Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Red convergence is off.
I have a panasonic PT-53TW53 53inch rear projection. I was watching a blu ray movie and all of a sudden the red was way off alignment. I tried to adjust via menu, but it wasn't even close. I did a little research and assume it's an IC problem? I'm pretty good with electronics any help would be much appreciated.
    Problem Solver:
  • 8 Answers
Hi there, your problem does sound like the IC's or IC has gone bad, before you change them check the solder connections. If they are ok then the ic.s need changing, do both as the other one may fail shortly, they are usually STK392-110 but check the number on the ic's to be sure. then do the alignment that covers the whole screen, sometimes you get lucky and dont have to go through the fine adjust. hope this helps.
Posted on Aug 04, 2008
Red, green and blue shadows
have you tried to run auto convergence
Mar 08, 2013 | Panasonic PT-47WX49 47" Rear Projection...
Missing red composite signal on panasonic pt-47wx52cf
Check your jacks and cables.
The RED jack is either (1) left or right channel AUDIO signal or (2) the RED color channel of an RGB (Red, Green, Blue) COMPONENT video signal.
Yellow is the COMPOSITE video signal.
Dec 31, 2012 | Panasonic PT-53TW54 53" Rear Projection...
I have have red and green shadows at the sides of the screen. A convergence didnt help.
If the convergence didnt help you need to replace your convergence chips in the back of your set. Please watch video
Nov 07, 2010 | Panasonic PT-56WXF90 56" Rear Projection...
My television has suddenly turned into double picture thts gone red and green..y is this? and can it b fixed.
try the auto convergance inthe viseo menu, if not it is the convergance board not a good idea to replace
May 30, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic Cinemavision PT-56hx41e, wording on screen is red?
the convergence circuit governing the red picture has gone defective and needs attention possibly a convergence amplifier IC or and convergence coil at the red CRT went defective
Apr 28, 2010 | Panasonic PT-56HX41 56" Rear Projection...
Panasonic rear projection-red convergence-moves horizontal only!?
The convergence ICs have failed. You will need to install a convergence repair kit. You can get the convergence repair kit for your model Panasonic from www.tvrepairworld.com which contains both of the Convergence ICs , the associated resistors and the cD with detailed repair instructions.
Dec 26, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX42
convergence IC bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Power problem
would require some troubleshooting, common problems would be convergence amp ic and high volt transformer transistors
If you are really brave tackle this TV FAQ.
http://repairfaq.ece.drexel.edu/sam/tvfaq.htm
Dec 04, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic blue convergence problem
Yea, you have to have the two convergence Amp IC's replaced. Should run you about 300 bucks or so. Good Luck
Sep 14, 2007 | Panasonic PT-56HX41 56" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
51 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
