Question about Ricoh Aficio 450 Copier
My Ricoh aficio 450 copier shows a error that says: close door for relay. I have closed all the covers and doors and still get the same error message.
    President:
  • 903 Answers
The relay door is the door on the lower right side, below the duplex unit. Check this door -- it may not be closed all the way, or the actuator (the piece of plastic that sticks off the door and is the part that blocks the sensor) may be broken. If neither of these is the case, the sensor may be bad.
Posted on Apr 17, 2011
Ricoh 2045 this problem coveris open as show close it
kindly check the cover that the machine is showing and close properly
Mar 10, 2014 | Ricoh Aficio 450 Copier
ERROR MESSAGE: COVER IS OPEN AS SHOWN. CLOSE COVER. IT IS SHOWING IN THE PICTURE A VIEW ON THE RIGHT SIDE BOTTOM TRAY.
Hello!
Make sure that all off the covers and doors are properly closed.
If you are sure that everything is closed you probably have a faulty switch or a broken gate in the bottom tray.
See you!
Jun 23, 2011 | Ricoh Aficio 2035 Copier
Ricoh Aficio 2035e showing "Open Cover" message.
If in the control panel don't show any places or any door, change the switches on the front cover area and the switches of the fuser area. If the problem continuos check the laser area.
Dec 03, 2010 | Ricoh Aficio 2035 Copier
Codigo sc-322-000 copier ricoh aficio 450
sc322 is an error generally caused by a component in the laser unit. However, sometimes a faulty door switch can cause this error as well. The switches in question are the three micro-switches that change state when the right door is opened or closed. They are located on the front right side of the copier, above the fusing unit and behind a plastic cover. If you can remove these switches and test them individually, you can probably find the faulty switch. If not, you can replace all three as a set and hopefully the sc322 error will go away (once you reset the machine).
If replacing the switches do not fix the error, then the problem lies somewhere in the laser unit, possibly with the polygon mirror motor, but your best bet is to replace the whole laser assembly if you can.
Hope that helps!
Oct 22, 2010 | Ricoh Aficio 450 Copier
Flase door open reading on my aficio 350. The door is shut. The machine is showing that the door is open but it not. It close as it should be.
when the door closed it actually activates the switch. see on the door if any plastic piece from the frame is broken or not and locate where in the machine does the front cover activates switch. it will be easy to find the broken part.
Sep 23, 2010 | Ricoh Aficio MP 161 Black and White Copier
I HAVE A PROBLEM WITH MY COPIER,NASHUATEC D435.
Enter in the service mode(SPmode),open the front cover and turn OFF the copier.Unpluged the machine,wait 10sec.amd pluged ON.Before clean the thermistors and thermofuses in the image fusing unit.Close the front door and turn ON the copiers.
Feb 08, 2010 | Ricoh Aficio 450 Copier
Door/covers open
dear sir; check it out on the side door left hand side (if you face door) have piece plastic door switch actuator isn't broken, change door !
Dec 26, 2008 | Ricoh Aficio 450 Copier
Sharp 336
My suggestion is to check the relay in the back of the machine,
I used to get that code with a toshiba, In the back to the right there is a relay with a switch, sometimes it would pop the switch.
Another thing that caused that was a small transformer.
Not sure if sharp is the same.
good Luck
Nov 27, 2007 | Ricoh Aficio 450 Copier
Problem with Aficio 450 door cover sensors
I post a solution for this problem see: www.fixya.com/support/t2748127-false_door_open_reading_aficio_350
May 07, 2007 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
177 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
