Question about Whirlpool Washing Machines
Does anyone know where I can find a tub seal for a front load Whirlpool washer?? It's a 50 100 13.5 mm.
  • norm2246 Mar 31, 2011
    Thank you for the info.....but the seal I need is in the center of the rear tub in front of the main bearings. The seal is removable as well as the bearings. I have found bearings at Bearing Headquarters for $12, but the seal seems to be an issue. It's a 50 100 13.5 mm. The parts stores offer the rear drum complete only. Someone makes this seal for them.....just have to find whom it is???????
    Sergeant:
  • 192 Answers
Norm,
I am posting two links you can click to take you to a parts site.
1.
http://www.partstap.com/browsebytype.aspx?part_id=3128710&viewall=48&cat=48&rdr=%2Fbrowsebytype.aspx%3Fviewall%3D48%26cat%3D48
2.
http://www.appliancepartspros.com/Appliance-Parts/Washer-Parts/Whirlpool-Duet-Washer-Parts/index.aspx
You can select your model or part number on this site.
Please let me know if this has helped or if I can assist you any further.
Thanks
Posted on Mar 30, 2011
  • Whispis2
    Whispis2 Mar 31, 2011
    Part number 481946818343
    From this diagram.http://www.scribd.com/doc/44697945/Whirl...
    If not let me know and i will keep looking.
    Copy and paste to see if this is it...http://www.atelitalia.com/eng/itacatalog...
  • Whispis2
    Found more herehttp://www.atelitalia.com/eng/itacatalog...
Does anyone know the rear bearings (2) and seal numbers for the drum? I have to replace them (along with the drum seal) like so many other have had to. I have the GHW9250MTO
Rear tub is 8181666 - subs to w10208156. It will come with a new tub seal.
If it has gotten really bad, you may want to aslo replace the basket, part number 8181668 - subs to W10269756
May 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My plastic drum seal on my Whirlpool duet front-loading washer is chipping apart. The drum doesn't run true, is wobbly and has a rhythmic rub when turning. How do I replace the drum seal? Model GHW9100LW.
You have more serious problem than just your drum seal. The support arms in the wash tub are broken. The wash tub should always spin true. When it wobbles it is a sure sign that the suport arms or spider arms are broken. It is an expensive repair since the wash drum, the outer plastic tub and the door seal need to be replaced. Check your warranty, to see if some of these repairs can be covered. Get a few estimates before deciding whether to repair or replace it. Sorry.
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Replacement: tub seal bellow/Whirpool Duet mod.#GHW9150PWO
Hi
Thanks for using FixYa. You can buy the tub seal bellow for your Whirlpool Duet from this link. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to remove bearing from rear tub?
BIG JOB!!!!
You have to completely remove the entire tub assembly to change this out.
This is the biggest and time consuming jobs to do on front load washers.
No easy way to do but to pull the entire unit apart.
Sep 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool GHW9100LW1 washer stopped working
be sure that the tub is moving around with out the outer tub moving....could be a motor controller problem.....but heres the part#s tub assembly#8181912 youll want to replace the seal too. seal#8181673
Jun 12, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Leaking bellow for duet washer
Whirlpool sells a product called Silco-seal it is a high temperature adhesive for sealing tub hoses to tubs this can be purchased at an appliance store it sometimes works to seal a tear or, hole in a bellows
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Duet Whirlpool Front Load washer on the spin cycle it make a clanking sound and is now dripping waster from the bottom of machine.
your pump is going bad.the water is leaking from pump or rubber door boot that connects to tub and wher door shuts,check for tear in boot.
Mar 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader washer
Mold and bacteria in your door seal is a symptom of problems deeper inside the unit. All washers - not just Whirlpool, have this problem. The area of worst buildup is always on the inside of the plastic outer tub just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this problem area add 1 or 2 caps of smelly washer cleaner to a full load of laundry. The added bulk of the laundry will raise the water level to include the "splash area". Intermittently pause to soak more extreme cases.
Aug 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
386 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
