I have a JVC t.v. purchased around 1995 . It has been working great but we tried to power it on and it just clicks and the power light comes on . Is there any hope?
  • Sharon Butler Bagherpour
    I just wanted to give you the model # AV-32820 manufactured in 1997. Would the instructions be the same?
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 30, 2011
  • Walesarumi
    Walesarumi Mar 30, 2011
    Yes, the instruction is the same irrespective of its model. This is common with TV's having a problem problem........
1995 pontiac lt1 sluggish no power slight back fire
sounds like a fuel problem, may have water in the gas or needs a fuel filter , try a bottle of drygas before the filter
Jan 04, 2013 | 1995 Pontiac Firebird
Power light just keeps blinking and T V will not turn on
Purchased just a month ago? It should still be covered by the manufacturer's warranty. Unless the seller isn't a legitimate retailer. Try warranty repair before worrying about fixing it yourself.
Nov 19, 2008 | JVC Televison & Video
No picture, clicking sound coming from speakers, power light blinks
visit http://fletchersite.com/documents/ask.html for an immediate solution to this problem.
Jun 30, 2008 | JVC AV-56WP30 56" Rear Projection...
Flashing power light on JVC 48W TV
Tri to remove the concergence pcb assy and start the Tv.If the TV is working just replace the convergance IC.
Feb 11, 2008 | JVC AV-48WP74 48" Rear Projection...
Tv wont power up makes a noise but no picture
Your power transformer is likely shot. It'll cost at least $200 to have it replaced. Someone can come to your house to diagnose it. Usually costs around $65.
Nov 03, 2007 | JVC AV-56WP74 56" Rear Projection...
Subwoofer not powering up
I could either be the sub or the main unit. The main unit actually sends a signal to the sub to turn it on so if that circuit is bad in the main unit the sub is never going to come on. I've also seen bad cables (You'd be amazed at how stubborn people can be when din connectors don't cooperate).
Sep 10, 2006 | JVC TH-M505 System
TV, i plug it in, turn it on, no image, "on timer" light comes on.
If you dont hear a click theres a problem in the standby power supply. if you do hear a click theres a problem in the Main power supply or sweep supply. Get a good tech to look at this for you if your not a tech. Good Luck
Aug 07, 2006 | JVC AV-27D302 27" TV
JVC AV-27820 27" TV
probably some cold solder joints. take your time and check over whole circuit board and re-solder what looks bad.
Jun 10, 2006 | JVC AV-27820 27" TV
Televison & Video Logo
Top Televison & Video Experts
