Question about Briggs & Stratton Garden
I have a Briggs @ Stratton self-propelled mower that will start but cuts off after a few seconds
    Novelist:
  • 111 Answers
There is probably water in your carburetor that is keeping the unit from running. When you press the primer bulb you are pushing fuel past the water into the carburetor .. this is why it will start up. Then it will try to pick up the water and then the unit will die. I would loosen the bowl nut on the bottom of the carburetor and dump the fuel from the fuel tank into an approved container. Also you may take the carburetor bowl off and see if you can see some water on the bottom of the bowl. Keep the bowl steady when you remove it. Also, check to see if the carburetor has any corrosion from the water sitting in it. It may have a white "stalagmite" appearance, or a varnish if the fuel was left in it from the last time you ran the unit last fall. If there is any corrosion you may be able to clean it up with some carburetor cleaning spray. This is available at any hardware or automotive store. After you have done this, then put some fresh fuel in the unit and prime it up and see if it will continue to run. If it does not run, then the carburetor needs to be removed and cleaned. To clean the carburetor you will need a thin wire. You can use this wire to probe the holes in the carburetor and "push" any obstruction out of the way and then you can use the carburetor cleaner to make sure the passage is clear. Then blow the holes out with compressed air. This should clean it up. If the unit still does not run then you may have to replace the carburetor with a new one. If you have to get a new carburetor, take in the MODEL, TYPE, and CODE off of the flywheel housing. It is stamped in the metal.
Posted on Mar 31, 2011
Testimonial: "thank you very much. I followed your advice and I am back in business again."
Briggs and stratton 650 series mower starts but cuts off Replace spark plug and put oil in It is a self propelled mower
be sure the oil level is not over the full mark. the plug is good? try to pour some gas in the carburetor, if it starts and runs a few seconds i would say the carburetor if plugged and needs taken apart and cleaned real good
Aug 13, 2016 | Garden
SELF PROPEL NOT WORKING
usually john the belt will stretch and start slipping. if you take off the cover and see if the belt is still on the pulleys turn it a few times to see if it is tight if not replace the belt.
Apr 29, 2016 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
How do I change the belt on a Briggs and Stratton Self Propelled 7.25ex lawn mower
unbolt top cover 5/16, unbolt bottom cover 3/8 unbolt blade 9/16 or 5/8 remove old belt, install new one, install covers and blade
Oct 01, 2014 | Briggs & Stratton Garden
Where is the carburetor on the Craftsman 675 Series 190cc 22" cut self-propelled lawn mower?
The carburetor would be located BEHIND the air filter housing and air inlet tube. The air filter housing should have a removable (by screw or clip) cover.
Apr 13, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
It starts up and sputters out in a few seconds . It has a briggs and stratton engine Used twice.
Remove the brass bolt holding the carburetor bowl on at bottom of carburetor. Inspect all holes and clean (at bottom and on smooth part of bolt). Clean out bowl also. Reassemble.
Jul 11, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
May 17, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
ACCELERATOR HAS STOPPED WORKING ON BRIGGS & STATTON PETROL MOWER
when the lawn mower suddenly stop working,first you should check the fuel. i think the Self-propelled device was broken. You can take the Self-propelled device off and try again with it.
May 03, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
390 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
