Question about GE Washing Machines
Ge washer won't spin and drain - GE Washing Machines
  • GE Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Mar 30, 2011
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
Mar 28, 2013 | GE WBSR3140DW Top Load Washer
GE WSXH208V1WW
Usually when you have a washer that will not drain, first check if the drain hose is kinked or too high above the washer (8 ft is the limit of the washer pump). Next check if there is a blockage in your drain (often a stand pipe) or if the air can't get into the stand pipe. The final thing to check is for foreign objects in the pump to drain hose area that block the drain. (This requires getting into the pump and disconnecting the hose. Keep a bucket ready to catch the water that will pour out of the washer.)
GE has the manuals for many of their appliances on their support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click submit. The direct link to the manual for the WSXH208V1WW is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90256.pdf .
I hope this helps.
(at least my washer won't spin if the water can't pump out. On a few washers (non-high efficiency) the solenoid has failed to open for the pump to drain the water.)
Nov 22, 2011 | Washing Machines
My GE washer #WDSR2080DEWW washer won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Aug 13, 2011 | GE WDSR2080D Top Load Washer
Ge washer won't let water spin out
heatman101
Aug 11, 2011 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
GE Washer will wash but won't drain?
heatman101
Jul 24, 2011 | GE Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My ge front end loader washer won`t spin water or pump water out
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
Hi. my ge wjse3110a won.t spin unless is start spinning it first by hand
The motor is going bad...
heatman101
Sep 07, 2010 | GE WJSE3110A Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
199 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
