Question about HP Wireless Optical Mouse
The click button on the left hand side is not working
    Problem Solver:
  • 11 Answers
This may mean it is dirty under the button, see if you can clean with a cotton swab, if it still does not work click start > right click my computer > properties > hardware tab > device manager > select the mouse and right click properties > click the roll back driver button.
i know you cannot click, which is why you will need to press the tab button a few times, this will move the selection around then you can press enter when it gets to the desired button.
if this does not work it means the mouse will need replacing, i hope this has helped you
Posted on Mar 30, 2011
The right side of my touch pad control button has stopped working
Did you check the settings for the left and right buttons under the mouse properties. Normally the left should be set on Click and the right should be set on Shortcut. If it's set to NONE then it will be inoperable. Better yet you can click the Default tab for buttons. Otherwise, it sounds like your touch pad needs to be replaced. The immediate remedy to this is to just go purchase a USB mouse and voila, you'll have the ability to left and right click.
Mar 20, 2012 | Toshiba Satellite A205-S4617 Notebook
Tip
How to change the mouse sensitivity
<p>Click on the "Start" button in the lower left corner of your computer screen to open the Start menu so you can change the mouse sensitivity. Locate the control panel link on the right-hand column of the Start menu and click on the link.<br /> <p><br /> <p>Wait for the Control Panel manu to open and then locate the "Search Control Panel" bar at the top of the menu on the the right-hand side. Type in "mouse" (no quote marks) in the window and locate the mouse menu at the top, left side of the menu.<br /> <p><br /> <p>Locate the link that says "Change Button Settings" at the bottom of the mouse menu and click on the link. When the mouse properties window appears, locate the tabs at the top of the window and find the one that says "Pointer Options."<br /> <p><br /> <p>Click on the "Pointer Options" window tab and locate the heading that says "Motion." In the Motion section, find the slide ajustment bar that is labeled "Slow" on the left side and "Fast" on the right side of the bar.<br /> <p><br /> <p>Move the bar according to your desired speed and preferences, and click on the "Apply" button on the lower right-hand side of the window.<br /> <p><br /> <p>Click the "OK" button on the lower left-hand side of the window, which will take you back to the default window. Verify that the mouse sensitivity is according to your needs and readjust if necessary by repeating these steps.<br />
on Dec 07, 2010 | Computers & Internet
Why cant i reboot my laptop i press enter and it doesnt work
Enter will not reboot your laptop unless you have the menu pulled up to do a restart. Use your mouse pad and go to the lower left hand corner of your screen you should see a microsoft logo on the very bottom of your screen far left hand side the first button on the bottom lower left hand side. Click on that button and a menu will pop up depending on the version of windows you are using you may see a window with writing in it it may say shut down or sleep but to the right of the window you will see a small triange. Click on that triangle and a drop down will appear select restart and your computer will reboot for you.
I hope this helps you out.
Apr 01, 2011 | Computers & Internet
My watch is stuck on military time somehow. I would like to know how to change it back to normal time. My watch is a Armitron Alarm/Chrono WR 165 sports watch. The number on the back is 45/6915. Thanks for...
Welcome to Fixya,
The Armitron WR165 is a digital watch that includes a 24-hour alarm, hourly chime, stopwatch feature, countdown timer and is water resistant up to 165 feet. With a rubber wristband and rugged style, the watch is meant for outdoor enthusiasts and athletes. The WR165 can be found online, in some sporting supply stores and in certain department or general home stores. Setting the Armitron WR165 only takes a few steps to perform properly.
1 - Push the top button on the left-hand side of the watch until the seconds flash on the display.Press the top button on the right-hand side to zero the seconds.
2 - Push the bottom button on the left-hand side of the watch until the hours flash and then the top button on the right-hand side of the watch to increase the hour on the watch display. Note that "PM" will appear on the watch display for PM times, but there is no "AM" indicator on the display.
3 - Press the bottom button on the left-hand side of the watch until the minutes flash on the display.Press the top button on the right-hand side of the watch to increase the minutes on the display.
4 - Repeat to set the month, date and weekday on the watch. Press the top button on the left-hand side of the watch to return to time mode.
5 - Press the bottom button on the left-hand side of the watch to enter the stopwatch mode. Press the top button on the right-hand side of the watch to start the timer. Press one more time to stop timing. Press the top button on the left-hand side of the watch to reset the stopwatch to zero and the bottom button on the left-hand side of the watch to return to time mode.
6 - Press the bottom button on the left-hand side of the watch twice to set the alarm. Press the top button on the left-hand side of the watch until the hours flash on the display. Press the bottom button on the left-hand side of the watch until the alarm number flashes. Press the top button on the right-hand side of the watch to choose Alarm Time 1 or Alarm Time 2. Push the bottom button on the left-hand side of the watch again until the hours flash. Push the top button on the right-hand side of the watch to choose the alarm hour, followed by the bottom button on the left-hand side of the watch to change to minutes. Press the top button on the right-hand side of the watch to advance the alarm minutes. Press the top button on the left-hand side of the watch to set the alarm time and the bottom button on the left-hand side of the watch to return to time mode.
I hope this will help you.
Thank you for usinf Fixya.
Feb 21, 2011 | Watches
Mouse sensitivity is slow.i want more then more speed of mouse pointer,i already search but nothing...pleas SIR
These are the steps to change the mouse sensitivity
Good luck
do rate the solution if got help
Dec 07, 2010 | HP P2360AA Keyboard/Mouse
How to delete songs and pictures that are already on it?
Delete songs
-Under Devices 2 d left hand side u c ur ipod name.. 2 its left u c a small arrow.. wen u click on dat u get a dropdown list sayin MUSIC VIDEOS etc..
-Click on MUSIC option u'l c a list of music..
-Right click on d song which ya don need n delete..:)
Delete pictures
-2 d left hand side, Click on the ipod name under devices
-Look 4 d TAB which says photos.. click on it..
-There is a tick box in front of d phrase SYNC PHOTOS FROM.. untick this..
-A lil box will come up saying want to delete photos or dont delete photos.. click on delete photos
-After dat 2 d bottom right derz APPLY button.. Click on this..
-Later click on SYNC button.. al d photos'l b deleted..
May 02, 2010 | Sharper Image Audio Players & Recorders
Changing default language in Canon Software for MP810
Hi I had the same problem with an ip4500
Go to printers and faxes in the start menu, right click on your printer, left click on printing preferences, this should be the second line down, the print pref. menu window will open, you may not be able to read any of this, on the top should be five tabs, the last one is the maintenance tab (has pliers and screwdriver symbols), left click on this tab, you should see all the maintenance buttons with icons inside and six rectangular buttons in the bottom right hand corner (four on the bottom and two above them), ignore the four on the bottom for now, ( with right to left languages such as Arabic the upper two buttons are on the left hand side and the button you need to click is on the left side) left click on the button that is on the right hand side of the two buttons above the other four, a smaller window will open with three buttons on the bottom, directly above this is a bounding box with a drop down arrow on the right hand side ( left side for R to L languages), click the arrow, find "English" or whatever language takes your fancy, click on it, now of the three buttons on the bottom of the SMALL window click the one on the left( right for R to L languages), the small window should close, then of the four buttons on the very bottom of the pref. window ( these are the four you ignored before ) click the one on the left, the window will close. Go back to printers and faxes, right click on your printer, choose print pref. and your menu should be in your new language. Hope this helps.
Oct 16, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Left handed use of dell mouse
go to control panel, double click 'mouse', look at 'buttons' tab. Change as needed!
Aug 13, 2008 | Computers & Internet
Windows XP display..
Try clicking on the icons Holding on to the button & drag it to the left hand side.A more easy method is to right click anywhere on the desktop,click on Arrange Icons By Name,Size,Type & modified.Choose any one of the four options.Hope this helps
Jun 06, 2008 | Microsoft Windows XP Professional for PC
Clicking
If It Glows Red Constantly, You have a possible Overheat Problem. if it flashes green/red it,s Fragging.
the clicking needs to be identified more clearly, is it clicking at the left hand-side or the right hand side of the console.
DVD Drive Left Hard Drive Right.
Mike @ compurepair.
Mar 02, 2008 | Microsoft Xbox Console
HP Wireless Optical Mouse Logo
156 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
