Question about Bissell Vacuums
I recently had my vaccum "tuned up". Supposedly they checked it out, replaced the beater bar, but when I got it home there was almost no suction on the portion that swept the floor. Suction for the removable top part was great but somewhere bewteen the removable hand vac and the floor sweeping part it lost almost all suction. Any help you can suggest would be great! I took it back to the vacuum repair shop but since it could pick rice krispies off the floor they insisted that there was no problem. Uchk!
  • 794 Answers
Hi gbenintendi,
This issue might be caused by different factors. And I'll give you some basic checking and troubleshooting that you may try to do to address the issue of having a low or almost no suction on the lower part of your machine.
1. First thing, check the dirt cup to make sure it is empty.
2. Your vacuum has 3 filters. Check out for debris on the inner and outer circular filters in the filter cup and the post-motor filter on the front of the machine. Also don't forget to check the upper-tank louvers. They may be removed and rinsed. Dirty filters will restrict air flow. To clean the filters:
  • It can be hand washed in cold water with mild detergent. Make sure to
3. Consider also on checking for good suction at the end of the upholstery hose with handle. If there's good suction, ensure this end of the hose is firmly pressed into the lower hose outlet on the back of the vacuum. Also check to ensure the brush is rotating. If it is not, remove the plate on the bottom of the vacuum by the two tabs and check the belt and clean the roller of debris and dirt. If the lower hose is clogged, remove the hose with handle and clean this hose.
4. If there is NOT good suction at the end of the hose with handle, remove the hose by twisting it off the back of the machine and check for suction on the vacuum. If the suction power is good, check the hose for cracks or splits and using a broomstick handle, push any dirt or debris through the hose.
Your problem may be something as simple as a broken drive belt or a filled dirt container. If you continue to experience low suction with your vacuum, please take your machine to a local BISSELL Authorized Service Center.
Hope it helps.
Thank you for using Fixya.
Posted on Mar 30, 2011
My Dyson vaccum leaves a row of multiple lines on my plush carpet. I've never had s vaccum leave more than the two wheel lines. I called customer service and they had no solution for me!
It's the beater bar brush. Turn it over and use a screwdriver or knife, and run it the full width of the beater bar to remove the hair and string and other debris that get wound up on the beater bar-NOTE you do NOT have to remove the beater bar or take apart anything. As long as the beater bar spins, and there are no missing sections on the beater bar- this will work. Beater bar could also be worn down- be sure that the bristles extend past the bottom of the vacuum- ALWAYS DO THIS WITH THE POWER OFF
May 03, 2017 | Dyson Vacuums
Panasonic optiflow upright vaccum
Hello, Put the vac on its side and remove the screws holding the cover plate on. This exposes the beater bar and belt on the side. Pull the beater bar out and take the belt off. Reverse this to put the belt back in place.
May 30, 2014 | Panasonic MC-UG323 OptiFlow Upright Vacuum...
My vaccum is about 1 yr old and has very little suction, in addition the sweeper is not working
You probably have a broken belt on the beater bar (sweeper) or a string/rope caught in into to cause it not to turn. Last option if it is a cannister type, that the electrical connection in the hose are not connected to the beater-bar unit well.
If suction is bad, you may have a full bag (replace with a fresh one). Alternatively, you may have a clog somewhere along the hose or just inside the unit.
-Mark
Jul 16, 2011 | Vacuums
Caught fridge of a blanket in vaccum. Turned off and remove object. Now beater bar does turn. How to fix?
Sounds like the belt either just slipped off, or is broken.
It's normal when the beater gets jammed.
Can you spin the beater easily?
Jun 24, 2011 | Kenmore Progressive Upright Vacuum with...
I have a Dyson Animal bagless vaccume and can not get the beater bar to work. I have cleaned it really good and seems that it doesn't switch from bare floor to carpet
Is this a new vacuum for you, or are you familiar with how it works? The beater bar button is on the front of the handle. It is a large half button with the picture of a beater bar on it. This button has to be pushed down for the bar to work.
If you already knew this and your vacuum is one you have had for awhile, it may have a worn or broken belt. The manual should tell you how to replace the belt, and you should be able to purchase one through the dyson website http://dyson.com under PARTS or at the store where you purchased the vacuum.
Please let me know if this works for you.
Jan 11, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a Wisperingtone Cannister 100 purchased in early 80sbeater bar won't turn...something may be stuck...how do I remove cover plate? Thanks.
Take the pwerhead off your vac.
Face the beater bar upwards toward you.
Remove 4 Philips screws.
Remove the plastic shroud from the bottom of pwerhead.
Carefully remove one end of the beater bar, (the end opposite to the belt)
Remove the belt end.
Now depending on your model... you should be able to remove both ends of the bar.
usually there is thread or carpet fiber wrap around the bar.
You mention the 80,s,which also tell me they had a copper fitting where the axle of the beater bar meet. Trying to relace the end pieces may be a task and a half... So purchase the whole unit from the manufacturer.
Have fun vaccuming
Jul 10, 2010 | Kenmore 23313 Whispertone Bagged Canister...
WHEN I TURN MY VACUME ON IT SOUNDS FINE, WHEN UPRIGHT. WHEN I GO TO MOVE IT TO HOOVER IT MAKES A SCREAMING NOISE. CAN U TELL ME WHAT IS WRONG PLEASE AND HOW TO FIX. THANK YOU
When the vaccum is upright, the beater bar is not engaged. When you tilt the handle back, the clutch engages and the beater bar begins to turn.
There are two likely possibilities for the "screaming noise". First, and most likely, is that the beater bar cannot turn because of a build up of debris or the beater bar is broken. In eaither case, the clutch belt is spinning on the non-moving beater bar causing the noise. Remove the beater bar, inspect for hair, carpet fibers or other items wrapped around the bar. Also inspect for cracks in the plasitc at the ends of the bar. Clean or replace the bar as needed.
The second possible cause is the clutch assembly. If you were unable to fix the problem with the first solution, it is time to take the vacuum in for service as replacing the clutch is somewhat difficult.
Here is a YouTube video link that will walk you through the process of removing the beater bar as well as the clutch if you decide to go it on your own: http://www.youtube.com/watch?v=7_CtaFcc5HU
Hope this helps.
Sep 23, 2009 | Dyson Vacuums
My bissel upright vaccum cleaner belt got damaged and i replaced it with a new one , but it got damaged immd after replacing
In the area where you replace the belt, see if you can remove the beater bar, and check that there is nothing stuck in the area that is causing the damage, like a small screw or similar item.
Sep 11, 2009 | Bissell 6594 PowerForce Bagless Upright...
The brush isn't spinning
the belt is broke. you can buy a new one for around 5-10 dollars at target or walmart, or loews or homedepot.take the screws of the bottom panel to expose belt. you will have to pull out the beater bar to replace the belt. just pull on it after the bottom plate is removed the beater bar just slides out. slide the new belt down the beater bar then pull the belt over the spinning pin. now stretch the beater back to its original position it should slide right in. replace the bottom plate and your back in business
Jul 12, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
