thanks
email < [email protected]> Dated Aug. 4, 2008
  • 565 Answers
By chance was the flashdrive formatted in NTFS? If so, try FAT32.
Also, if you are right clicking a file and using "send to", don't do that. Try "copy" instead, then go to My Computer, right click your flashdrive and select "paste." Then safely remove and see if the files are there.
Posted on Jan 28, 2009
SOURCE:
Hello Kitty 8Gb flash drive isn't recognized on PC
physical damage is the most common reason a flash drive isn\'t detected. The connection between the USB connector and the circuit board can become disconnected after even normal use. A telltale sign is a loose or bent connector, but sometimes the damage is undetectable with the naked eye. if you want to do this your self..If you accept the risk and choose to repair your flash drive yourself, the first step is to apply light pressure to either side of the flash drive while it is inserted. Make sure the sound on your computer is on so you will hear the "ding" if the connection is momentarily reestablished. If you do get an indication, you can try to hold your flash drive in the position that causes it to show up. While you hold it in place, ask someone to access the drive and save your files to your computer. This requires a steady hand and if you have a lot of data on your flash drive, you might have to hold it in the same position for a long time.
Aug 09, 2014 | Hello Kitty 8GB USB Flash Drive
How do I download word documents to cruzer flash drive
From Word, use Save As.... and point the file to your USB drive. You can also open two instances of My Computer and drag & drop from the PC to the flash drive.
May 09, 2014 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Images turn sideways w/8gb flash drive
what happens if you right click on the photos select properties you will see an array of options select the advanced tab you should see 2 panes with options something like allow this file to have contents indexed in addition to the file and compress file to save space among other options
or it might be something related to Deel software you are using
Sep 19, 2012 | EMTEC Magnetics Group Electronics - Others
How can I transfer photo picture from usb to my computer?
1.Plug in your USB
2.The first time the device is connected to the computer the PC will load up the drivers. Be patient.
3.
The PC will recognize your USB SanDisk Cruzer Flash drive.
4.Click on My Computer/Computer icon on your desktop(or start - computer) and after that click on your flash drive icon.
5.There you can see all files on your flash drive and right click on your chosen picture and copy.
6.Right click (example desktop) and paste.
Good luck. I hope this will help you
Aug 01, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
8gb flash drive holds less than 2gb
Try reformatting the flash drive. Copy all your important files somewhere, since reformatting the device would erase all saved data. Go to "My Computer", right click on the usb device, click "Format...", click "Start" on the window that pops-up, click "ok" and wait for the formatting to finish. This should erase all data on the device, including hidden files that might be taking the space up.
Apr 28, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
L have forgotten how to use my USB to up music on it from ltunes.....when l plug it in to my computer it flashes for a few seconds and then nothing..not sure what l have to do ...l have tried finding it on...
Once you put the flash drive into the USB port, double click on the "my computer" icon. This will open up and show all available drives on your computer. The flash drive will have its' own drive letter. Once you log into i-tunes, when you go to save the file, make sure it goes to the flash drive. If your USB port is not recognizing the flash drive, try to do a system restore to a previous date. Try to go back at least 30 days (if you have created restore points on your system), then re-connect the flash drive and it should begin to install the proper drivers. If this is not your only USB port, try another one, if it is your only port, try plugging another USB device into it and see if it will recognize it.
Dec 28, 2010 | Verbatim ® Store `n` Go USB Flash Drive,...
I emptied the cruzer 8Gb by deleting the files.
Reformat the drive. Plug it into the Windows computer, and right click on it in the My Computer folder. Select properties, and you can reformat from there.
Oct 29, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I just purchased an 8GB USB 2.0 flash drive from SanDisk Cruzer. I plugged it in, it recognized it then opened to documents what do i do next?
You use it like a floppy disk, you can copy files to and from your computer to the flash drive,then take the flash drive out and the put into another computer to share, ie. to download and copy files to from other computers such as a friend's computer. The files can be anything, music, photos etc.
Sep 28, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have SanDisk Cruzer 8gb and once I got it plugged in the computer and got the applications I wanted, I couldn't save any of my school papers on it. Please teach me how to do this.
When you go to save your data in your application program it should let you save it to: go to my computer and look for the drive letter of your new flash drive and give your data a specific name and save it to that drive letter. You will be able to open it up by going back to my computer and double left clicking on the same drive letter and see your file their. Double left click on it and it should bring it back up for you. Hope this helps, let me know if it don't and we can go futher from thier. My E-Mail is [email protected]
Sep 15, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk Titanium 8GB flash drive with files will not open
Microsoft has a fix for USB and other external peripherals.
http://support.microsoft.com/kb/925196#fixit4me
Hope this solves your issue. Good luck and all the best!
Greg
May 17, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
