Question about Microwave Ovens
When I preheat the oven it takes an hour to reach 200 degrees. Is this normal? I am sure it was a lot quicker than this.
  • 3,287 Answers
An hour to go from room temperature to 200 degrees F (or even C for that matter) is unacceptable.
There is a problem with either a control, sensor or heating element. You should have this oven serviced to restore it to proper working order.
Posted on Mar 30, 2011
I want to know how long to dry herbs. There is a drying setting on the oven
You dry at 200 degrees. Anything higher will destroy the flavor of the herb. Usually it takes 4 to 6 hours or until the leaves are dry. Then put them in a blender to chop them up to a fine consistency. I sun dry my basil instead of oven drying. I have a dehydrator , but it takes 24 or more hours to dry them so I don't use it much.
Jun 17, 2015 | Microwave Ovens
Panasonic microwave does not achieve desired temperature
They never do ! You have to check the temp at where the air comes out of the fan and you need to use a remote electronic thermometer.
the old oven type won't work sitting on a the shelf. 275 degrees at best. Take it back it's not broken ...the just don't work as advertized
Apr 07, 2014 | Panasonic NNCS596S Microwave Oven
My recently purchased Rival RGST902 microwave stopped heating. Everything else works, it just will not heat.
HELLO.
The first wayout is to consider WARRANTY.If the microwave is under warranty return it to the point of purchase to enjoy warranty right.But if the microwave is not under warranty another wayout is needed.
Below is the solution on how to make our microwave heat food.
1 Remove oven racks and place them in soapy water to soak.
2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • Thanks.
    Sep 20, 2011 | Microwave Ovens
    The microwave looks like it is working but no matter what I do there is no heat. I put in a cup of coffee and hit the minute button. It turned on and goes around but the coffee is cold. So I tried...
    HELLO.
  • Thanks.
    How to preheat my godrej microwave at 200 degree
    my oven model no. is GMC25E09MRGX of godrej i m jst unable to preheat for making biscuits on 180 degree for 15 mins plz tell me
    Sep 14, 2011 | Microwave Ovens
    How to use self cleaning oven?
    1. Remove oven racks and soak them in soapy water.
    2. Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
    3. 3 Let the oven do its work;it will heat for several hours, charring off baked-on .foods
    4. Fast Cleaning
    5. 1 Remove oven racks and place them in soapy water to soak.
    6. 2 Preheat oven to 200 degrees.
    7. 3 Turn the oven off and spray the inside with oven cleaner.
    8. 4 Allow to sit for 10 minutes.
    9. 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
    10. 6 Dry with a soft cloth.
    rate this if it help
    Thanks.
    Oct 15, 2010 | Microwave Ovens
    Preheated oven with glass dish...tried to bake..now no power
    they have a fuse that blows if the cavity gets to hot looks like a small thermostat
    Jun 30, 2009 | GE Advantium SCA1001SS Convection /...
    15 yr-old GE electric oven takes over an hour to preheat to 450
    After jiggling the lower burn element the oven heated up in the normal time. Perhaps a connection had come loose.
    Feb 14, 2009 | GE JEM25 Microwave Oven
    Built in oven takes hours to reach desired degrees set.
    There may be a problem with either the door seal or the thermostat.
    The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
    If it still fails, you can download GE owner's manuals and installation instructions here in case you don't have yours.
    Once you look it over, if you still have a problem,
    GE Customer Service is here and they should be able to help you check it or send service if you have a problem.
    Feb 01, 2009 | General Electric PT970 Microwave Oven
    Convection Preheat doesn't reach the Chosen Oven Temperature
    I would first suspect the thermister (thermistor) or a low line voltage, weak control board relay etc.
    But the service manuals will show you how to safely disassemble, test and repair the unit.
    We have the service manuals for this model and have uploaded them to our site here and here to help you.
    You will need the
    free Acrobat Reader to view or print them in case you don't have it.
    The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
    Feel free to contact me directly (and please remind me of your full model number) for more information & help.
    William E. Miller
    prototech@usa.net
    http://www.microwavedisplay.com
    Jan 04, 2009 | Sharp R-1870 Convection/Microwave Oven
    Microwave Ovens Logo
    98 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
