Error in photoshop 7.0 - Computers & Internet
    Champion:
  • 232 Answers
TRY UNINSTALLING ,RESETTING COMPUTER AND REINSTALLING SOFTWARE, MAKE SURE YOUR COMPUTER HAS ENOUGH RESOURCES TO EXECUTE THIS PROGRAM
Posted on Aug 04, 2008
Photoshop 5.5 r6025 error web
If the operating system is windows 7 or above the XP software will not run, it has to be compatible with windows 7 up.
Apr 20, 2017 | Adobe Computers & Internet
I hove got the error number0x80040303 in intalling adobe photoshop cs 2 in my windos 7
Forget about installing Photoshop CS2 or CS3 or lower versions on Win 7, the software are not compatible with Win 7 OS. Get a newer version CS4 or higher.
You can check it @ Windows 7 Compatibility Center
Hope it helps.
Sep 23, 2010 | Adobe Photoshop 6.0 for PC
Install photoshop elements 6 for windows 7, it does not open at all after installation.
You have to wait for the information about the compatibility of the Adobe Photoshop Elements 6 and Adobe Photoshop Elements 7. You can upgrade to Adobe Photoshop 8 which is completely compatible with Windows 7. You can check the compatibility here. Check event viewer for the error message, for this click on start menu type Event Viewer and press Enter. It would be better to check with Adobe for what operating systems that Photoshop Element 6 would be supported. However you can try installing Adobe Photoshop Element 6 in a fresh installed Windows 7.
I hope this helps.
Apr 21, 2010 | Adobe Photoshop Elements 6: Windows
Photoshop 7.0 installation fails with the error message: "An error occurred during the move data process : -106" Upon install process it makes it to about 1% then gives the following error code....
one problem that could cause this error is lack of administrator rights,
right button click the setup.exe or whatever it called and select run as administrator,
Or if it's Vista try the compatiblity help , right button click the app, select properties and select run as XP service pack2 etc
Regards
gewiz.co.uk
Nov 30, 2009 | Computers & Internet
Installed photoshop 7 on my laptop and everytime I start the program and click on editor, it tells me the program will automatically shut down. Is there a fix for this problem?
The error telling you that Photoshop 'will automatically shut down' is a waterd-down way of telling you there was a critical error and that it was not able to open. There appears to be a corruption in your Photoshop installation.
I would recomend uninstalling Photoshop 7 and then re-installing it again as follows:
- Click Start > Control Panel > Add/Remove Programs (or 'Programs' in Vista or Win7)
- Locate Adobe Photoshop 7 and click on it and select Uninstall.
- When it has completed, restart your PC.
- Once restarted, re-install Photoshop 7 via the CD/DVD.
Hope this helps,
-Tor
Nov 21, 2009 | HP Computers & Internet
Photoshop elements 7 will not download onto my laptop
I think you have problem with  you setup package.if you tried to install through cd or dvd then first clean it with clean cloth and try to install . If this error again appears then contact adobe company with activation code or you details . Then they will provide new product
Nov 01, 2009 | Adobe PHOTOSHOP ELEMENTS 7 for PC
Photoshop Elements 7 is not working on my vaio with vista 64 bit
Starting Adobe Photoshop Elements, the Editor returns the error message "Unable to continue because of hardware or system error. Sorry, but this error is unrecoverable," and the Organizer returns the error message "Interface not found."
Solution: Enable the Event log service.
1. Choose Start > Settings > Control Panel.
2. Double-click Administrative Tools, then Services.
3. Right-click Event Log and select Start.
Note: The Event Log can only be disabled in the Microsoft System Configuration utility (msconfig) under the Services tab, but should never be turned off.
Background information
The error messages "hardware or system error..." or "interface not found" when you start either the Editor or Organizer indicate a system level problem. These messages display if Event Log is disabled. The Event Log is a Microsoft service that should never be disabled.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Sep 23, 2009 | Adobe Photoshop 6.0 for PC
Scratch & windows error
You must change the location of Photoshop's primary scratch disk to a different HD or other HD partition. You can do this using the Windows Explorer
Oct 28, 2008 | Adobe Photoshop 7.0 for PC
Photoshop's Primary Scratch & Windows primary paging file on the same volume
this is not a hardware error actually photoshop writes temporary files, for which it uses hard drive, its alway a better to have scratch disk other then the drive where its installed, you can change this, by going to edit, preferences, then check plug ins-scratch disk, check your first scratch disk other than c, say the drive which has the maximum space, then select any drive
how do you like the solution please rate it i will appreciate your comments
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
