Question about ASUS A6J Notebook
Hi one of my notebook asus a6j chipset was removed by someone an this chipset placed under realtek chipset and i think its related to keyboard do you know what chipset it is?
  • reza_sammy Mar 31, 2011
    thank you all. but i want some pic from asus a6j nootbook mainboard to understand the removed chipset what is it and i can fix that problem.
  • 122 Answers
Hello, i think you need to put more clear note to these.
Posted on Mar 30, 2011
  • ONYEKACHI OKEREKE
    ONYEKACHI OKEREKE Mar 30, 2011
  • ASUS Master
  • 3,287 Answers
The ASUS AJ6 makes use of a Realtek Driver for HD Audio.
It is not likely that someone "removed your chipset" from the notebook. The "chipset" is soldered to the motherboard and is not under any circumstances "easily" removed. The motherboard is designed around the chipset, so even if it were removed the exact same type would need to go back in. This just isn't done. The chipset provides support to allow the CPU, memory, audio and all the hardware inside the notebook to work together.
If the hardware is being reported as something other than what is expected for an A6J, or is being reported as something OTHER than an A6J (meaning the model number on the case doesn't match that which is being reported when checked or scanned); more than likely the motherboard was changed to one that is used in a notebook model one or two up or down from your A6J.
You can read a review for the A6J notebook here along with viewing the hardware specs. I hope this helps and good luck. Please rate my reply. Thank you.
Testimonial: " i did not mean you did not help me but in my first question i said: placed under realtek chipset in mainboard "
  • Steve Mar 31, 2011
    I'm sure no one "removed" your chipset. If you wanted a picture - why didn't you simply ASK for that - instead of asking about a Realtek chipset - which I answered for you. You "thanked me" for my effort with a "not very helpful" rating. If you can't articulate what you really want - and people correctly answer the question you asked - only to have you indicate they ANSWERED wrong - no one is going to want to help you. The simple fact is, you asked the wrong question and got the right answer to THAT question. I still am not sure what you're looking for - but good luck to you anyway.
  • Steve Apr 02, 2011
    reza_sammy. Let's try this again, but from the beginning. I know you haven't got the information that you're looking for yet, and I really want to help you out. Do you think that someone opened the case of your notebook and physically removed components from your motherboard and replaced them (that's the way your original question reads to me)? Are you looking for DRIVERS for your chipset? Have you looked here: "http://tinyurl.com/3chrdnt"
Is there are realtek audio driver for asus p5kpl cm motherboard???
Let's go to Asus Support, and see;
http://www.asus.com/Motherboards/Intel_Socket_775/P5KPLCM/#specifications
Audio -> VIA VT1708B / 8-Channel High Definition Audio CODEC
It's a VIA audio chipset.
The answer is NO
[ Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
Driver. Sort for Device driver
Driver: A small piece of software that allows the Operating System to communicate with a device.
The device is the audio chipset.
You didn't state what O/S you are using.
Drivers are written for devices by the device manufacturer, when specifically referring to an audio chipset.
What would make you think it should have a Realtek audio chipset?
Post back in a Comment.
Regards,
joecoolvette
Oct 26, 2012 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
My asus a6j when i insert a cd to install windows, it gives a black screen after the choose of the boot menu and still there black!
You'll need to make sure you have the BIOS set to boot from the CD. When you first power up, there will be a prompt to press a key (usually the F2, DEL, or similar) to enter the BIOS. Once in the BIOS, you can change the "Boot Order" so that the CD drive is first, then the hard drive, etc.
If that doesn't take care of it, you may have a problem with the CD drive or the CD itself.
Hope that's helpful.
Jan 06, 2011 | ASUS A6J Notebook
Hello How do I remove the keyboard from an Asus A6J A6000 entertainment notebook? Thankyou
1. Place your laptop on a clean, flat surface and remove all power sources from it. Open your laptop screen as far as you can.
2. Use the flathead screwdriver to pop open the hinge cover. Slowly and carefully pry it open from the right side to the left side, exposing the keyboard screws. Using the Phillips screwdriver, remove the screws that hold the Asus A6J Keyboard in place. Keep these screws in a safe place.
3. Gently tug the Asus A6J Keyboard component toward your laptop display. You are trying to pull it out of the slot that is located near the palm rest and mouse pad. It doesn't take much force, but you must be firm. Once you have pulled it out of the slot, you can lift it up and remove it from your laptop.
4. Take the replacement keyboard and slide it into the slot. Once in place, screw it into place with the Phillips screwdriver and the screws you removed in Step 2. Fit the hinge cover back into place by snapping it in from left to right. Power on your laptop and verify that the Asus A6J Keyboard is working.
Dec 11, 2010 | ASUS A6J Notebook
How do I replace the cmos battery in a ASUS Eee PC 900AH?
i think the cmos battery is under the keyboard. if it is there should be two screws under the laptop that will have the simbol of a keyboard, remove these and take out the keyboard. hope this helps
Jul 20, 2010 | ASUS Eee PC 900 PC Notebook
How do I dissasembale Asus A6J laptop
Short of doing it for you, I would suggest to get a clean area to work on, a place to put all your screws that you will be removing... ideally a tray or drawer for every set of screws. Get yourself a good digital camera to record your process. This helps when you want to rebuild your system back. Above all, work slowly and paying close attention to every step that you take. I can't stress it enough to document your work, you can get lost very quickly doing this. I do this all the time, I have notes, but not for this particular laptop. I would start you off by removing the bezel that covers the power buttons, Normally I would work from right to left, gently prying up the bezel with a small screw driver. The exposed screws will remove the keyboard, be careful of the ribbon that attaches the k/b to the motherboard. You will work your way down to the system, but I would start cleaning the keyboard first. Good luck to you. Keep us updated. -Carlos:
Jun 15, 2009 | ASUS A6J Notebook
No windows xp
You will have to reformat it again. its likely a bad sector has been created on the hard disk, and windows file is probably occupying the bad sector. Try to reformat your hard drive. If that doesn't work, try to reformat it with windows 98 bootable disk. If it doesn't work, get another hard drive and test to see if it will work. If that works, then know you may have lost the MBR (Master boot Record) of your hard drive.
Apr 14, 2009 | ASUS A6J Notebook
Asus a6000 keyboard
Keyboards are most generally held by screws in one of two places. 1- On the bottom, could be marked with a K, With bottom screws, the keyboard may have tabs on it holding it, you will need to pry the tabs gently out away from the plastics. 2- towards the top of the keyboard under the power button strip. Try this link, you may be able to find a breakdown diagram for your machine there.
http://repair4laptop.org/notebook.html
Don't be afraid to remove all the screws on the bottom of the machine if you're unsure as to which are for the keyboard, it won't hurt anything as long as you get them all back in. If they're marked with a B, it's a motherboard screw, and P is for plastic casing.
Jun 30, 2008 | ASUS A6U Notebook
ASUS L3500 Keyboard
you remove that using screw driver and be careful to remove the casing be sure the lack is open from the case...or you just get a manual and follow the step to open the casing.....
Dec 10, 2007 | ASUS L3 L3562 Notebook
ASUS A6J Notebook Logo
112 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
