Question about Whirlpool LER8648L Electric Dryer
Dryer does not stop when you open door - Whirlpool LER8648L Electric Dryer
  • 57 Answers
Bad door switch. Easy fix. Remove two screws by lint screen that secure top to blower housing. On the right and left side( front of unit). Use putty knife to release top from clips. Top will hinge back to expose door shop. Good luck.
Posted on Mar 30, 2011
    President:
  • 1,489 Answers
The door switch is sticking. Door switch is around the door opening and is located where the door would push it in when the door is closed. It may just need cleaning or putting back in its rightful place or it may be broken and need replacing.
More info, let me know.
Charlie
THE LIGHT WILL NOT COME ON WHEN THE DOOR IS OPENED AND THE DRYER WILL NOT STOP WITH THE DOOR OPEN
The dryer has a switch in the door that is activated when the door is opened/closed, replace this switch or check the connector to it or the wiring.
Oct 25, 2016 | Kenmore Dryers
Dryer still tumbles even when door is open. It will turn of and stop when i turn it manually to off
The door actuator mounted on the door or the switch mounted on the dryer is missing or broken. The dryer is supposed to stop if the door is opened. Replace the door actuator or the switch.
Mar 03, 2015 | Dryers
We have a new Frigidaire FASG7074NR2. It stopped at the beginning of the cycle and read door open. The door was not open. We tried opening and firmly closing the door and unplugging but it still reads door...
Good Morning Frances,
I understand that your new Frigidaire dryer, model# FASG7074NR2, stops at the beginning of the cycle and states that the door is open. I also see that opening the door firmly, closing the door firmly, and unplugging your appliance, the display still reads "Door Open", and will not run. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your dryer and determine why it is stating "Door Open". I hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire Fasg7074Lr 7.0 Cu Ft Gas Dryer
Drum keeps spinning after dryer door is opened
What is the model number of the unit?
Nov 03, 2012 | Kenmore Dryers
My Dryer won't stop drying until I open the door.
If it does this in a Timed Dry setting the timer is bad. If it does this in an Auto dry setting it could be a bad moisture sensor or a bad timer.
Aug 21, 2011 | Crosley Dryers
Dryer runs when door shuts. Only stops when door is open
There is a safety switch in the door that shuts dryer off when door is open. If there is more to your problem let me know. From what you have stated there is no problem.
Jun 06, 2010 | Frigidaire FEQ1442ES Electric Dryer
Dryer stops in the middle of cycle
The door latch has failed, that's why your dryer stops. When the door opens it stops the drum and turns off. Fix the latch.
Jul 01, 2009 | Maytag PYE2300AY Electric Dryer
When the dryer is open the dryer keeps spining and wont stop you have to unplug it
Check the door switch. If the plunger is stuck, the dryer keeps running.
May 14, 2009 | Dryers
Dryer works for few minutes then stops
clothes can open the door if door latch is weak, causing door opening and stopping the cycle, or a bad automatic sensor
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Crosley Dryer Won't Stop When Door Open
Yes, however befor replacing just check it is not jammed on be abiuld up of fluff around microswitch Regards Advisor
Aug 29, 2007 | Crosley CDG6000 Gas Dryer
Whirlpool LER8648L Electric Dryer Logo
91 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
