Question about Dewalt DW310K Heavy Duty Reciprocating Saw Kit
I have a Dewalt DW310 and the small piece on the end of blade broke off inside. How can I remove? Thank you Bruce
  • 710 Answers
There is a small screw on the right side by the shoe assembly that should allow you to remove it so you can get to the piece broken off. There is also a C-clip that you might have to remove also.
I hope this helps. If it does, I would appreciate a vote or comment. Thanks,
Handie Andie
Posted on Mar 30, 2011
  • brucegus96 Mar 30, 2011
    After using a magnifier I seen that it has a spring roll pin that holds chuck on. I used a punch of proper size and it came right out allowing me to remove broken piece of blade.
    Thanks so much for you time and suggestion.
    Bruce
A piece of a broken blade is stuck here the blade fits into the saw (Dewalt DW 303m). How do I get it out?
Craig, a drop of penetrate oil and you will just have to work at it with ice pick.small screwdriver, or needle nose pliers if you can, make sure you have blade release depressed while trying to pry blade shank out. Once you get it moving it will fall out. Clean and blow out blade port before inserting another blade.
How to Remove Stuck Blade on Sawzall Hatchet eHow
Troubleshooting Your Malfunctioning Reciprocating Saw DoItYourself com
May 26, 2016 | Dewalt Saws
My dewalt planer dw735 just made a loud pop sound. Then, a piece of metal launched out of the dust ejector, a few sparks flew. I tool the top od and found a hunk of wood that broke of the board jamming the...
have you checked you have not taken a chunk out your blade. also you have to make sure the blades are set spot on. other wise it will affect the balance. good kuck
Dec 20, 2014 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
How do I get a broken blade out of Dewalt DC330?
Do the same procedure on how you installed the blade.
Sep 14, 2014 | Dewalt 18v 18 Volt Cordless Xrp Jig Saw...
50s 1
Remove the blade, and you will normally see a hole in a lug on the inner ring of the guard and a slot with a bar across it on the upper inside of the fixed guard. Either end of the spring will hook through these. Sometimes (normally on DeWalt) the springs will be attached with a small self tapping screw with a washer at either end.
Apr 25, 2013 | Saws
The blade broke off in my ridgid r3001.
Release the clamp as much as you can, spray with wd40 and either use something like a small piece of wire to free it or try banging it gently down against a piece of soft wood.
May 15, 2012 | Ridgid R3001
How do I remove a broken blade on a reciprocating saw? The blade broke off at the place where it attaches to the body. Unlocking the blade by the usual means doesn't free the small piece remaining in...
Sometimes if you take the set screw completely out and then use a flat blade small screw driver to wege open the throat you can use a dental pick to get it out. Spray it first with wd40.
Hope you weren't using those cheap blades from harbor freight - that is how I learned that trick - bought the dental picks from harbor freight.
Jun 20, 2011 | Dewalt DW303 Heavy Duty 65 Amp...
Is the Dewalt dw310 multi purpose saw available in 110 volts
  • Help Instructions, Repair Guides, Manuals & Troubleshooting sacore:green.gif Dewalt DW310K Heavy Duty Reciprocating Saw Kit... Is the Dewalt dw310 multi purpose saw available in 110 volts - posted in Reciprocating Saws ...
    www.fixya.com/troubleshoot
  • Jan 14, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
    I bought a Dewalt DW310 reciprocating saw and there seems to be no way to install a blade. The instructions show a wheel to turn to unlock the blade chuck but the wheel is up inside the saw body where you...
    The blade clamp collar is a spring loaded knob of sorts that holds the blade in place. If you are not able to pull the blade shaft out of the saw to get at it, plug the saw in and hit the on/off trigger a few times to get the shaft and knob out of the body of the saw. Once you can get at the knob it should be easy to turn it and insert a new blade. Let me know if you have problems.
    Aug 30, 2010 | Dewalt DW310K Heavy Duty Reciprocating Saw...
    How To Remove Blade Clip On dc305 Dewalt
    Should be able to loosten a small inside allen screw that becomes visible when aligned with a round hole in the tip assembly.
    Dec 16, 2009 | Dewalt DC305K Cordless Reciprocating Saws
    Dewalt DW310K Heavy Duty Reciprocating Saw Kit Logo
    335 people viewed this question
    Top Dewalt Saws Experts
    JOHN LAPIER
    ken skalski
    Are you a Dewalt Saw Expert? Answer questions, earn points and help others
