Question about Brother MFC-9440CN Laser Printer
My Brother MFC-9440CN is printing orange instead of red. I have replaced the magenta cartridge and the drum assembly (I suspect it would have been due for a change anyway) with no success. The old magenta cartridge was leaking toner causing a streak down the side of the paper - the new one fixes that but both cartridges print orange instead red. I am guessing the the toner leak from the old cartridge may be affecting the laser mirrors but have not been able to find any information on a DIY way to clean the mirrors. Do I need to take it in for service?
  • lhoagland Mar 31, 2011
    The problem is solved. I eventually replaced the black toner cartridge even though it was printing black fine and for some reason the problem went away. I don't know if that was coincidence or not, but the problem is gone.
SOURCE: Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Posted on Sep 26, 2008
  • 4 Answers
SOURCE: Magenta streak running length of paper
Have you tried cleaning the corona wire?  You can also use a cotton swab and clean the drum.  Just be sure to unplug the unit from the wall and allow everything to cool down.
Posted on Dec 02, 2008
cns assoc
  • 677 Answers
SOURCE: have a MFC-240C used INNOJET compatible
Brother Genuine Cartirdges????
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 05, 2010
Testimonial: "thank you very much still pretty much a beginner at all this greatly appreciate someone being so helpful to a stranger "
mariolands
  • 2296 Answers
SOURCE: Brother MFC-9440CN Laser Printer is
If you want to reset your Brother MFC 9440N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 9440N should be reset and the Toner End of Life message should disappear. Warning, this may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Posted on Nov 11, 2010
  • 2246 Answers
SOURCE: My Brother MFC 9440CN has been leaking toner onto
buy new printer
Posted on Jan 04, 2011
My Brother mfc 9440cn is printing a ghost image. how do you fix this?
The most common remedy is to clean the drum unit, but you have replaced that. Try cleaning the corona wires, p144 here
http://www.manualsprinter.com/manuals/brother/Brother_MFC-9440CN.pdf
Jan 11, 2015 | Brother MFC-9440CN Laser Printer
The printer is low on cyan and magenta toner. However, I only need the black ink. How can I still print?
change the black cartridge if need be and program printer to only print black using printer/devices preferences tab. try.
Aug 18, 2013 | Brother MFC-9440CN Laser Printer
I just put in a new toner cartridge and it still prompted me to add a new one, it was still printing so i kept going. But now it's saying that the cartridge is empty and refuses to print any more. I've...
When you replace the Drum cartridge with a new one, you need to reset the drum cartridge counter by using the following steps:
  1. Turn the the machine's power switch back on.
  2. Press Menu > Machine Info. > Reset Menu.
  3. Press the Up or Down Arrow key to choose Drum.
  4. Press OK.
  5. Press 1 to reset the drum unit counter.
  6. Press Stop/Exit.
This will reset the counter and will see the toner cartridge as new..(if in the menu it is available toner reset instead of drum ..choose that one )
Mar 16, 2011 | Brother MFC-9440CN Laser Printer
My mfc-9440cn prints a black line on the rigth side do you know what could that be? maybe needs new drum?
Hi there !
If you are self refilling the toner cartridge, the roller drum can be damage due to wear and tear. I need to replace new toner cartridge other i will getting wider and wider on both left and right of the paper.
Jan 13, 2011 | Brother MFC-9440CN Laser Printer
I have a Brother MFC-9440CN. It has been sitting for a while and when I print the right side of the paper has a lot of specks. How do I clean the inside of the maching.
In the users manual, it has directions on how to run a cleaning sheet. Do this 5 times. If it does not correct the error, open the machine, remove the cartridges and inspect the carts and the drum unit for excessive toner. If one of the carts is leaking, replace it and run the clean procedure. If the carts are clean, the drum unit needs to be CAREFULLY blown off with deionized compressed air set to 35 psi.
Sep 29, 2010 | Brother MFC-9440CN Laser Printer
How do I set Brother 9440 MFC to print using black cartridge only?
You can set the MFC-9440CN to print with the black toner cartridge only through the printer drivers.
If you are using Mac, this needs to be changed before you print or set a preset.
If you are using windows, follow the below steps.
1. Go to Start menu \ Control Panel \ Printers (devices and printers for windows 7)
2. Right click on the MFC-9440CN and select "printing preferences"
3. Under the "basic" tab, you will see "color mode"; simply select "mono"
Thank you,
Mar 28, 2010 | Brother MFC-9440CN Laser Printer
Magenta Dots vertically on Left margin of page
That is referred to as a repeating defect...most likely caused by a defect on the magenta drum unit. Here is a link for information on how to repair this problem:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000016/faq000216_016.html?reg=us&c=us&lang=en&prod=mfc9440cn_all&Cat=3
Jan 17, 2009 | Brother MFC-9440CN Laser Printer
Replacing Toner
Sep 07, 2008 | Brother MFC-9440CN Laser Printer
Brother MFC-9440CN Laser Printer Logo
237 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
