Have new HL-2140 printer which seems to print too lightly despite efforts to adjust per instructions provided
    Novelist:
  • 129 Answers
Hi there!
You can try to check again the printer priperties: If the Toner save is off or if the resolution is set to 300dpi.
Hope this help. Please rate if its works. Thanks
Posted on Mar 30, 2011
I am trying to hook a Brother HL-2140 laser printer to a dell computer. I am unable to print since I've recently hook up the new computer. I hooked everything up like how it was on the old...
Re boot the computer with ,( wired or wireless printer?), the printer cable in the USB port in the laptop/desktop, the windows version you have will ID the device and try to load a driver, or Go to printer in the start menu and ADD a PRINTER the software will search for the attached printer. OR use the software that came with the printer, load into the Dell and follow the instructions.
Nov 10, 2012 | Brother HL 2140 Laser Printer
Tip
Resetting Blinking Toner Light HL-2140
Here is the procedure for resetting the Toner flashing light on Brother HL-2140 (sources for other answers here and self testing - specific to HL-2140)
  • Open the front cover and leave open.
  • Turn the printer off.
  • Hold the "white button" while turning the printer on. (All panel lights should be on.)
  • Release the "white button".
  • Press the "white button" 2 times (Pause, wait for all lights to come on.)
  • Press the "white button" 5 times. (All lights to come on again, then go out.)
  • Cancel "maintenance driver" install, if prompted
  • Close cover.
  • Power cycle printer.
This will:
  • reset the toner light (stop blinking)
  • restore the printing darkness (when toner light flashes, printer prints lighter to save toner)
  • keeps the printed page counts and drum life info
on Mar 06, 2011 | Brother HL 2140 Laser Printer
I recently installed the Brother HL-2140 to my computer, everything came through, but I am not able to print. Rose
Set your new HL-2140 as the default printer. Go to Control Panel, Click Printers and Scanners tab, and set your Brother HL-2140 as your default printer. You may have other printer as the default printer currently. Check your connections again. Connect it to another USB port as the current port might not be responding due to connection contact problem.
Oct 05, 2010 | Brother HL 2140 Laser Printer
Printer not printing documents HL-2140 model
when the toner light is on this means the toner cartridge is empty and ned to be replaced. After its replaced it will start working normally again.
Jun 02, 2010 | Brother HL 2140 Laser Printer
I have a new Hl 2140 and haven´t printed more than 100 copys but now the toner light is on and the printer refuses to print
Tip the toner cartridge from end to end to redistribute the toner. You will get more mileage out of it, if it is simply a low toner issue.
Apr 21, 2010 | Brother HL 2140 Laser Printer
Brother HL 2140 printer very slow printing.
It sounds like you haven't completely removed the old print driver. To do so, you must take the following steps:
  1. Open Printers by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
  2. Right-click the printer that you want to remove, and then click Delete.
    If you can't delete the printer, right-click it again, click Run as administrator, and then click Delete. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Another way or removing the printer driver is this:
1. Delete the printer from control panel -> printers
2. Open Services.msc and stop and start the Print Spooler service
3. Open Print Management(Open command prompt, type in printmanagement.msc or type print management in to the start menu search box)
4. In Custom Filters -> All Drivers right click the printer driver you want to remove and select Remove Driver Package
5. Install new printer driver.
Now that you've removed the printer driver, you can go ahead and manually install the new printer driver.
To manually install you must follow the prompts carefully.
Follow the instructions in this link:
http://www.vista4beginners.com/How-to-install-local-printer
At the install the printer driver section, choose have disk and locate the printer driver that you want to be associated with this printer you are installing.
This should solve your problem.
Mar 24, 2010 | Brother HL 2140 Laser Printer
HL 2140 does not print
This is a common problem to your brother printer model 2140. You need to turn off your printer and take out the toner. Look for the side and you will see a small hole on both sides. This is the sensor. You need to cover it with electrical tape.
Here is a detailed video on how to do it:
http://www.youtube.com/watch?v=hPCGZZIdXyM
Good luck and hope this helps you.
Sep 30, 2009 | Brother HL 2140 Laser Printer
Hl-2140 noises
For a possible fix to the Brother HL-2140 squeal/squeak/noise problem open the printer at the other side from the paper tray and toner cartridge door. You should see a little black roller rod along with some white wheels.
The noise may be coming from the contact between the wheels/rollers which pull paper toward the output tray on top after it has been printed.
Check and clean/wipe the wheels and black rod, especially in the center area. Hopefully the noise will now be reduced/eliminated.
Cheers, Stephen
Sep 14, 2009 | Brother HL 2140 Laser Printer
Can i print envelopes addresses on brother HL 2140 laser printers
The manual by-pass slot just below the brother name on the front allows a user to load envelopes just put the envelope in the slot and adjust the size.by closing the two grey tabs
Nov 25, 2008 | Brother HL 2140 Laser Printer
20 people viewed this question
k24674
jasbo
jasbo
