Question about Kenmore 22982 Top Load Washer
Kenmore 80 Series - Agitator clunks only during the high speed portion of the spin cycle. It makes a kind of rubbing noise and as it spins faster it begins to clunk jerks like it wants to lock up.
5 Suggested Answers
  • 1314 Answers
SOURCE: loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Posted on Jan 11, 2008
duby1990
  • 367 Answers
SOURCE: Kenmore 80 series makes noise in sping cycle
Its the transmission. Try to find a used appliance store in your town. Most save used parts and you should be able to pick up a used tranny for around 100 bucks.
Posted on Nov 20, 2008
Maytag317
  • 1136 Answers
SOURCE: replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 03, 2009
aasc
  • 1606 Answers
SOURCE: Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Posted on Aug 02, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Loud noise during spin cycle
what kinda noise, sqeeling, or clunking, mite be sumthing small that made its way behind ajatator an is causeing noise..or one of the springs that hold it broke..sorry i dont no what kind of noise.....
Jan 31, 2010 | Washing Machines
Kenmore 80 series has loud banging sound during the spin cycle
I had a washer that at the beginning of the spin cycle it was fine, but when the water was half drained it would begin making a banging noise. When the draining reach the bottom and the spin speed increased it was fine. Finally found the problem - What happened was the tabs that hold the control arms for the brake had loosened. During the spin cycle especially in the middle of the cycle (when torque was at the maximum and speed was at medium. The brake spring would flex out due to compression and hit the some extended metal tab on the brake housing. Once the speed increased and the torque reduced the spring no longer hit the housing tabs. Fix the problem by bending the tabs that hold the brake control arms in place to better hold the control arms in the proper location.
Jan 19, 2010 | Kenmore Washing Machines
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series washer - agitates and drains but does not spin
my kenmor washes and drains but does not spin, help
Jun 17, 2009 | Washing Machines
Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Mar 10, 2009 | Kenmore Washing Machines
I have a Kenmore series 80 washer that is making a loud clunking
check the motor coupler between the gearcase and motor for wear. If it is cracked or broken it will need to be replaced
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Kenmore 80 series washer make high pitched whining noise
cold water screen in hose was half plugged causing it to either shut off the spin cylce due to lack of water or increase the spinning speed.
Hope this solves the problem.
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
Nov 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22982 Top Load Washer Logo
70 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
