Question about Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishwasher is leaving dirty dishes. Water is hot, detergent is good, jet dry is full and the trap is clean in the bottom. What else could be the problem?
  • 2,510 Answers
Are the rotating arm jets clear of any blockage, top and bottom arms?
Posted on Mar 30, 2011
Built-in dishwasher. dishes not clean, plus nasty white residue on everything...
Hi
The white residue is from the new environmentally safe soap. Check your soap and see if it is phosphate free soap and that will be your issue. Also either you have hard water or you're seeing either calcium or lime deposits. You should use the jet dry for every load. There should never be any suds in a dishwasher. Do not use liquid dish detergent for the dishwasher.Try running a load without dishes, using vinegar, or a bottle of Dishwasher Magic. Another possibility could be you're not getting enough water. The level should be close to the heater(check your tech sheet to be sure). The water temp should be at least 140 deg.F (no matter what the box says) Also, use a good brand of detergent (Cascade) and be sure your wetting Agent dispenser is full. (jet dry)You should not have to pre-wash your dishes..just scrape them well.The detergent actually needs some dirty dishes to work properly..fats, protien, etc. to make up 1 more chemical for the detergent.Another important step is to run the hot water faucet before running your d/w to "purge" the cold water out of the line.
Also check this links for some helpful information:-
http://www.appliance-repair-it.com/dishwasher-leaves-white-film-on-dishes.html
http://askville.amazon.com/dishwasher-washes-dishes-clean-white-residue-problem/AnswerViewer.do?requestId=6117170
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6192
Please get back to us if you have further query else please accept this particular suggestion.
Thanks for contacting fixya.com
Aug 23, 2011 | Kenmore 16602 / 16604 / 16609 Built-in...
I have a Maytag dishwasher Model PDB3600A. the dishes are left with a strong soap residue after a full cycle of wash. I use a powder detergent and Jet Dry. What should I check to solve the problem?
When you open up the dishwasher is there still water in the bottom of the dishwasher????? The screen around the bottom could be dirty. Or the drain line could be restricted, if it drains back to the Garbage disposal make sure it is draining. Are you using hot water??? Check to see if the Arms are turning and the ports are not plugged with debrie.... If the drains are OK and the screen is clean...... I put in about a half gallon of white Vinegar in the wash cycle after it filled with water and used no soap and rewashed the dishes. I ran the Hot water faucet at the Kitchen sink till the water was good and Hot and then on the dishwasher used the heat water feature. It cleaned up the dishes and the dishwasher. I did this on a Whirlpool dishwasher but it should work for any make of dishwasher. Hope this helps... I had to do this several time to get all the dishes back clean
Jan 02, 2011 | Maytag Dishwashers
Dishes constantly come out dirty.. What temp should the water be while the dishwasher is running?
Supply water temperature should be above 120 degrees F for effective cleaning. Run hot water from your kitchen sink (your dishwasher should be tapped off the hot water line near your sink faucet) right before you start a dishwashing cycle to make sure it's as hot as it can be when the dishwasher begins filling. Also, during the wash cycle the heating elements at the bottom of the tub may turn on and warm the water further even if you select a "No Heat Dry" option causing a noticeable shot of steam to escape if you open the door during a cycle.
Note: I recently had a problem with our dishwasher (Frigidaire FDB834RFS0) causing dishes to come out dirty and the detergent dispenser to be left with undissolved detergent. Our problem happened to be caused by a partially clogged strainer in the water supply valve. (I would imagine Whirlpool most likely has some kind of filter/strainer in its water valve as well.) When the supply valve was commanded to open for some time, I noticed the water level in the tub would barely be visible below the lower spray arm. After cleaning out the strainer (required removing and disassembling the water supply valve) the water level was noticeably higher -- almost at the bottom of the float or about an inch below the heating elements. Our dishes and the detergent dispenser are now clean.
If your water supply is ok, I would next check to make sure your spray arms do not have any plugged holes and that they rotate freely. Also, use a good quality detergent and a rinse aid. We prefer liquid Cascade and Jet Dry. We have had problems with old, stale, or really thick liquid detergents and by getting a fresh jug have solved the dirty dish dilemma.
Make sure to clean out the filter basket at the bottom of the basin below the lower spray arm occasionally as it can clog and cause the pump to starve due to lack of water. If the pump can't get a supply of water to pump to the spray arms and nozzles, your dishes will not get sprayed evenly and you will end up with them being poorly cleaned.
Hope this helps you out...good luck!
Nov 18, 2010 | Whirlpool Dishwashers
Dishwasher not cleaning the dishes anymore, leaves a film on
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you’re using and adjusting your hot water heater’s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you’ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn’t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don’t use extra-hot settings such as “Power Scrub,” and use the “Energy Saver” dry cycle.
2) Adjust the detergent amount.
3) Don’t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Apr 10, 2010 | Kenmore 24 in. 16299 Built-in Dishwasher
After a wash cycle my unit leaves a film on my glass'
first thing you need to do is purchase a bottle of dishwaser cleaner from your groc store in the diswasher detergent section red the instructions on the label add it to the cutlery tray in an empty dishwasher upside down remove the paper seal off the top of the lid do not remove the wax seal place the bottle upside down in your dishwasher turn on hot water tap and run till it is hot next turn on your washer set it to wasn and let it run a full cycle. when washer finishes open it up when it cools and fill rinse dispenser in door with a good quality rinse agent like jet dry close dispenser and when dishwaser is full of dirty dishes turn it on the jet dry will make your galsses come out crystal clear w no film and the dishwaher cleaner will help all your dishes come cleaner.Use the dishwasher cleaner aroun 4-6 wekks it cleans all the inside of the dishwasher and removes a lot of **** aND RESIDUE THAT ACCUMULATES IN DISHWASHERS OVER TIME
Dec 17, 2009 | Dishwashers
Not rinsing glasses clean
If the glasses are spotty from hard water try a rinse aid like Jet Dry. If they are actually dirty, depending on the brand of DW you may need to rinse them better before putting them in the DW. Not all brands are cerated equally, some do work better then others
Oct 11, 2009 | Dishwashers
I have a adb2200awb amana dishwasher which leaving glasses with a cloudy plus grid stuff on the glass and on the dishes. i use jet dry stuff plus the talbets with jet dry in them also i put them on a 2hr...
This is a classic sign of too much detergent. Are you only using one tablet? Too low of a washing temperature could also be your culprit. Dishwasher detergent needs to be washed with at least 120 degree water. Check to make sure your supply is hot (if it's plumbed to intersect with your faucet, just check faucet hot water supply temp). I'm not sure why you're running it on a two hour cycle, dishwashers can generally do the job in about 40 minutes. The grit is probably because there are food particles in your food trap. Make sure the food filter beneath the spray arm (if equipped) is clean and check the lowest areas for food scraps.
Jul 08, 2009 | Amana 24 in. ADB2200AW Built-In Dishwasher
Dishwasher leaves film on dishes
make sure your rinse agent aka : Jet Dry is full and water is hot enough.
Jan 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Soap film on dishes
Rodney B if you are sure that the white film is detergent and not hard water deposits, then look at how you are using the detergent. When you watch the TV ads for dw detergents, they are showing baked on/extemely dirty dishes being put in the dishwasher and coming out clean. Well they do this as the dw detergent is designed to break down protein based food products. Fats, oils, and such. If you are prewashing your dishes before putting them in the dishwasher, then there is nothing for the detergent to attack and attach to, so it ends up staying in the dishwasher. If you are going to rinse your dishes, then you need only 1 tablespoon of detergent. Dishwashers are designed to clean using 4 parameters, hot water of 130 degrees, water, detergent,& pressure of the water jets. That is how they clean dishes. Now if this is hard water deposits, switching to an enviromently friendly detergent which is high is Citric Acid (What gives Tang drink its tartness) this will reduce this issue. Hope this helps
Jan 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Washing leaves spots
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you're using and adjusting your hot water heater's water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water. First you'll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, you can wash the glass with warm water and concentrated dishwasher detergent or use a high-phosphate detergent (such as Glass Magic) according to label directions. If film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature. See "Doesn't wash well," above. Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn't anything you can do to make it clear again. But you can avoid future etching by taking these steps: 1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don't use extra hot settings, such as "Power Scrub" and use "Energy Saver" dry cycle. 2) Adjust detergent amount. 3) Don't pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
Jan 18, 2006 | Hoover 24 in. DT999 Free-Standing...
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
83 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Tom Chichester
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
