,Some months ago my computer stop lighting up, turning on and nothing is going on in system, i think it is the fuse that blow out,,,,,,,,,,,,,,,,,,,
    Guru:
  • 433 Answers
Think about power supply
battery
bios
Posted on Mar 30, 2011
Radio quit working
Sounds like someone shorted the wires...you need to look into the entire butcher job and see what wires were touched. Disconnect everything the butcher did and then see if your battery is still drainning power.
Dec 03, 2013 | 2006 Chevrolet Malibu
2003 altima dash fuse blows when i put in reverse and alternator stops working
It is electrical, could be initiated by mechanical (shift lever mechanics are pinching a wire in reverse) or a shorted wire or solenoid in the reverse light system or transmission solenoid circuit. Need a detailed wiring diagram to determine path of circuit for that fuse. That is where you need to start. Try your local library or dealer for a service manual. Look Online also.
Nov 02, 2013 | Cars & Trucks
Saturn 2002 L200 Air conditioner problem
The compressor clutch has a relay that energizes the A/C comperssor clutch an The PCM / ECM - engine computer energizes the relay . what you have posted here ( I did reset the battery thinking it was a computer error but still no fix) . Will do nothing ,you people think resetting the computer can fix anything ????? Take it to a qualified repair shop that knows how the system works . There are high an low pressure cut off switches ,maybe the clutch coil is bad . Could have DTC'S - diagnostic trouble codes . Hooking up A/C gauges is also a must , you do not want to add refrigerant if it doesn't need it . Checking Automotive Pressures updated How to Diagnose and Recharge Your AC System with Refrigerant Using an...
Mar 07, 2017 | 2002 Saturn L-Series
I have a Bosch Nexxt 500 andjust replaced the heating element less than 6 months ago. A week ago it stopped heating up again. Took the back panel off, pushed the reset button but now when I turn it on, the...
Sounds like a bad thermal fuse or thermostat, check all of them with a multi meter for continuity. as for the heater going out I would check ur venting inside and out the machine. the fuses and heater blow out for a reason? Usually due to overheating issues? I suspect ur lint build up is the problem?
Aug 16, 2012 | Bosch Nexxt 500 Dryer
I have a 2002 fire fighter road king. I noticed about a month ago that the horn would fade in and out when I depressed the horn button. Today I pressed it just to see if it was still acting up and it...
I do think they are all on the same circuit. You have a fuse box somewhere but I have no idea of where it is. If it blows another fuse, disconnect everything you can electrically and then reconnect them one thing at a time. When the fuse blows, the last thing you reconnected is the likely culprit.
Good Luck
Steve
Aug 09, 2011 | Harley Davidson FLHR-FLHRI Road king...
,Some months ago my computer stop lighting up, turning on and nothing is going on in the system, i think it is the fuse that blow,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
change the power supply if that doesnt fix it then your motherboard has blown, there are no fuses in the power supply, you have probably blown diodes inside it. You have tried another power lead, that you know is working?
Mar 30, 2011 | Computers & Internet
Starter/Fuel Pump fuse, or the Relay Fuse blow
the fuel pump comes on when you turn the key on the starter comes on when you turn all the way to start so i would think the short is in the fuel pump if it blows by just turning the key on
Jul 17, 2009 | 2002 Chrysler Sebring
2003 acura EL blows cold air
hi it might be your heater core that is messed up dose your heater work, if not that could be your problem
Mar 04, 2009 | 1995 Honda Accord
Logitech Z-680
You need a 2 Amp Slow Blow fuse. 250V. Available from eBay
Aug 01, 2007 | Logitech Z-680 Speakers and DVD218 System
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
