Question about RCA Lyra RD1072 MP3 Player
My memory card doesn't show up on my product and my computer
How to used my memory card in my product.
Posted on May 22, 2011
I have a memory card with photos on which I can retrieve onto my computer, but the latest photos show on the camera but are not showing on the memory card.
Perhaps you did hide the pictures. When you hide the pictures, (the ones you don't want to show to costumers) you only get to see them on the computer. To unhide, goto the playback menu look for the line hide pictures and press. Rest must be simple.
Jan 16, 2014 | Nikon D60 Digital Camera
It doesn't fit in the computer
Go to a computer store and ask for a "USB to PRO Duo Memory Card Adapter". Stick the card in the adapter plug the adapter into the computer.
Dec 18, 2012 | Sony 2GB Memory Stick PRO Duo Memory Card
Where on my dell inspiron/1200 do i insert sandisk
Do you mean an 8GB SanDisk USB flash drive (thumb drive) or memory card (SD card or another type) or another SanDisk product?
If you have a flash drive, plug it into one of the 3 USB ports on the back of the laptop. If you have other devices plugged in, you may need a USB hub to add ports. (Note: hubs can fail; try a direct connection if the unit doesn't communicate.)
If you are using a memory card, you need to add a memory card reader. USB card readers are available from many shops; they will be cheaper from some online vendors compared to the big box electronics stores. Get one that supports the format of your memory card. There may be PC card slot card readers but I'm not aware of any specific models. The Inspiron/1200 supports Type I or Type II CardBus devices; 16-bit PCMCIA cards are also supported.
If you have a different item, please add a comment giving more informatiion on which SanDisk product you are connecting to the computer. I hope this helps.
Oct 16, 2012 | SanDisk Televison & Video
SCREEN SHOWS---MEMORY CARD ERROR--I CANNOT LOCATE ANYTHING IN THE BOOK RE: THIS
Hello eilo311,
It is possible that there might be corrupted files on your memory card or it is also possible that your memory card is already malfunctioning and needs replacing and some other reasons. BUT the important thing is let us FIX that error. Do you have a memory card reader? Transfer ALL important files from your memory card to your computer and then format you memory card USING YOUR DIGITAL CAMERA. It is VERY important to format your memory card (especially if it is the first time you use it on your camera) so it will be compatible.
If that doesn't solve your problem, please reply here and indicate the brand and model of your digital camera and some more details regarding your problem so I can advice you what to do next.
Oct 14, 2011 | Canon Cameras
Not showing ther data
Insert the Memory Card to the card reader,
Then plug the card reader to the computer and perform the following setting to the computer.
Go to the Control panel,
Choose Folder Options
Then click on View.
Choose
Show hidden files and folders
and
Remove mark to the Hide extensions for known file types.
Again
Remove mark to the Hide protected operating system files (Recommended)
A Warning will Display Click OK.
Then Apply and Click OK.
Open My Computer and Go an Open/Explore your Memory Card for Backup of your data.
Copy a Data to the Computer and Format your Memory Card.
Before Restore you backup to the memory Perform the setting of file attribute to your data
Example of file Attribute is
Read Only
Archive
Hide
Right Click your Data
and then Remove a mark to the Hide in Order to view Your Data to the Memory Card.
Thanks a lot.
More Info; Rogerftn@gmail.com
or
Call
+255 755723228
Jul 05, 2011 | SanDisk 2GB microSD Memory Card
My blackberry 8520 keeps on saying my memory card has fatal errors and when I go on the computer the folder 'blackberry' doesn't show. My phone wont let me format or repair the card. I've...
Look on this forum:
http://supportforums.blackberry.com/t5/BlackBerry-Curve/Problem-updating-device-software-quot-Fatal-error-quot/td-p/82515
Jun 18, 2011 | SanDisk 2GB microSD Memory Card
My new 4g memory card will not let me use it, say memory error
Hi there!
Since this is a new memory card, the first thing that you can do is to format the memory card through the camera menu.
If that doesn't work, try another memory card. If that card doesn't show the error then your new memory card is the problem.
Hope this helps.
May 14, 2011 | Cameras
How do i put a memory card from my camera into the computer so i can upload pictures to myspace?
If your computer doesn;t have Built-in Card Slot(s), then you must get a USB - Memory card adapter. I have included an Ebay link so you can see what I mean.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=usb+-+memory+card&_sacat=See-All-Categories
Then, you simply install the USB device and drivers. After which, you plug in the memory card to the USB adapter, the card will then show up as a "Drive" as such it can be used as normal, ie: Cut-Copy-Paste. The pics can then be used either straight from the Card, or copied somewhere else on ya PC, say desktop, and use them from there.
Jan 19, 2010 | Samsung SyncMaster 793MB 17" CRT Monitor
"Storage Device Unreadable. Format Now.?"
yes there is a possible solution to your problem....there seems to be a problem with your card....and it doesn`t look like you can get your data back from it ...so you will have to format your memory card....connect your card to a computer through a memory card reader by also using your micro card`s adaptor and then format it from your computer......hope this helps.....please vote ...help us to help you better
Aug 07, 2009 | Motorola Mobility V360 Cellular Phone
Gateway Camera DC-T50
Check memory card from computer with card reader.
If that doesn`t help.
Try formatting memory card from camera or from computer (it will destroy data on card).
Most likely your pictures are alredy lost.
Feb 13, 2008 | Gateway DC-T50 Digital Camera
RCA Lyra RD1072 MP3 Player Logo
20 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
