Question about West Bend Kitchen Appliances - Others
Bread sticks to bread pan even though it wa pre-sprayed prior to baking, and is especially hard to getr out- usually breaking apart.
    Genius:
  • West Bend Master
  • 1,280 Answers
Your are probably using too much liquid. Look a the dough during the 2nd knead...if it hasn't formed a ball and the pan is still has batter sticking to it that is a sign you have too much liquid in your recipe...
Posted on Apr 01, 2011
Do I need to spray the well of the baking pan
No, not a good idea as that is where the heat is. You will just make a burned on mess. You only spray the inner pan where you put your ingredients.
Apr 23, 2016 | Kitchen Appliances - Others
How can I keep a baked loaf of bread from sticking to the pan ina west bend bread maker?
Let pan and loaf cool for about 10-15 mins then try to slide it out then. Also you can very gently ease a plastic knife around the top of the bread, to see if this helps.
Feb 01, 2014 | West Bend 41053 Bread & Dough Maker
Bread sticks to the pan and the dough blade what am I doing wrong
It is not uncommon for the paddle to get stuck in the bread loaf especially with thick crust breads (i.e. french) Be sure to choose light crust and sometime using milk instead of water help too.
Feb 08, 2013 | Kitchen Appliances - Others
My toastmaster bread machine 1142, the bread sticks to the pan and the kneading tool gets lodged in the bread after it is baked. What can I do to prevent this or do I need to buy a new bread pan and...
The next time you make your bread use the same recipe but use 2 table spoons less liquid. Having the paddle come off in the bread is not abnormal. If the bread sticks to the pan again let me know daryl441@msn.com Sometimes my paddles stay in the loaves sometimes they do not.
Mar 24, 2011 | Toastmaster 1142 Bread Maker
The driver that operates the kneading blade ( paddle) is falling out of the baking pan from the bottom. It appears a washer has disintegrated. Pieces seemed to fall apart when cleaning. any suggestions? I...
There is a sealed bearing at the bottom of the pan. This allows the paddle to rotate. The bearing has failed and is falling apart. This usually happens with age or use. Time for a new bread pan. If you are lucky you can find one on ebay. Sorry for the bad news....Hank
Dec 09, 2009 | Oster 5838 ExpressBake Bread Maker
Bread pan does not release loaf after baking.
The Teflon coating on the inside of the pan has worn. You will need a new pan and probably also a paddle. In the meantime you could try spraying the inside of the pan with cooking oil prior to each use.
Sep 21, 2009 | Kitchen Appliances - Others
Bread sticks to pan and crust always burnt
My wife grinds her own wheat, and bakes her own bread. She suggests using less sugar. You also could try switching to honey if using white sugar. Too much sugar/honey will cause over browning and sticking.
If problem persists post back.
Sep 25, 2008 | Toastmaster 1193 Bread Maker
Bread sticks to pan
May be that the coating on the pan is just wearing off. Had the same problem several years ago and it was just that the poor old machine was over used and the simplest solution was to buy a new pan. That machine went though 2 of them before it died its self.
- Neil
May 25, 2008 | Breadman TR444 Bread Maker
Dough blade sticks in bread
Dunno - I've got the same problem. A few things do help: 1. Scrub the pan THOROUGHLY before baking new bread. Especially around the paddle, where little bits of baked dough can collect. 2. Put in a little more butter or oil or shortening than the recipe calls for. Just a scoche.  3. Put the bread up before going to sleep, and take out in the morning. That seems to allow enough time to elapse that the bread comes out without taking a chunk out of the bottom. I also tried putting the pan in wet from a washing, instead of waiting for it to dry. This morning's loaf came out fine & dandy. I don't think anything's going to stop us poor 3400 owners from having to bang the bread pan upside down on a cutting board in order to get the bread out of the pan. Sigh.
Hope this all helped. Amy
Dec 21, 2007 | Welbilt ABMIL2P Bread Maker
Blades stuck inside bread
Unfortunately trying to stick the paddles in the pan just tends to leave half the loaf in the bottom with them. The best method i have found is to cut the crust around the outside of the paddles, carefully avoiding the bit where the actual paddle blade is, then you insert a rod into the centre of the paddle and tilt it towards the blade. They normally come free pretty easily. Another method you can use if you are around the machine when it is making bread, is to remove the paddles at the end of the mixing/kneading cycle, just before the baking cycle starts. Most machines have a small pause allowing you to do this - sometimes with a "beep" or screen message to tell you that you can do this. Sorry i couldn't find the exact info for your model, it will vary for different baking programs also. If you check the cycle to determine at which stage it starts actually baking, then you can do this quite safely so long as you are careful of the machine heating up while you are removing the paddles - usually you would have around 20 minutes at least to remove the paddles before baking. Hope this helps :)
Apr 11, 2007 | Black & Decker B2000 Bread Maker
Kitchen Appliances - Others Logo
35 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Oloyede Monsuru
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
