My Brother MFC-9440CN is printing orange instead of red. I have replaced the magenta cartridge and the drum assembly (I suspect it would have been due for a change anyway) with no success. The old magenta cartridge was leaking toner causing a streak down the side of the paper - the new one fixes that but both cartridges print orange instead red. I am guessing the the toner leak from the old cartridge may be affecting the laser mirrors but have not been able to find any information on a DIY way to clean the mirrors. Do I need to take it in for service?
  • lhoagland Mar 31, 2011
    I tried the expert's suggestion to turn off color management and it did not work. His suggestion about a bad print head needs more explaining as I didn't know a laser printer had printheads?
    Genius:
  • 1,570 Answers
Yes the magenta cartridge might be defective. Try to replace new again.
Also, you are correct that maybe the leak powder is the problem. Sometimes it happens. You have to clean the toner compartment, fuser rollers and other inside the toner compartment.
Try also to shake well the toner cartridge that might be sticky to distribute evenly the toner.
If not, you have to replace the magenta cartridge and it is faulty.
Post comment for more help. Run also the calibration and maybe there are other toner that is low. Normally when toner cartridge it empty, the color of the print out changes.
Post comment if you need more help. Regards
Posted on Mar 31, 2011
  • 10,319 Answers
Either a faulty print head or fom what you say above you haven't turned off color management. In order to disable color management you need turn "on"
My Brother mfc 9440cn is printing a ghost image. how do you fix this?
The most common remedy is to clean the drum unit, but you have replaced that. Try cleaning the corona wires, p144 here
http://www.manualsprinter.com/manuals/brother/Brother_MFC-9440CN.pdf
Jan 11, 2015 | Brother MFC-9440CN Laser Printer
The printer is low on cyan and magenta toner. However, I only need the black ink. How can I still print?
change the black cartridge if need be and program printer to only print black using printer/devices preferences tab. try.
Aug 18, 2013 | Brother MFC-9440CN Laser Printer
I just put in a new toner cartridge and it still prompted me to add a new one, it was still printing so i kept going. But now it's saying that the cartridge is empty and refuses to print any more. I've...
When you replace the Drum cartridge with a new one, you need to reset the drum cartridge counter by using the following steps:
  1. Turn the the machine's power switch back on.
  2. Press Menu > Machine Info. > Reset Menu.
  3. Press the Up or Down Arrow key to choose Drum.
  4. Press OK.
  5. Press 1 to reset the drum unit counter.
  6. Press Stop/Exit.
This will reset the counter and will see the toner cartridge as new..(if in the menu it is available toner reset instead of drum ..choose that one )
Mar 16, 2011 | Brother MFC-9440CN Laser Printer
My mfc-9440cn prints a black line on the rigth side do you know what could that be? maybe needs new drum?
Hi there !
If you are self refilling the toner cartridge, the roller drum can be damage due to wear and tear. I need to replace new toner cartridge other i will getting wider and wider on both left and right of the paper.
Jan 13, 2011 | Brother MFC-9440CN Laser Printer
I have a Brother MFC-9440CN. It has been sitting for a while and when I print the right side of the paper has a lot of specks. How do I clean the inside of the maching.
In the users manual, it has directions on how to run a cleaning sheet. Do this 5 times. If it does not correct the error, open the machine, remove the cartridges and inspect the carts and the drum unit for excessive toner. If one of the carts is leaking, replace it and run the clean procedure. If the carts are clean, the drum unit needs to be CAREFULLY blown off with deionized compressed air set to 35 psi.
Sep 29, 2010 | Brother MFC-9440CN Laser Printer
How do I set Brother 9440 MFC to print using black cartridge only?
You can set the MFC-9440CN to print with the black toner cartridge only through the printer drivers.
If you are using Mac, this needs to be changed before you print or set a preset.
If you are using windows, follow the below steps.
1. Go to Start menu \ Control Panel \ Printers (devices and printers for windows 7)
2. Right click on the MFC-9440CN and select "printing preferences"
3. Under the "basic" tab, you will see "color mode"; simply select "mono"
Thank you,
Mar 28, 2010 | Brother MFC-9440CN Laser Printer
Magenta Dots vertically on Left margin of page
That is referred to as a repeating defect...most likely caused by a defect on the magenta drum unit. Here is a link for information on how to repair this problem:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000016/faq000216_016.html?reg=us&c=us&lang=en&prod=mfc9440cn_all&Cat=3
Jan 17, 2009 | Brother MFC-9440CN Laser Printer
Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Sep 07, 2008 | Brother MFC-9440CN Laser Printer
90 people viewed this question
jasbo
jasbo
