Question about Britax Boulevard
I can't get my base to click into the upright position. It is stuck in the recline position. I am trying to find a diagram of the inside of the base as I have removed the cover on the base.
Ring 01264333343 and ask for customer services. They should be able to help
Posted on Mar 30, 2011
I have a new Bissell Powerglide 1305 vacuum. It is red. I took the thing apart screw by screw to clean it inside out after my son decided to vacuum out the fireplace ash. However, once I put it back...
Knowing a little of how mechanical things are designed I would guess that when you took it apart you didn't notice exactly how the mechanism was set up that triggers the reclining feature. I would take it apart again. Then canalize how the reclining mechanism should work. It's probably to pieces that are not fastened together but are only held by positioning on assembly.
Feb 10, 2015 | Bissell Vacuums
My Dyson DC25 animal won't recline more than a few inches back from the upright position.
Check out the casting on the right hand side there is a squire plastic moveable part that engages the clutch if it get stuck it stops the Hoover from letting the handle drop all the way try lifting it up into the right position and try again
Nov 03, 2014 | Vacuums
How to put the Dyson Vacuum Cleaner out of the upright position?
Hi there, it's Jack at Dyson.
To recline your DC33 into the normal vacuuming position, place one foot on the cleaner held and recline the main body. After use, just stand the vacuum upright and it will lock in position until you recline it again.
I hope this answers your question. If you'd like any further help or advice, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 13, 2014 | Dyson DC33 Multi-Floor Upright Vacuum...
My vacuum is stuck in upright position
It's frustrating, but it's a common mix of vague documentation and un-obvious operation for a lot of Dyson uprights. Per the manual (
https://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc27_uk_manual_alf_120710%20pdf.pdf ), look at page 4, you put your foot on the base of the unit and pull back with conviction on the handle. It should move. If it's feeling really iffy, make sure that the hose assembly is fully clicked into the base.
Be aware that the brush bar won't spin until the unit is reclined. This is a common feature in Dysons, since this is the position where it re-routes the suction into the handle for use of accessory heads.
Good Luck!
Jul 07, 2014 | Dyson DC27 Bagless Upright Vacuum
Pontiac g6 seat recline lever won't work anymore
remove seat(s) and check for obstruction in the mechanism path. You'll need a big Torx bit.
Mar 22, 2014 | 2007 Pontiac G6
Brush roller will not rotate on Dyson dc04 absolute
The brush will not rotate when the machine is upright. The brush only rotates when it is reclined; in use.
On the side of the housing where you place your foot to recline it is a round knob. Turn it one click clockwise if you can; to the "auto" position.
If the brush doesn't turn then when the machine is reclined, it needs attention to the belt and/or clutch mechanism.
Jan 13, 2011 | Dyson DC04 HEPA Bagless Upright Cyclonic...
My Oreck vacuum cleaner will only stay on in the upright position. If I try to recline it to vacuum, it shuts off...put it back up and it turns back on. Of course I can't vacuum in the upright...
it sound as if you have a short in the cord or it has come loose from the motor you can take it part by removing the four screws in the buttom of the base plate to see if any of the wires are loose.
Aug 27, 2010 | Oreck Vacuums
My maxi cosi tobi seat wont recline
Yes it seems to be a design fault. Has happened twice on our Tobi seat.
To fix, lay the seat on its back.
Locate the 3 Torx head screws middle front and rear left and right. You'll need a Torx screwdriver or head of the correct size. http://en.wikipedia.org/wiki/Torx
Undo the screws, then pop the four catches at each corner with a flat-head screwdriver and remove the base.
Look at the recline mechanism, you'll see large bar at the rear (both sides) which is meant to be there. At the front, on one side or the other, you'll see a smaller bar which is part of the hinge for the recline handle. It's slipped sideways and into one of the recline mechanism slots.
Jiggle the recline handle and push the hinge bar back into the centre. It might help to use gravity - lay the seat on its side with the blocking bar uppermost. I can't see a way to prevent this slipping out again over time.
Snap the base back on and replace the Torx screws.
Jan 03, 2010 | Baby Gear
Stuck in recline
I know this post is old but I figured somebody w/the same problem might come across this. I had the same problem with my Marathon today. I also own a Roundabout & had no problem changing the recline myself. When my husband came home he took a look & fixed it. All he did was put it in the upright postion , held it in place & turned the seat on it's side & pushed up on the base and it clicked! he pushed on one of the corners (but I don't know if that even matters)
Jan 05, 2008 | Britax Marathon
Britax Boulevard Logo
117 people viewed this question
Top Britax Baby Gear Experts
thegtw
CheckitRight
CheckitRight
Jennifer Rock
Jennifer Rock
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
