After loging on my computer, it shows me that to put in a window xp proffessional service park 2...and i put in my disk drive a window 2000 proffessional, and it showed me again that ( asms) is needed... plz i need help. thnx
  • 415 Answers
The service packs are available for upload via the internet "windows updates". Down on the "tray" at the lowest bottom left of your screen near the clock will be the shortcut for updates that will pop up when there are updates to install. Depending on how you have it set, "automatically" will install them when you aren't looking or "manual" which gives you the choice on when you install them but you have to do it.
Posted on Mar 30, 2011
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
DX4850 doesn't detect dvd drive. It doesnt show on "my computer"
Check to see if it is detected in "Device Manger"
  • Right Click "My Computer" > Properties
  • Click on the "Hardware" tab
  • Click Device Manager
  • Check to see if you shows any devices with yellow ! or ?
If you see nothing at all for a CD/DVD drive then it's mostly just bad and needs to be replaced. Press easy replacement. Here is a tutorial. I would rate it a 2 out of 10 for difficulty. http://www.ehow.com/how_4814466_replace-computer-dvd-drive.html
Comment back if you need further assistance. Thanks!
Aug 12, 2011 | Gateway Dx4850-45 Desktop Pc
I have 1 note book LG X120 with windows 7. when im trying to install Windows XP proffessional through a USB CD ROM its showing the following Message * To specify additional SCSI adapters, CD-ROM...
Hi lionking2022!
Since this is a USB CD_ROM, you need change some settings in the bios for it to be detected and the system will actually boot from it.
1. You enter your BIOS
2. Look for the tab that will contain IDE settings
3. Change it to AHCI
4. Save and Exit
You may know try to boot from cd-rom and install your windows xp.
After the setup or installation is finished don't forget to changed it back to SATA or whatever the setting was.
Hope this will help.
Thank you for using Fixya,
avf110686
Mar 24, 2011 | AGPtek USB External CDROM Drive For LG...
My drive is brand new, unused, when I click on the Start button, then Computer, I see the newly attached iomega drive as a CD Drive. so far so good. But when I RIGHT click on the iomega drive, chose...
As long as it is just the USB 3.0 and not the USB 3.0 with encryption. You will just need to format your drive.
Windows 7 / Vista 1. Connect the Iomega Hard Drive to the USB on the computer. 2. Next, open Disk Management. (Right click on the Computer icon > select Manage > click Storage > select Disk Management ) 3. You will see a prompt indicating you must initialize a disk before Logical Disk Manager can access it. The disk will be selected by default. Read the note at the bottom of the window and select the partition style you want to use. 4. Click OK. 5. The drive will now appear as Unallocated and the bar will be black. Right click on the black bar and select New Simple Volume. 6. When the New Simple Volume Wizard opens, click Next. 7. It is recommended to leave the maximum disk space selected. Click Next. 8. Assign the next drive letter available. (It is recommended that physical drives are placed before mapped network drives.) Click Next. 9. Windows will automatically select NTFS as the volume format. This is the preferred file system for use with Windows 7, Vista, and XP. 10. Select the option for Perform a quick format, enter a volume label if desired, and click Next, then click Finish. The drive will be ready to use when the format completes.
Windows XP / 2000 1. Connect the Iomega Hard Drive to the USB on the computer. 2. Next, open Windows Disk Management. (Right click on My Computer > select Manage > click on Disk Management ) 3. If the Disk Wizard opens, click Next. Select the disk, click Next, then Finish. If the Wizard does not open, locate the drive in the lower list. Look for a disk that does not show a drive letter or file system. CAUTION! Make sure you select the correct drive before proceeding. The following steps will erase all information from the selected drive. 4. Right click on the drive name and select Initialize Disk (Windows XP) or Write Signature (Windows 2000), then click OK. NOTE: If the options listed above are not available, you might need to delete the primary partition. 5. The drive will now appear as Unallocated and the bar will be black. Right click on the black bar and select New Partition (Windows XP) or Create Partition (Windows 2000). 6. When the Create Partition Wizard opens, click Next. 7. Verify that the partition type is Primary partition and click Next. 8. It is recommended to leave the maximum disk space selected. Click Next. 9. Assign the next drive letter available. (It is recommended that physical drives are placed before mapped network drives.) Click Next. 10. Select the option for Perform a quick format, click Next, then click Finish.
Nov 25, 2010 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
Can't get into any folder because c:Windows/System 32/rundll32 .exe keep popin up
To resolve this issue, follow these steps:
1.
Put the Windows XP CD ROM disk in the CD ROM drive.
2.
Click Start , and then click Run .
3.
Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4.
Restart the computer
2.
3.
4.
1) Put the Windows XP CD ROM disk in the CD ROM drive.
2) Click Start , and then click Run .
3) Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4) Restart the computer.
Oct 27, 2010 | Computers & Internet
Sir my pen drive is not showing in windows xp .\r\...
Try this,
1. Click Start, click Run, type compmgmt.msc, and then click OK.
2. On the console tree, click Disk Management. The Disk Management window will appear.
3. On this disk management window, you can see some drives including the portable drive. Right
click on your portable drive and click change drive letter and paths.
4. Then a assign a new drive letter which is not being used by any of your drives in My Computer.
5. Finish assigning the new drive letter your portable drive will show up in my computer with
other drives
Hope it works for you
May 20, 2010 | Microsoft Windows XP Professional With...
When we formatting the drive it shows unknown capacity
The partition table is most likely set up wrong.
plug it into your computer, right click on my computer and select manage.
On the left side on the computer management window, select disk management.
Find the removeable disk which is the usb stick, right click on the area on the right of that disk, select Delete partition, delete all the partitions from that drive, noting else. then finaly, create new partition, fat or fat32 as big as possible, and format it.
This may need a windows 2000 computer since I've had problems in fixing it on windows xp and vistam but 2000 seems to be able to do the job.
if all fails, contact your dealer or the company for service or buy a new drive.
Jul 09, 2009 | Kingston Technologies 512MB DataTraveler I...
NTLDR missing on changing harddisk connection
put the xp bootable disk in computer and boot from it, choose repair option. it will slove your problem.
Feb 24, 2009 | Microsoft Windows XP Professional With...
Help
Yes you can install another windows on it here are instructions for windows XP they are almost the same for just about all versions of windows past windows 2000.
  1. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  2. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  3. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  4. Read the Microsoft Software License Terms, and then press F8.
  5. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  6. Follow the instructions on the screen to complete the Windows XP Setup.
Jan 18, 2009 | Dell OptiPlex GX150 PC Desktop
I need to up grade my windows 2000 to windows xp
First you need to make sure that your computer meets the following specifications:
- 300 MHz (or higher processor)
- Intel Pentium/Celeron or AMD K6/Athlon/Duron compatible processor.
- 128 MB of RAM (or higher)
- 1.5 Gigabytes of available hard disk space
- Super VGA (800 x 600) or higher resolution video adapter and monitor.
I am sure that your computer likely meets all of these requirements, but I posted them to save you the grief if by chance it does not meet one of the above!
In a moment I will post a link to a website where you can purchase an upgrade to Microsoft Windows XP home edition (Service Pack 2).
Once you have the software, start up windows 2000 and place the disk into the CDROM drive. You should be given an option to upgrade to XP. (make sure you start the disk while you are on the Windows 2000 desktop with all programs closed). After XP is installed if your computer does not have an Antivirus program installed, I strongly recommend either installing Norton Antivirus or AVG. AVG is free and can be downloaded from http://www.avg.com/. Then make sure that your windows firewall is turned on. (It should be automatically) After this go to Microsoft.com and download service pack 3 and any additional updates needed.
The upgrade version of Windows XP home with service pack 2 can be purchased from newegg.com by clicking on this link: http://www.newegg.com/Product/Product.aspx?Item=N82E16837116194.
I hope that this information has been helpful to you. Please let me know if you have any other questions!
Sep 20, 2008 | Gateway Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
