Question about Canon PIXMA MP240 All-In-One InkJet Printer
First time I'm changing the ink - need help for dummies! I have no manual. Thanks
    Top Expert:
  • Canon Master
  • 76,132 Answers
Solution courtesy of expert Joed911 (thanks Joe!)
The cartridges are under the scanner and stay off to the right side of the unit except when printing or when you lift the scanner unit cover while the unit on. If the cartridges returns to the right, close the scanner unit cover and then reopen it. If the cartridge carrier doesn't move, make sure that the unit is turned on.
The black ink goes on the right side.
See instructions on this link:
http://www.retrevo.com/pdf/23126ag611/4/Install+the+FINE+Cartridges+Instale+los+cartuchos+FINE...#q=Canon+MP240
Click on this link or copy and paste the complete link into your browser.
Posted on Mar 30, 2011
Why won't my Brother LC61 printer pring the color on test pages?
You may find more success with water than alcohol - most inks are water based these days. However, you may find that ink has dried in the head, which you won't resolve. I can't remember if these have changeable heads or not.
Final option is to try printing a whole full page of cyan colour. It might eventually get through the dried ink and soften and start printing.
Jul 31, 2014 | For Dummies Brother LC61 Combo Inkjet...
I need the english manual for the fonegear mini Blu headset
try here. bought mine used and they changed the password. now to figure out how to change that. hope this helps. 3's
Grampa
http://www.manualslib.com/manual/251101/Fonegear-976.html#manual
Feb 19, 2013 | foneGEAR (00976) Wireless Headset
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Canon MP140 fails to print
I don't think that has anything to do with reaching the board of 5000 copies. Your cartridges have no chips on them or anything. You might actually have a problem with your black ink cartridge, as the printer is telling you. Remove the black cartridge, gently wipe the contacts with a dry cloth and put it back in. Hold the "resume" button (triangle in circle) for about 10 seconds to try and reset your cartridge. If none of that works, I suggest you buy a new black ink cartridge.
Apr 07, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
My friend just gave me an hp PhotoSmart P1000. I need a manual. Also how do I change the ink cartridge
www.downloadthat.com/.../hp_photosmart_1000_manual
copy and past this link in your address bar to go to your manual download site
the ink needs to be manually dragged to center of printer, then lift up front of ink cartridge, after it pops up, lift cartridge straight up and then out.
Aug 25, 2009 | Office Equipment & Supplies
Need to change the ink Roller
Remove the top cover. You should see a little black tap that says pull up (the ink roll), do so. Then pop your new ink roll in. Replace cover.
Mar 16, 2009 | The Times ROYAL TC100 TimeMaster Time...
Low on ink. don't know how to change ink cartridges.
Heres a direct link to the download page so you can get a manual, its free. CLICK HERE
That should help you the instructions for changing ink is in there, feel free to give me a Fixya rating if this answers your question.
Jan 04, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson C43SX communication error
It is presumed the 6 posts in this problem are all from the same person. If one (or more) isn't, and my response below doesn't help, would you you start a new separate post on your particular problem.
A solitary blinking red light means that the ink level in one of your cartridges is low, but printing can continue normally until the ink runs out, at which point the red light becomes permanently on. You must now change the ink cartridge before the print will work again.
If the green light is flashing at the same time as the red one, this means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C43 Service Manual". You will often find them for sale very cheaply on E-Bay. Note, however, if you can find or borrow any of the C40,42,44,60,62 service manuals, as far as ink pad replacement goes, they are the same.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
The reference manual is at
http://support2.epson.net/manuals/english/ij/stylusc43/REF_G/INDEX.HTM
which provides good information on the meanings of the error lights.
Please report back with further information if the above advice doesn't help.
Jul 05, 2008 | Epson Stylus C43SX InkJet Printer
Changing cartridges
Did you get the answer for how to replace the ink cartridge, because I don't have a manual myself and I can't even figure out where the ink cartridge is located?
Dec 11, 2007 | Office Equipment & Supplies
Canon PIXMA MP240 All-In-One InkJet Printer Logo
67 people viewed this question
old marine
old marine
