Question about Motorola Mobility H500 Wireless Headset
H500 PROBLEMS Hi You answered a question here a couple months ago but I still cannot get my H500 to connect to my Env2 phone. I can get it to find the device and pair to it but not connect. It states as someone else also indicated on this thread that it says device is out of range or not powered on. Sometimes it says device is busy. If you have any further advice, I would be most grateful. Thanks!
  • gemmeg4928 Aug 28, 2008
    I have the same problem with the LG envy2. My h500 worked with it for a few days and now I get the same error message. It says the device is not powered or out of range.
    Sergeant:
  • 359 Answers
This is a symptom of a bad headset. You need to replace the unit.
Posted on Aug 25, 2008
SOURCE:
I can receive a text from a certain number but about a month ago she could no longer receive my text message
Hi, some times text message are disturbed by network fluctuation. if the incidence happens continuously,will need to contact you customer care service for help.am sure they will be willing to help you.
Have a nice day.
Aug 06, 2010 | Verizon Communications enV2 Cellular Phone
When i call someone or someone calls me on my env2 they can't hear me and everything is really scratchy in the background...my old env2 broke and i just got this new one about a month ago..shouldnt be...
Try making test calls to someone and use a wired headset.
If they can hear you better - that you know it is the mouthpiece microphone that has gone bad.
If they cannot hear you better - something is wrong internally with the phone.
Usually insurance replaces your phone with a REFURBISHED unit. They check everything at least once before they send out the units, but problems that are intermittent - (just show up some of the time) don't always show up in testing. So yes sometimes you get a dud, and they have to replace it again. If you already paid a deductible, you won't have to pay one again. The refurbished one should be covered free for the next year!!
Nov 30, 2009 | Verizon Communications enV2 Cellular Phone
I can't connect my EnV2 to my Jabra Bluetooth. Is there a trick?
It could as easy as updating your phone by dailing *228 with a Verizon phone, select option 2 then press ok when the update is complete. When the phone resets, turn on the bluetooth headset, a prompt on the phone should come up to enter the passkey which should be 0000
Sep 01, 2009 | Motorola Mobility H500 Wireless Headset
My phone keeps shutting off every time i go to type a text message
If it's truly a loose battery, more than likely it's the connections that are making secure contact. You can try with a thin pinted implement to pry the connection tabs on the battery compartment (the connectors onthe battery itself are fixed and imovable) outward ever so slightly and that will make for a better connection. But use care so that you don't over bend and break the connections.
Also look for any corrosion onthe connections which can cause intermittent failures.
May 07, 2009 | Verizon Communications enV2 Cellular Phone
Problems pairing up a Nokia 6301 with my Motorola H500
Try power cycling the phone. Turn the Nokia off, wait 10 seconds, then turn back on and try again. It really does help sometimes. Let us know if this doesn't help.
Apr 01, 2009 | Motorola Mobility H500 Wireless Headset
Headset won't get recognized or connect...
when your in device seek blue tooth mode at its start up to seek is on
now on your bluetooth your using
make sure completly off first
then when device is in seek hold the bluetooth headset power down till your device finds the signal it will tell you in 30 to 40 that its found it
if requires pin it is 0000 or 1234 or 12345 this after everything found
thats it all you had to do
Jun 03, 2008 | Motorola Mobility H500 Wireless Headset
VX9900 Random Restarts and Blue Screen of Death
I was told by Verizon that this is caused by outdated software. If you have the software upgraded it should fix the problem.
Jan 10, 2008 | LG enV VX9900 Cellular Phone
Problems With Pairing H500 and Motorola V190
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H500once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 24, 2007 | Motorola Mobility H500 Wireless Headset
Tapping the answer button does not answer the phone
I had the same issue until I realized that I was touching the button twice,- first answering the incoming call, then immediately hanging up!
When you first tap the button there is a slight delay and the incoming call seems to be still ringing but you've really already "answered" it. Just tap once, be patient a couple of seconds and say"Hello". Your caller will be there!
Dec 12, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility H500 Wireless Headset Logo
70 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
