Question about Whirlpool AWM8143 Front Load Washer
Good Morning, I have a Whirlpool front load AWO 3561. I have never had any issues with it until yesterday. It is only running the prewash and then stops, flashes and displays 'FA' on the little screen. I took out the front filter and cleaned it but when I tried to run it again, the same thing happened. Can you please assist. I am freaking out. Thank you. Chloe
  • 6 Answers
SOURCE: F9/FA Whirlpool 6th sense frontloader washer
F09 is "overflow failure" - check drain pump, pressure switch, blocked drain.
FA is the emergency shutoff switch that detects when water is pooling underneath the machine.
Posted on Jul 16, 2008
SOURCE: Whirlpool Duet Sport? Front Load Washer WFW8300SW
hate my duet sport also! You cant presoak in this machine, very little water to wash with, very noisy, and everything stinks when it comes out of washer. Mine also smelled like mold but i figured out if you pull out the little tray that holds the detergent it is filled with stinky black mold. would never buy again
Posted on Oct 08, 2008
SOURCE: whirlpool awo 3761/5/s
have you checked that there is not a blockage in the outlet pipe or that it is not kinked?sometimes if the pipe is lying to low (ie creating a u-bend) this can prevent water getting in & out & so the machine interprets it as either taps off or the pump needs cleaned (this has happened to me numerous times :) )
Posted on Jan 12, 2009
danromarris
  • 101 Answers
SOURCE: clean pump light is flashing where is the pump so i can clean it
The pump is located in that bottom compartment under the door. There are two screws that you need to take out located in that tiny little opening and the panel will come right off. The pump is right there in front. Let me know if you have any other questions and let me know if this was helpful for you. Good luck and I am glad I could help.
Posted on Jan 22, 2009
jsrock516
  • 5911 Answers
SOURCE: whirlpool duet front load
In many cases these error codes can be erroneous. If you reset the Central Control Unit (the Main Control for the washer), in many cases, the problem will clear. You must unplug the washer for AT LEAST 30 minutes in order to do this, however. If an error code returns following a CCU reset, then you have a legitimate problem.
Posted on Feb 14, 2009
My whirlpool awo 3561/5 wont take in water?
either thetimer contacts are bad or the water inlet valve has failed
Mar 10, 2015 | Whirlpool Washing Machines
HOW TO REPLACE WHIRLPOOL WASHING MACHINE VALVE MAGNET for AWO/D8500
Do not attempt to just replace valve components this is not a proper repair, just replace the complete inlet valve
Nov 16, 2014 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool AWO 3561/5 makes a loud squealing noise when draining. What could be the problem?
Check your drain filter for any blockage. Make sure when you open the filter that you look up in there as far as possible. Also, I would remove the drain hose from the pump to look for any debris. After clearing the filter and pump, run the machine again. If you still hear the squealing you will need to replace the pump. Here is a link to the replacement pump.
Regards, Richard
Jul 30, 2011 | Washing Machines
I need to download user manual of front load washer Model Whirlpool AWO 9561
Dec 09, 2010 | Washing Machines
Whirlpool AWO 5140 Service-Red-Blinking lamp
hiya
it could be something thats been stuck in the pump filter, usually on whirlpools these are located at the front of the machine behind the plastic kick plate on the bottom. you may need a couple of towels or old rags as there will be some water comes out of the filter when you remove it.
hope this helps
Jul 30, 2008 | Whirlpool AWM5104/1 Front Load Washer
Whirlpool AWM8143 Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
