Question about Canon imageRUNNER C3200 Copier
Side paper deck set to A4 setting by default... how do I change it to Letter size?
  • Canon Expert
  • 287 Answers
Hello Eileen,
If I can successfully convey the way for you to enter service mode,and then guide you to where you need to be then this is cake. To enter service mode you need tho make a fluid 3 three step key execution. Locate the "additional functions" key.Press it and release,press the numbers 2&8 at the same time and release,press additional funtions again and release.3 steps,fluid,and prompt.You may need a few tries and don't be afraid to press reset if you fumble.Once you have entered service mode the screen will change and say "service mode". You will have any number of tabs to select from on the screen but you want to select "COPIER".New screen shows. Now focus on the tabs across the top of the new screen. Select "OPTION".Now the screen will have tabs in the "body " of the main screen. Select "ACC". Now select "DK-P". The value there is " 0 " which means A4. Press the number "1" from the 9 key pad then press "OK" at the lower right corner. Then 1 should appear now to the right of DK-P. Now turn the main power switch off located on the right side of the copier, at the rear , about halfway down. Wait a sec, and power up. If we worked together properly you are fixed.Best of wishes.Please let "FIXYA" know if we succedded. :-) SPINAL
Posted on Mar 31, 2011
  • jeff heightchew
    jeff heightchew Apr 01, 2011
    I see some one has "viewed" this fix. Well thats's cool but I CAN ASSURE YOU THAT IF THESE STEPS ARE FOLLOWED THE PROBLEM WILL BE RESOLVED. I suppose a person could lend the assurance that they have been proficient at solving problems after working on Canon, Toshiba, Danka, Samsung, Kodak, Ricoh/Savin copiers for 23 years and still be full of ****. I have met people who have been able to keep a job 23 years and they are still idiots. I, am not one of those.
Load mp feader a4
Please determine what size you are trying to print (A4, Letter, Legal, etc.). The printer is requesting A4 sized paper in the maunal paper feeder becuase either you selected manual feed or the setting for the default try (usually tray 1) is not set to the correct paper size. In your case, make sure the green slide adjustment on tray 1 is set to A4.
Mar 22, 2014 | Lexmark T632 Laser Printer
Always showing the manual feed option when we printing. We would like to set it as automatic printing. How can we do that in default. Please help. We checked all the menus. example: in system set up paper...
If you are in Canada or US then you need to set the default paper size to Letter not A4. Most if not all software you use likely sends the print job in letter format. Because the printer is set in A4 it stops and waits for that size.
Mar 11, 2011 | HP LaserJet 3050 All-In-One Printer
Paper size
check default setting with bypass try
usually it is letter size change into the a4
Apr 21, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
My hp laserjet 4015n is very slow whiles printing after changing the setting to factory default
You need to set your paper tray correctly. If you are using Letter, make sure the tray is set to Letter, and if you are using A4, set the tray to A4.
"Any" is NOT a valid choice. You have to set the correct SIZE.
You will olso have to configure your driver correctly. Make sure the driver up to match your printers paper settings.
Good Luck.
Dec 15, 2009 | HP LaserJet P4015N Printer
Can't send or receive faxes after fixing error code problem
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Whenever i change paper size from A4 to letter,
Don't set by using the "Print" option.
Go to [Start]
[Printers and Faxes]
right-click on the HP printer entry
! Don't select "Printing Preferences"! from there
Select [properties]
Select [Advanced] tab
Select [Printing Defaults]
[Advanced}
(I know, the screen looks the same, but it functions differently this way)
Change paper size to "Letter"
[OK, OK, OK]
*done*
Sep 25, 2009 | HP LaserJet 4350 Printer
Pc load letter
Hi there this issue is caused by your driver defaulting to letter and a4 paper being used set your default paper size to a4 in the driver and also set tray to a4 this should cure the problem Regards AL "alstech"
May 28, 2009 | HP LaserJet 4 plus Printer
HP6110 default paper size for copying
Yes, manually set your paper size using A4 or begin with A4 and leave it on auto (default) it will try and match it.
Instructions...
  • Press Menu
  • Option 1
  • Option 2
  • Select copy Setup
  • Select paper size
  • Hit the black triangle until the size you want displays
  • Then hit enter.
Dec 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark T632 says "Load MP Feeder Letter
Hi Pqpoppa,
Check the paper size setting in the printer. Set it to the paper size you normally use such as A4 and the default tray. Check the default paper size in the printer driver in your computer and the default tray. Finally, check the paper size of the document you are printing. If all these match, it should not try to be smart and ask you to feed paper.
Rgds
S88
Nov 03, 2008 | Lexmark T632 Laser Printer
When I print my letter, I set my defaults on my computer with Letter size. But pn the printer, I can't figure out how to change the cassette from A4 to letter. It's driving me crazy. Please help me default...
Go through the following
Start=Settings=printers and faxes=right click on the isatalled printer=printing preferences=change paper size from A4 to Letter. This will now remain as default.
Regards,
Manoj Joseph
+91 9352008418
Jun 18, 2008 | Canon Office Equipment & Supplies
Canon imageRUNNER C3200 Copier Logo
167 people viewed this question
old marine
old marine
