Question about Estate TEDS740JQ Electric Dryer
First the drier started squeeking then the drum stoped turning
  • 57 Answers
Belt and idler pulley most common. If you need instructions. Let me know.
Posted on Mar 30, 2011
Why won't it start?
check for the operation of a small micro switch at the door hinge
if that is out of adjustment then the unit will not start
Jan 05, 2016 | Bosch Dryers
How to get to motor on hoover vhc691b?
Very rare a motor fails on a hoover drier normally its the capacitor that fails. you can hear the motor humming but the drum wont rotate to proof its the capacitor turn the machine on press start listen for the motor humming open the the door of drier turn the drum by hand fast then shut the door as fast has possible then the drum should start going around . then this proves its the capacitor fault you are doing the job of the capacitor giving the motor a start .
May 16, 2014 | Hoover HDC6 Electric Dryer
Ge frontloader dryer is squeeking incessantly, high pitch squeek driving us all crazy. by manually turning the drum i can isolate the squeek, but cannot see anything wrong. does it need to be taken...
There is a teflon bearing that holds the back of the drum you will need to replace. To get to it remove the top cover, take off the control panel, remove the front cover, take off the belt, then take the drum out, ususlly by lifting it up as you pull it foward. While have it all apart I would reccomend replacing the teflon glides at the front that the drum rides on.
Jan 31, 2011 | General Electric DCVH680EJWW Dryer
I have a 5 yr old KitchenAid front load dry that just started to make loud squeaking sound when running or even if I turn the drum when the dry is off. Drys clothing good, just making noise and want to...
You will need to check the tub roller wheels. This is a common noise when the wheel bearings start to ware down. They are not expensive, and you should be able to do this yourself. Good Luck Friend.
Feb 22, 2018 | KitchenAid KEHS02R Electric Dryer
Chattering squeeking drum noise
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.Also remove the screws holding the lint filter in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
May 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My drier makes a squeeking noise and overheats after about 10 minutes. What is wrong and how do I fix this?
You have a partial or full clog in the exhaust. Pull the machine from the wall and disconnect the hose ... start cleaning with a shop vac ... go both ways. If your hose is plastic, replace it with flexible metal. Dont forget to clean the outside vent.
The squeek is probably the front 'bearing' which is usually felt and rides on a ring around the door. Best fix is replace it, next best is clean it ... the fix i use it I turn the radio up until the noise goes away.
Oct 08, 2009 | Maytag PYE2300AY Electric Dryer
Is squeeking and takes long to dry
you will need to replace the drier drum belt
Sep 18, 2009 | GE DVL223EBWW Electric Dryer
Squeeking / squeeling from Candy cc2 17 smart dryer
hi,well if its not the belt,there should be two rollers in front of drum at bottom,they are wearing out or need oiled.as for getting to motor and belt,well not sure of model,but most of dryers,you will have to take front off of dryer,then remove belt the tumbler.you should be able to reach tension,and release it to get slack in belt. hope this helps. duane.
May 28, 2009 | Candy CDV262 Dryer
Dryer drum will not turn
sounds like a power promblem to me check at out let for 220 volts if you have it there first turn circete breaker off then on try drier if that dont get it check for power at outlet with meter if 220 is there after unplugging drier check cord at back of drier at terminal block if all thats ok then you have a bad door switch a bad start switch or a bad thermal limiter last and rare bad drive motor
Nov 06, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Estate TEDS740JQ Electric Dryer Logo
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
