Question about NAD T955 5Channel Amplifier
One of the face of my T955, a Blue LED for one of the channels is much dimmer than the other 4. And when I engage the soft clipping, the blue LED nearly goes out. This same LED is also dimmer when I first turn the amp on and all of the 5 LEDs are red. I think the channel in question is also slightly distorted compared to the others. It is hard to say with certainty as I am actively biamping my speakers and I can't do a full range comparison of the channel in question to any of the other channels. Will this channel fail ultimately if not serviced? Thanks! Tim
  • Scott Frye
    Scott Frye Apr 05, 2011
    That dimmer LED may just be out of line
    Contact NAD for the "nuts and bolts" of your problem
    Their tech guys are OK
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: I OWN A NAD M
The manual would suggest you have a problem.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-M25-Amps-manual/id/8043ci561/t/2/
Try unplugging all of the speakers and see if that amp is still distressed. If it looks clean and happy start adding speakers until it returns (or not).
Posted on Jul 03, 2011
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
Mitsubishi wd 52628 input issue, blue screen and input error
there are no analog channels, they are all digital now, be sure your antenna is facing proper direction before scanning for digital channels
Apr 20, 2013 | Mitsubishi WD-52628 52" Projection HDTV
Need wiring diagram for pioneer deh p2900mp wiring diagram
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps.
Feb 23, 2011 | Car Audio & Video
Hitachi p50H401 plasma - no picture no sound. blue led flashes
sound like mine,the two power clips have gone,midle panel to left,need to be replaced,if still no good,need new mother board with the clips.
Sep 26, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Cb radios-galaxy dx99v
This has an LED channel display, which is the same as the Cobra 29. You can pick up a new one, there are a few color options available. You need to be very proficient with de-soldering and soldering small parts. You need a desoldering iron or desoldering wic, and no bigger than a 30 watt sodlering iron, any bigger can burn the foil trace, and some solder. You have to open the case, remove the faceplate screws, remove the faceplate, remove the channel selector/pcboard, and the channel display pc board together. Now you desolder the pins of the display, aproximately 20, remove the diplay, insert the new display observing direction (make sure it is face with the decimal to the right place), solder each pin to the pc board, and clip off the excess section of the pins (which is sticking out of the back of the channel display pc board. If you have changed to a blue display, you need to remove the orange or green cover, and replace it with a blue one (I make mine from blue transparant report covers) and hot glue it to the inside of the faceplate where the old one would have been. The reason for this is that the blue light will not shing blue thourgh a green or orange cover, and if you use clear, the display will be extremely bright, and the blue cover will knock down the glare a little. Now just put the radio back together and fire it up.
Now with that said, if you think you may have any trouble with this, you can take it to any cb shop and they should be able to help you.
Any more questions, don't hesitate to email me at rollincbmods@yahoo.com
Dean Pitts
Rollin CBs
Aug 22, 2008 | Radio Communications
NAD T955 amp has dropped a channel, when i turn it on the led starts off blue instead of red, when the other channels change to blue from red it emits a loud POP noise from the lost channel. No noise comes...
Hello.I know the post is old but i had the same Amplifire NAD T955 with the same problem.I send my Baby to a Service in Austria and they can easy repair it.Im very happy again,it works nice.If anyone had this problem contact them.Harlander GmbH in Vienna.Homepage reparatur-service.at.
Greetz TommyS
Apr 15, 2008 | Audio Players & Recorders
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Open Questions:
See all NAD T955 5Channel Amplifier Questions
NAD T955 5Channel Amplifier Logo
57 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
