Question about Sanyo VPC-E760 Digital Camera
I inserted a new SD card and camera says card needs formatting but when I try to format it says can't read card
    Brigadier General:
  • 11,967 Answers
Make sure the slide switch on the side of the card is in the unlocked position. Also, be sure this is an SD card, not an SDHC which your camera cannot use.
Posted on Mar 30, 2011
Why is my camera reading err sd when I insert sd card
I can think of a few possible issues:
1. SD card not formatted (format it in the camera)
2. SD card bad. try another one.
3. SD card bigger than camera can handle.
Sep 16, 2014 | Wildgame Innovations IR4c Digital Game...
Trying to format the sd card in my new jazz hdv180 camcorder, but it always just gets stuck on "waiting..." and i can't get it to connect to my computer to format it. Need it for christmas...
Hello
Remove the SD card from your camera and insert it into a memory card reader that is able to read SD cards. From there you can format your SD card and make it usable again.
Good Luck, hope it helps, if so do rate the solution
Dec 21, 2010 | Cameras
This camera reads "card error" and won't format a
yes. you can try to insert the sd card to a computer using any all-in-1 memory card reader. then if windows detects it, right click the card's drive in windows explorer then select format. choose FAT as file system type. before you put it back to your camera clean the card's contact points, insert the card and if the camera detects the card format it again using the camera's format tool.
Dec 19, 2010 | GE C1033 Digital Camera
My sandisk sd card isn't working in my camera. My camera is a vivitar 5024 camera, everytime I try to take a picture it says memory card is not ready, it says switch to internel ram. This memory card is...
Have you tried to format the card.
1.
  • Start up a computer with Windows XP, Vista, windows 7or Insert the SD card into an external memory card reader or into the computer's built in card reader. If it the first time a SD card has been inserted into the computer, Windows will recognize the SD card and automatically install drivers to read the memory card.
  • 2Go to the computer view by clicking on the windows start menu icon in the bottom right corner of the computer. In Windows 7 and Vista click "Computer". In Windows XP click "My Computer"
  • 3Right click on the SD drive under the computer heading. A dialog box with different options for the drive will appear. Click on "Format" to bring up the formatting dialog box.
  • 4Select the type of formatting (also known as file system format). In Windows XP or Vista there are several choices including FAT, FAT 32, and NTFS. In Windows 7 there is an added choice called exFAT formatting. This is an improved FAT formatting type with improved meta data capabilities. Choose the formatting type, name if the drive if desired, check or uncheck the "quick format" option, and press the "Start" button. When the SD card format is complete Windows will provide a notification.
    If you need further assistance please feel free to let me know. Thanks and have great day, Midwest-tek
  • Aug 31, 2010 | Vivitar ViviCam 5024 Digital Camera
    Tried two different brand sd cards. c533 tries to
    Try turning the camera off and then back on.Ensure that the memory card is the proper type for the camera. If the memory card is the proper type, try re- formatting the card using the Format option in the Delete sub-menu of the Playback Menu. If it will not format, it is probably corrupted. Replace the memory card
    Jun 30, 2010 | Kodak EasyShare C533 Digital Camera
    C190 does not read the sd card even when sd card format is ok . it is giving a message 'memory card requires formatting' 'please format memory card or insert another card' however inserting a new...
    Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 20, 2010 | Kodak Easyshare C190 12MP Digital Camera...
    When I turn on my Jazz DV 152/ T20 it displays "Read card..." and then nothing happens...I have a 4GB SDHC card by SanDisk...both camera and card are new....is this a faulty camera or am I doing something...
    Usually the first thing you need to do with any SD card and Camera is to go into the settings of the your camera and Format the SD card. This has to be done for each memory card you use with that camera. i.e. a SD card formatted on a Panasonic HD camcorder won't work in your Jazz Camcorder. The formatting is different between the two camcorders. New SD cards don't come formatted.
    SO try inserting the SD card into your Jazz Cam and rummage through the setting until you find your memory settings. From there find the Format Memory Card function, format the SD Card and you should be good to go.
    Jan 04, 2010 | Jazz DV152 Camcorder
    New digital memory card inserted and camara reads memory card error
    1. Try to format your memory card using a PC/Laptop.
    2. Now, insert it in camera and check whether its working!
    please rate this advice if it helps....tc! :)
    Jan 02, 2010 | Canon PowerShot A530 Digital Camera
    Sd card will not format
    The camera has a limit of a 2 GB card , its built into the camera hardware.
    Oct 19, 2007 | Kodak EasyShare Z740 Digital Camera
    Sanyo VPC-E760 Digital Camera Logo
    73 people viewed this question
    Top Sanyo Cameras Experts
    ray gallant
    Are you a Sanyo Camera Expert? Answer questions, earn points and help others
