Question about HP PSC 2410 All-In-One InkJet Printer
Not faxing on 2410 all in one hp printer - HP PSC 2410 All-In-One InkJet Printer
    Problem Solver:
  • 9 Answers
Make sure that youre using a regular line not dsl or voip line make sure youve connected it to the right port it should be line 1 connect the printer direct to the phoneline check settings "rings to answer" must be set to 3 ring you should have distinctive ring it must be set to all rings check fax speed it must medium then run a fax test all of these are under fax setting on your printer send fax tp 1800-hpfaxme,if recived a reply your good to go...otherwise call hp support...
Posted on Mar 30, 2011
Testimonial: "Simply had the line plugged into wrong port, thanks."
Hp psc 2410 photosmart driver win7
HP no longer provides support for drivers for this printer. The newer Windows OS will support the printer natively, but sometimes it requires a little finesse from the user. Here is a link to an HP forum where folks tell how they worked out the communications issue for the print and scanning functions. Hope this helps!
adding hp psc 2410 printer to windows 7
Aug 01, 2016 | HP PSC-2410 PhotoSmart All-in-One Color...
Hp 2410 won't fax
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 31, 2010 | HP PSC 2410 All-In-One InkJet Printer
Fax will not answer
go to fax settings and change the fax speed to the lowest and also turn off aut reduction if that does not work run a fax test should be under the tools option on the printer else you can run it from the printer driver
Jan 15, 2010 | HP Photosmart 2410 All-In-One InkJet...
I keep getting an error 421 when i try to fax something and i am not able to recieve faxes... i have an hp psc 2410 aii in one printer
Have you DSL switch in place. you must plug printer into that then the switch into phone socket.
Uninstall then reinstall, being patient and following instructions when asked for information.
Nov 10, 2009 | HP PSC 2410 All-In-One InkJet Printer
My hp psc 2410 photosmart All-Inn-One is not allowing me to receive faxes. It goes through the process of connecting but then says fax failed. I am able to send faxes out and they are received. I am using...
try going into the advanced fax settings and turning off error correction mode. also if you have distinctive ring on the phone line make sure it is set to the right number of rings for the line. ex. fax line is second number set the answer ring type or distinctive rings to double
Aug 08, 2009 | HP PSC 2410 All-In-One InkJet Printer
I cant get the fax to work on my hp psc 2410 all in one
Try going into the fax menu and setting preferences. Insure that you have a good telephone connection to the outside line. Try going to www.hp.com and troubleshoot. Good luck.
Jan 27, 2009 | HP PSC 2410 All-In-One InkJet Printer
Hp 2410 can receive but not fax out
Your fax transmission protocols might be set to a non-standard. Go through the fax menu and try to reset. You may also have a dial out setting, added or missing, an additional number. (i.e. 9- to get out of the office)
RDO
Nov 05, 2008 | HP Photosmart 2410 All-In-One InkJet...
Hp psc 2410 photosmart all in one printer/fax/scanner/printer.
plz visit the manufacture website and download the manual for free
Jul 03, 2008 | HP PSC 2410 All-In-One InkJet Printer
Fax HP PSC 2410
I HAVE PSC 2410 XI All-In-One AND Fax HP PSC 2410xi does not work PLEASE HELP
Feb 01, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
240 people viewed this question
Seeker5211
Seeker5211
