Question about Whirlpool 17.6 Cu. Ft. Top-Mount Refrigerator - White
Seal around door is not tight. there are no breaks in the seal but the door doesn't seal properly. you have to make sure that you close the door tightly and when you close the freezer door it causes the frig door to open slightly.
  • 57 Answers
Is this unit new? Is it new to you? Has this problem just developed? I need the history to help you. If it is new, you have a year warranty. All units built today are as air tight as possible. When one door is opened and closed. The other door can pop open. To alleviate this issue the unit's front levelers must be adjusted to tilt the unit back slightly. The door or doors might still pop open but will close by themselves. If I can help you futher, let me know.
Posted on Mar 30, 2011
Freezer ZFT810FW door was left slightly open frosted but didn't de frost. Defrosted and cleaned. Fan making a noise red light flashing no alarm sound. The light flashing ,remains freezing. Thank you
The light will flash until the freezer gets cold enough probably around zero degrees. Be sure door is sealing tightly. This can easily be checked by opening the door and putting a dollar bill between the door seal and the cabinet and closing the door. Close the door and tug on the dollar bill there should be a little resistance there if the seal is sealing against the cabinet. check it in several places
Apr 02, 2018 | Refrigerators
My Neff fridge (K4316X1/GB) door does not close tightly on it's own and so does not seal properly unless I press it home
Try the following:
  1. Make sure there is nothing sticking out the fridge what could keep the door from shutting;
  2. Take a good look at the hinges and perhaps clean them or lubricate them (using Teflon spray);
  3. There is a white rubber strip all around containing the magnet with which the door should seal itself. Clean this rubber strip and the surface of the fridge it lands on;
  4. Make sure the fridge is level.
May 31, 2014 | Neff K4664 Top Freezer Refrigerator
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
My Fridgidaire refrigerator door does not close tight every time without pushing on it.. There isn't any moisture around the door. The light switch button has put a dimple in the gasket. The button on the...
If it is placing a dimple in the gasket, this may be the culprit. Try taping the switch off with duct tape and closing the door to see if it seals properly.Also make sure you have all food items clear. this is another factor in doors not closing, especially freezers.
Jan 15, 2011 | Frigidaire Refrigerator Light Switch -...
Left door of the refer isn't closing properly, must manually feed it thru the little channel at the top for it to fold in and close
check the door hinges a in place:
The door latch and lower hinge pin should hold your refrigerator door in place..
Uncover the door by removing the screws.Take the door off and pack bottom hinge with washers and make sure hinge brackets on cabinet are tight.
Check the seal is clean and pliable:
If seal is gapping, one solution is to warm with a hairdryer and pull outwards gently.
Check the refrigerator is properly leveled:
Adjust the middle hinge to straighten the lower portion of the door. Use a level to ensure the door is flush.
After fitting the door back again,check to see if the seal is touching on all sides when the door is closed. If not, you will need a new seal.Refrigerator is properly leveled.and hinges should be properly placed.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 06, 2010 | Amana AFD2535DES French Door Refrigerator
ICE DOOR SEAL IS LOOSE AND NOT SEALING CAUSING FROST BUILDUP
This is the step you will use to repair your ice door seal that is loose.
There are screws under the fold of the freezer door gasket that holds the brace for the gasket in place. Lift the rubber gasket to expose the screw head, one section at a time. Just loosen the screw, and do not take it completely out.
As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
Check the seal by closing the door. You should have a nice, tight seal.
Good luck.
  • Step 4 Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7rn3O8
  • Step 3 Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7gYaZ2
  • Step 2 As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
  • Step 5 fix-freezer-door-seal-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/k5/eg/fix-freezer-door-seal-1.5-800X800.jpg'); }); Keep the gasket clean to last longer. Check the seal by closing the door. You should have a nice, tight seal.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7JfY8i
    Jun 22, 2010 | Refrigerators
    Oven door will not shut tight at top
    The door is not tight per say. The seal is hat determines if it is properly closed. Check to see if the seal is tight all the way around(use a strip of paper to check consistency). If it is not sealing the hinges are tweeked and need replacing.
    Eric
    Feb 22, 2010 | Kitchen Ranges
    My dishwasher is leaking... I have a seal but dont know how to replace it its a maytag dishwasher
    If you are talking about the seal that goes around the door, it simply inserts into a groove around the perimeter of the tub facing. Just follow these steps:
    1. Remove old seal by pulling it from the groove around the perimeter of the tub facing and clean the area to ensure it is free of food debris and/or sopa deposits. This will ensure the new seal seats properly. Also clean the facing of the door interior where it meets the door seal.
    2. Take the new tub seal and locate the center mark. This is usually a small paint spot or small groove. If there is no center mark on the seal, fold it in half and mark this spot with your fingers.
    3. Insert the seal at the top center portion of the tub facing at the center mark of the seal.
    4. Push seal into the groove and work your way around the tub facing all the way to the bottom along each side. You can remove the seal and readjust as necessary.
    Once the seal is in place, close the door and compress. The door will shut tight for a while until the new seal breaks in.
    If you have questions, or if this isn't the seal you are talking about, please post back and elaborate more on what you need assistance with. Please include your full model number so that I may be able to provide you with better assistance. I hope you find this information helpful.
    Sep 06, 2009 | Dishwashers
    Door not closing properly.
    take door off and pack bottom hinge with washers. make sure hingebrackets on cabinet are tight. however, door hanging a bit should not really affect sealing. if seal is gapping, one solution is to warm with a hairdryer and pull outwards gently
    Mar 31, 2007 | Hotpoint RLA80 Refrigerator
    Whirlpool 17.6 Cu. Ft. Top-Mount Refrigerator - White Logo
    302 people viewed this question
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Dan Webster
    Dan Webster
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
