Question about Dayton (3E405) Gas Radiator Heater
Have a dayton 3F405D propane greenhouse heater don't know where to light the pilot light.
  • 1,420 Answers
Find where the gas line connects to the gas valve on the back of the heater, from the gas valve, follow a small aluminum tube going into the back of the heater. There may be a removable door to access the pilot assembly. If there is no aluminum tube, the unit has electronic ignition and no pilot lite. Turn the gas knob to off, then to pilot. Hold the gas valve in and with a long match or gas grill lighter, light the pilot. Continue to hold the knob in for about 30 seconds. After that, release the knob and check to make sure the pilot stays lit. If so, rotate the knob to ON. The thermostat will kick the burners on.
Posted on Mar 30, 2011
Propane heater not heating
-Thermo is not working. Replace new thermo.
Good Luck
Mai
Dec 04, 2014 | Heating & Cooling
Dayton3e368a pilot lights but burners do not come on. Heat rod was replaced last year. Heater is in a greenhouse
Most heaters has a pilot proving sensor of one type or another, it will be in direct contact with the pilot flame to prove that the pilot is lit and then will allow for the main gas to the burners to open. If the proving device has failed then it needs replaced.
Oct 12, 2011 | Dayton Gas Furnace Heater
Just bought a Dayton electric heater to heat a 12' X 20' greenhouse in October. When the heater comes on it now makes a loud sound as if the fan is hitting something. I have it mounted horizonally near...
If it sounds like the fan is hitting something, It is likely you will have to get a step ladder, and look closely at what is making the noise-
Likely something fell in there-- and needs to be removed.
When you shut the thermostat down, does the fan stop instantly?
Mack B
Dec 28, 2010 | Dayton Electric Heater
Just filled my propane tank, tryed to light the pilot light, it would light but was very weak and would not stay on. Is the pilot plugged and how do I fix? Thanks
undo pilot tube at base of pilot and remove jet inside and clean or blow in pilot jet with tube or can of air should work then
Nov 10, 2010 | Dayton (3E386) Heater
Greenhouse Heater pilot light will not stay lit
replace the thermocouple. it is a small copper tube that screws into the gas valve and goes to the pilot assembly. a good haedware store that sells heaters will have one. they come in various lengths 18"-48".
Nov 30, 2009 | Heating & Cooling
Pilot lights but heater does notstart burning it sounds like everythings starting up its about 15 years old worked fine then one night smelled some gas shut it off next day would not work its propane
its most likely dirt/rust in your burner assy , but as its 15 year old and propane do your self a favour and get it inspected by a registered gas/propane engineer .
ive witnessed propane explosions at first hand and they are scary
Oct 23, 2009 | Dayton Gas Fired Heater LP TC200VA - Heats...
Pilot light
Hi the thermocouple is a long copper wire that goes back to the gas valve from the pilot .
i would clean the flame senser first , then check the pressure switch jump this out , then check the fan control or snap disc jump this out see if it runs if you need A THERMOCOUPLE then honeywell universal will do
Apr 07, 2009 | Dayton (4LX41) Heater
Pilot goes out!!
My manual shows three possibilities:  1) Insufficient fresh air available for combustion, so ODS kicks off gas flow 2) Low gas line pressure (should be between 11 and 14") or 3) ODS/Pilot is partially clogged.  Toll free number for ProCom is 877-886-5989.
Mar 09, 2008 | Procom ML300TBA Heater
Dayton (3E405) Gas Radiator Heater Logo
216 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
