Question about Vacuums
My Hinari vapore steam generator IR320SG has a problem of 'auto off' light keep brinking non-stop although the iron itself is hot.W hen I press the steam generating button it 'beep beep' sound. A new filter has been replaced and all the hot plate was cleaned. Problem still presist....where can i get the right tool for unscrew this iron if i need to? I noticed that the screws of this Iron are so small and in sort of star or flower shape!!
  • 2976 Answers
SOURCE: I was getting ready to iron a pair of pants that
First, UNPLUG THE IRON. DO THIS PART COLD. Clean the soleplate with scotch brite and WD-40. Next, you will have to remove the WD-40 residue from the soleplate with something like windex. Make sure you get around the steam holes.
Next-Plug it in and fill it with 50-50 mix of water and white vinegar. Set it for steam and let it run through. Refill it with plain water and steam it out again, until there is NO VINEGAR SMELL. This will clean the deposits out of the tank and steam vents.
Posted on Jul 06, 2010
  • 113 Answers
SOURCE: I cannot find anywhere to
If you can't find it ever, you can use bottled drinking water. Don't use purified water it is so pure that it can be a little aggressive on some metals. Just use RO or drinking water from your local store.
Posted on Sep 20, 2010
dogsled48195
  • 411 Answers
SOURCE: POWERFULL TEFAL PRO EXPRESS 2911
strait vinager fill it to full let sit over night then empty
Posted on Feb 16, 2011
reyjoshua07
  • 1157 Answers
SOURCE: shark iron; when you turn
Hi Sicnoramoore,
If your having problem with your shark iron and it leaks drops of water while ironing, it might be the water holding tank has a crack. Here are some steps that you may apply to check what's causing the leak issue.
1. Check the water. If you put wrong water it will cause the iron to spit the water out. So try to use good spring water or bottled water. Also make sure that the iron is empty before storage.
2. Check the two front screws ( they are hidden ). The two screws are holding the tank to the base. Sometimes iron developed a crack caused by tightening the screws.
--> if the unit has crack, I will recommend to call the manufacturer if warranty is up to have it be repaired for free.
Hope it helps.
Thank you for using FixYa.
Posted on Mar 23, 2011
  • 12 Answers
SOURCE: often when ironing, the iron{tefal
Try using CLR cleaner, if not just buy a new one, and keep the receipt for a return down the road, these iron's are reasonable nowadays.
Posted on Apr 25, 2011
I have a GENER8 steam mop i can not get it to steam it get hot but no steam, i have cleaned out the bottom foot but nothing can you help
There is probably a blockage preventing water from entering the steam generator.
Mostly with domestic steam equipment the water gravity feeds and it doesn't need much to stop the flow - often just a collapsed tube or a wayward blob of sealer.
Unfortunately to find the culprit the appliance will probably need partially dismantling.
Sep 23, 2016 | Vacuums
I need operating manual for vapor white wing steamer
This is from an Amazon review. I have misplaced my manual and was searching for a pdf file without any luck. I think I have it under control if I only knew where to put my distilled water.Basic operation of the WhiteWing is:
1. Fill the tank with distilled water
2. Attach the hose to the steamer.
3. Attach the extension handles and attachment you want.(Be sure to watch the video and read the instruction booklet. Some of the attachments have specific uses and setup instructions)
4. Lock the finger trigger.
5. Plug it in.
6. Turn it on.
7. Wait 20 min. or until the pressure gauge reads between 3.5-4.5.
8. Get ready to rock - press the steam release button, unlock the finger trigger and start steaming.
For many jobs such as countertops, shower stalls, stovetops, you will need to follow behind the steam, wiping with a cloth to remove the released dirt from the surface. Some jobs may require you to start with a non-toxic cleaner or grease remover such as Orange Clean or Method brand cleaners. Remember, you'll be breathing in vaporized cleaner. So be sure it's something non-toxic and non-irritating. I prefer the Method brand cleaners.
Jun 20, 2012 | Vapor WhiteWing Steamer Canister Vacuum
Often when ironing, the iron{tefal aquaspeed 160] will spit dirty water on whatever I'm ironing.are you supposed to use botled water in iron?Aren't tefal irons made for tap water?Also how do you stop iron...
Apr 25, 2011 | Vacuums
I am looking for a cap for my tefal pressing profile steam generator iron model 2880 can you help
Did anyone help you with this? Did you find - I also need one!
Sep 27, 2010 | Vacuums
Theres water pouring out of my t fal iron's little holes when I begin to iron my shirt...why!
The iron needs to be cleaned as I have just discovered myself. I have a hinari and the instructions are as follows. Fill the water tank and turn the iron on to medium. When heated press the steam button and hold it over the sink or a container so that the water can run out of it. It will take sediments with it. The cleaning of the iron should be carried out once a month.
I experienced the same trouble and carried out the instructions and all is well again.
Jun 28, 2010 | Vacuums
Does not give steam.
Actually there was no category for clothes steamer, and before entering information I was prompted to pick a category so I chose vacuums hoping that when my problem was diagnosed it would be understood that the problem is a clothes steamer that has stopped giving off steam. Please help if you can. I appreciated your time.
May 20, 2009 | Westinghouse Vacuums
Prolectrix 3 tier steam
Is the unit spraying ok? If not then the heater may be plugged. Other than that, you should fill the tank with hot tap water, the the heater will only heat it alittle more, you won't really see steam.
Jan 19, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
74 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
