Question about Teledyne Laars Pool & Spa
I have 2 Laars Mighty Therm Lo Nox heaters on the roof at my laundry. They heat the water. Everything fine for about 6 years, now the flame roll out or fused link keeps breaking. The first time it lasted about 6 mo. Then 2 mo. then a week or 2 . Now they seem to last about half an hour. Couold the heaters be dirty (carbon build up)? Thanks for any help. model # PW0400Cn22NASN...Don
  • 3,740 Answers
Hi Don and welcome to FixYa, I am Kelly.
I first have to ask a question: Is there any sign of water being introduced into the firebox? Fused links open due to high current flow. High current flow is caused by several things:
1. Chassis grounds
2. Failed components
3. Corrosion on terminals
4. Hot terminals of wiring connections (even main power) on terminal blocks or components.
5. Clogged flue or litle air flow out the flue so the unit is getting very hot inside the chassis.
Since you have 2 units... I would be doing some serious resistance comparisons between the 2 units.
Take a look at Figure 16 on page 22 of this manual: (All 24 VAC related)
http://www.laars.com/LinkClick.aspx?fileticket=xpEyS3kHr3U%3d&tabid=1607&mid=4009
The fused link is the fuse for the fan switch, flow switch, Ignition BD, Gas valves and relay via the pump switch to K3. You need to compare the readings between the 2 units in this circuit. Somewhere you have a very LOW resistance that is cooking your fuse link. I think your going to find the problem is either with the ignition BD or the gas valves. If you suspect the ignition board as the probable cause move the boad between units. If the fuse link fails on the other you you know the board was bad. If the fuse link fails on the unit with the original symptom suspect a problem with the gas valves or relay K3.
Thanks for choosing FixYa,
Kelly
Posted on Mar 30, 2011
Heater only warms water to 98 degrees
temp sensor or if control box make sure heater set to 104
Nov 27, 2013 | Sta Rite Sr333na Max E Therm Pool & Spa...
My laars mighty therm keeps igniting on and over constanty, whats the problem
There is a problem with flame rectification. This could be caused by a dirty flame sensor, poor ground to burner, faulty ignition module, improper venting, inadequate combustion air, dirty burners, or clogged heat exchanger.
Jan 26, 2011 | Teledyne Laars HEAT EXCHANGER ASSEMBLY,...
Sta-Rite Propane heater ignites flame and within 2 seconds shuts down.
With the limited information provided above, I would say that it is your flame rectifier (flame sensor).
If the heater ignites, and the flame sensor is bad, it will go out right away as a safety precaution.
Below is the parts/troubleshooting manual for this heater. You can find the part number for your flame sensor, and replace it.
http://www.pentairpool.com/pdfs/MaxEThermOM.pdf
Jan 21, 2011 | Sta Rite Sr400na Max E Therm Pool & Spa...
I replaced the ignition transformer in my Teledyne Laars epc325 pool heater and cleaned everything. When I switch the heater on the burners all work fine but they only cycle on for about 10 seconds then...
This is probally your ignition wire is bad and not reading flame at the pilot or your pilot is bent or something so that when the pilot lights the flame isn't hitting the sensor probe at the pilot. When looking under the heater use a mirror so if you get roll out of the flame you don't get burned. Good luck and be careful.
Feb 26, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Sta-Rite Max-e-Therm pool heater -- cycling and HLS
make sure that you have adequate water flow going through the heater and that your water chemistry is balanced.
Jan 09, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
Pool & Spa Logo
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
