Question about Casio Keyboard Power Adapter
I have one key out of tune. I wonder, could the problem be a bad power supply?
  • Casio Master
  • 5,603 Answers
In a word, NO. We have no idea which keyboard you have. If the pitch is off that is HIGHLY unlikely. A common problem however is a dirty key contact causing a note to be very loud as if hit hard and fast. The contacts are conductive rubber and require disassembly and cleaaning the rubber pills and the circuit traces they contact with ONLY 99% isoprophyl alcohol and Q tips. There are two per key to measure velocity.
Posted on Mar 30, 2011
Roland BK-3 is in Key of D even after factory reset. How do I tune it to C without changing the key setting?
What brand and model Keyboard is it??????
For the sake of brevity, try powering down. Then, power up holding the last note on the keyboard, Some models use this as a factory reset feature, but then again you haven't mentioned the brand or model...
May 26, 2015 | Music
Power switch for Casio key board not switching
Without knowing the model, age of the keyboard if it is moved a lot, etc it's hard to say. Most common problems are damaged power jack(or cracked trace on the supply board near the jack ), bad AC adapter, bad power supply board(shorted semiconductor, regulator, etc ) and rarely a bad power switch. You could try a new ac adapter but it might be a waste of money(if you have access to a multimeter check the output of the adapter before buying a new one).
Jan 02, 2015 | Music
I have a mackie thump that will not turn on. I was wondering why this is? I have bought a new adapter and the power cord is fine
Check power supply Mosfet's for cracked pins, check power supply coils for cracked pins also, that could be your issue.
Oct 13, 2013 | Music
Moving to Canada Korg M50 - 220V to110V ?
110 will not damage it, just will not work, if built in power supply should say on the rating plate next to power input the voltage it is able to take, a lot of units are rated 110-240v some will have a small switch to change over from 110 to 240. Other than that, you will need to get a step up unit to supply 240 from 110 just a small transformer unit.
Mar 06, 2013 | Korg M50 61-Key Music Workstation Keyboard...
I have a VOX NT15. When switched to Triode ( 7,5 W ) mode, my amp generates quite loud buzzing sound. The loudness of this sound is on the same level, no matter if the volume is switched to minimum or...
You LIKELY have a bad filter capacitor. The additional load of the Triode load is probably dragging the supply causing flattopping and the power supply ripple frequency to come through. Have the unit serviced.
Jul 26, 2011 | VOX Amplification Vox Night Train Amp Head
I've got a Adam A5X studio monitor. the problem is that fuse blows after about 15 sec. it works but you can hear background hum and the transformer gets very hot in 15 sec. then fuse blows. i wonder...
Transformers RARELY fail. It is likely that either one side of the amplifier has shorted or there is a failure in the rectifier/filter circuit of the power supply. Take it for repair unless you are adept at electronic repair. Do NOT continue to replace the fuse as you MAY cause futher damage. Use a 25 or 40 watt lamp in series with your power cord to limit current while troubleshooting.
Jul 05, 2011 | Adam Audio A5X Pair 2-way 5.5 inch...
Hi I got PMP3000 and all of a sudden in the program smoke came out of the unit and I unplugged the Mixer...I have given it to repair and they saying the Main power SMPS has blown out..they charging too...
Sorry... you likely have one of the power amp channels bad as well. One does NOT replace the power supply, instead repair it. You need a competent repair shop. I can tell you what parts are blown on the supply. They cost about $30 max for parts to repair the power supply. There usually is about $15 of parts blown on the amp that caused the problem and significant labor to repair the amp portion. If the smoke was dark or heavy, it was likely from the 0.03 ohm metering resistor on the bottom of the amp circuit board that caused the original problem. If one replaces the power supply and turns power on they will find one side of the amp doesn't work and MAY blow the power supply again immediately. I have repaired several of these units and have walked others through the repair sequence as well. You can contact me directly by email for more info if you need it. Unless you can find a competent repair shop that replaces components, including work on surface mounted boards, the cost of the module parts AND availability will preclude repair. The amp module is another $155 after the power supply is repaired if a channel is bad and one chooses to replace rather than repair.
Apr 19, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
I just got this guitar. I pull the tuner control, strum the string and after the guitar tune itself, the G string still out of tune??
Are you sure you are struming the G string at the right point? One might be able to fool the tuner by triggering a harmonic on the strings or being too aggressive in the strum.
I would pull the peg and see if the string CAN be tuned manually. It is possible the G string is bad or somebody put the wrong string on there.
Remember that strings can be within about 10% of the breaking tension when in tune.
Also it appears that the thing can detune itself to nearby keys. Make sure you have the dial set correct when you pull it out to tune.
Feb 05, 2010 | Gibson Robot SG Special LTD Ebony
No power is coming through to my CTK 611, bought a new power unit and this has made no difference
There is a chance that the jack that the power supply plugs into is broken loose or has bad solder joints to the circuit board. I am hoping that you purchased a direct replacement for the power supply.
Oct 29, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Casio Keyboard Power Adapter Logo
57 people viewed this question
Top Casio Music Experts
Ben Armstrong
Piyal Perera
Piyal Perera
Are you a Casio Music Expert? Answer questions, earn points and help others
