Question about Denon AVR 3808Ci Receiver
I have a sx 1250 and i was told it has a blown channel. i would like to know if i can fix it or should i take it to an expert. this unit is not light so less hauling is a benefit to me
    Brigadier General:
  • 8,546 Answers
It CAN be fixed. By whom? I'd schlep it once to a technician for a start. Or hold it up in front of your monitor while WE ponder it (kidding).
Posted on Mar 30, 2011
OVERLOAD issue
check the attached service manual.
H appears normal and L appears to be defect.
also see page 88 to troubleshoot further Pioneer SX 316 Service Manual
Apr 05, 2016 | Pioneer Sx-316 Audio Multi-channel...
I brought my 2006 Kia spectra SX in for a Check Light Engine resulting in a P0449 code after the Smoke test the light went out. I was told the part to fix this requires a Charcoal Canister Assembly...
You're probably not far off on that part unless you can buy it over the internet. You may want to look and see if there is on available cheaper. Good luck.
Nov 17, 2014 | 2006 Kia Spectra SX
1976 pioneer sx 1250 receiver has no sound from receiver to speakers
for
1976 pioneer sx 1250 receiverhas no sound from receiver to speakers
check the integrity of speaker systems,
check the receiver internal components, pay close attention to the
capacitors, possibly have dried up or swollen (age)
Check for continuity to the speaker outputs.
These may take some time, but I hope you will make it.
Sep 09, 2012 | Audio Players & Recorders
Unit does not power up. Opened unit and found fuse closest to power switch blown inside unit. Will replacing this fuse get my unit working again? If so, what would cause this fuse to blow? please help.
It is possible that the fuse was blown due to a surge and replacing it will resolve the problem, but I wouldn't expect it. Usually when the main fuse blows, the primary stage of the power supply has a problem and the replacement fuse will blow as well. This is not a cheap amp and I would suggest that it be checked by a service tech. A few quick measurements internally can determine the likely fault and should not cost too much as an estimate fee.
Please keep us posted.
Dan
Jun 22, 2010 | Sonance Sonamp 1250 12-Channel Amplifier
How do i bi amp sx 1250 to get both channels of each side to work together
you are actually not bi-amping the unit, you are bridging the amp. this really only works as long as all channels produce equal power. next the bad news is that typically home stereo amps are not wired internally to bridge channels.
bi-amping a speaker refers to connecting on channel to the highs and on channel to the lows. the receiver would need to be be able to process the outputs via a crossover network to split the frequency range in half so the appropriate frequencies went to the correct speaker.
Sep 21, 2009 | Sunfire Theater Grand Amplifier
Pioneer SX-9000 Receiver Nothing out of the left channel no sound
Could be as simple as a bad connection at one of the regulators or as complex as a blown channel. These are good units that are worth the repair cost. Where are you located?
Dan
Jan 30, 2009 | Pioneer SX-205 Receiver
Hello I have a Pioneer SX-315 and the power shuts off after 10-30 seconds what is wrong with this unit
try to reset the unit, i dont know how to reset but you can ask some expert, hopefully it works!!
Jan 15, 2009 | Pioneer SX-315
Pioneer sx 1250 wil not start when turned on.
In all probability , the unit is in "protect" mode. This means that a problem was detected in the output section and the receiver shuts down to prevent further damage. Expect a parts cost in the range of $30-$60 along with the local labor rate.
Dan
May 07, 2008 | Audio Players & Recorders
Distorted sound coming out of SW channel only
try turnind down the sub from the amp itself it might be putting out more volts than the subs input can handle check your standing wave feature to make sure the trim is not up too high
Jan 13, 2008 | Pioneer SX-315
Denon AVR 3808Ci Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
