Question about Garden
The moter just cut out completely - Garden
    Problem Solver:
  • 4 Answers
Check your spark plug first
#2check your plug wire,, it will ground out against the cylinder and sometimes the spark plug wire will come out of the coil and you wont be able to tell unless you take the pull start off and if you still have no spark the coil is shot
Posted on Apr 01, 2011
Fiesta Mark 6 passenger window power to switch ok and power to moter ok goes up but will not come down when on the car . If you take out the moter and check it on a bench it goes up and down
When you bench it, the is no toque applied to the motor. That's why it works. There is a built in heat sink in them. Gets hot, cuts off. It takes more torque to push it up. Replace it. Might want to replace the regulator also.
Sep 18, 2016 | Cars & Trucks
Won't pump out water
remove the pump use an external jumper wire usually u can cut an extension and hook to terminal ends on it plug them into the pump then into the outlet to test the pump
May 03, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
1994 chevy s10 .. moter swapped to carburated and
Actually, I recommend putting an after-market ratchet shifter on the transmission. This sounds weird, but we purposely cut the TPS out of my TH350 for street / strip racing. A ratchet B&M shifter or something similar will work, but it makes destination driving (I.E groceries, family, etc) a bit more of a pain.
Nov 06, 2009 | 1994 Chevrolet S-10
Trimmer runs good but does not cut grass
I have had a similar problem with an edging attachment. The socket that fit onto the shaft was worn, and the shaft would just spin, creating a lot of heat right there, but very little movement, and it would completely stall when you tried to use it implement, even though the moter still ran just fine. The cure, I'm sorry to say, was to replace the implement.
Best regards, --W/D--
Aug 15, 2009 | Craftsman Convertible 25cc. Gas Line...
I have a Hotpoint WDM73 washer dryer, during a spin cycle the power cut out and it won't turn on again. Can you help please?
on a hotpoint the moter is three faze so if it is turning the power off this means that the moter could be damged between the windings u can get the moters off ebay from about 55 pounds
Jun 28, 2009 | Dryers
Driver side power window stuck when rolled completely down.
this is a regular problem with gm cars and trucks. you probably need a window lift moter.if the glass is lose and wigles in the frame. you need a window regulater with lift moter. good luck
Nov 08, 2008 | 1999 GMC Jimmy
Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Jul 07, 2008 | Stoves Premier 900GRa Gas Double Oven
Canon NP6050
The E510 is a sorter feed moter problem moter (M1) You can see if the sorter moter turnes if it does not,replace it
If you want a quick cure to get you copying disconnect the sorter remove the communications lead you have to remove the sorter completely and the copier will work.
Thank You
Mar 11, 2008 | Canon NP 6050 Copier
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
