Question about Homelite Garden
Where can I find a manual for the homelite chainsaw ut10540?
    Novelist:
  • 111 Answers
Http://www.homelite.com/product_manual/file_url/64/UT10540_60_80_339_r.pdf This is the page that has the product manual for this model number.
Posted on Mar 31, 2011
I have a homelite 350 automatic chainsaw. How can I get a repair manual for it?
http://www.mymowerparts.com/pdf/Homelite-Parts-Manuals-For-Chain-Saws/
May 02, 2016 | Homelite Garden
Homelite ut10540
From fuel tank to primer bulb to carburetor with a return.
Apr 08, 2014 | Homelite Garden
Homelite UT10540 chainsaw was cutting fine..cutting thru a 6" stump of Yew, started to labor, backed off gunned it back and resumed cutting...same thing but engine stopped. Noticed it was smoking a...
Hi and welcome to FixYa, I am Kelly. This sounds as if the engine leaned out big time. You may have a hole in the piston. Perform a compression test looking for 110 PSIG minimum. There is a bit of a compresion release due to the design of the cyliner head so you will not see full compression on a compression test. Your compression should be 110 PSI or above. There is the possibility you also have a fuel supply problem that caused the engine to run lean. This could be from debris in the carb or a hole in the carb diaphragm(s). I know this is a 35cc engine and has a 14" bar unless you changed it to a 16" bar.
Parts:
http://www.ereplacementparts.com/homelite-ut10540-35cc-chain-saw-parts-c-18807_21362_127279.html
The piston is in detail D but appears to NOT be available. (no release date)
This engine takes carb repair kit H142-42 (Ruiing) The kit is under $6.00.
My real concern here is that you added fuel to the cylinder and did not get a momentary start (new plug too). That is why I think you may have a hole in the piston from running lean. (Compression test is a must) If you do not have a compression tester... fit a paint brush handle (form it) so that it does not penetrate any deeper than the electrode of the spark plug into the cylinder but make it a tight fit. When you pull the recoil do it with conviction. It should pop the paint brush about 10 feet if you had it TIGHT in the spark plug hole. Also use a flash light and do what you can to inspect for about a 1/4" hole in the piston. (Won't be easy to see the whole pistion head)
Thanks for choosing FixYa,
Kelly
Sep 23, 2011 | Garden
I need a manual for a Homelite chainsaw Where is
Hi calwolfe...
Go to the following website and download your manual, if it is among the list.
You did not get me a model so I did not have much to work with to find your user manual for your chainsaw.
Please take time to rate me
http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/homelite_chainsaw_product_list.html
Sep 10, 2011 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
Hello, I am looking for a repair manual for a Homelite 300 chainsaw
Hello DRB, you will need to contact Homelite directly, and their customer service should be able to provide a manual. Here is the link.
https://register.homelite.com/contact_us/new
Nov 23, 2010 | Homelite Garden
Not running at full throttle
close to the carb you will find two tiny screws. They are labeled H and L. L sets the idle speed. H sets the max RPM. Hold the throttle wide open and turn the H screw. When you find the very top end, back it down some or it will be running too lean. That would make it run hot, and provides less lubrication. Could result in engine failure if you run it too lean.
Dec 23, 2009 | Garden
Homelite cs3314 chainsaw
Here is a link to get you your parts list. Make sure you have your UT#
http://odref.com/homelite/chainsaw/index.html
Apr 05, 2009 | Garden
Owners manual for homelite chainsaw
Have your UT# available.
Mar 27, 2009 | Garden
Need to adjust carburetor jets of homelite chain saw
what is the adjustment for high and low settings on a homlite 330 ?
Jan 11, 2009 | Garden
Garden Logo
162 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
