Question about Epson Aculaser C1100 Printer
Epson Aculaser C1100 Just replaced Black Cartridge still printing with wide black line on right hand side of page
  • 1,218 Answers
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Posted on Mar 31, 2011
Epson PX650 not printing the full A4 page of my receipts, cutting off on right hand side
COULD BE THAT THE PAPER IS BIGGER SIZE THEREFORE CUTTING.NEED TO SAY FIT TO PAGE ON YOUR PRINTER DRIVER
Nov 18, 2013 | Epson Aculaser C1100 Printer
Right hand side page print quality very poor, almost unreadable
this is cause of the lens is dirty with toner droping..
open the front cover and on the right side, there is a level for you to pull out.. at the right side of the printer, open the small cover and you will be able to find a cleaner. To clean..pull out the holder few times.. by applying slight pressure..that will clean the bottom lens..and u should be able to print out fine now..
Feb 26, 2010 | Epson Aculaser C1100 Printer
Black solid line on the right hand of page when
Hi, remove the black drum and clean the corona wites and drum GENTLY with a LINT FREE CLOTH. If there uis no change in the print quality you may need to replace the black drum. Hope this helps
Feb 18, 2010 | Epson Aculaser C1100 Printer
Where abouts is toner k
K toner is refering to black toner. Here is a link to Epson for your Aculaser C1100 Reference Guide. Look under Setup & Maintenence for >Replacing Consumable Products..... click on 'Toner Cartridge' for the proceedure.
http://support2.epson.net/manuals/english/page/aculaserc1100/ref_g/index.htm
Nov 27, 2009 | Epson Aculaser C1100 Printer
Epson C1100 K toner low, right hand side can't print
Well if the margins are not the issue, then I would change it.
But before that, try taking a cotton swab, and cleaning the "k toner", the bottom part where the ink comes out. This way before investing more money into your printer, this 'k toner' might just needed a bit of cleaning.
Good luck
Sep 10, 2009 | Epson Aculaser C1100 Printer
No print on the RHS of page using Epson Aculaser C1100
Two things to check,
1- clean the laser by opening the front cover, pull forward the green lever on the R/H side, take off the little panel on the R/H side of the printer and pull out/push in the lens cleaning "stick". Replace panel and push the lever back in, close the front and try a test print.
If that didn't work:
2- Open the lid, lift the orange lever and remove the photoconductor. Be careful with it as it is easily scratched. Inside the printer rotate the toner cartridges and check that the cartridge lock levers are fully locked as even a couple of millimeters can block the laser.
Hope this helps.
Sep 09, 2009 | Epson Aculaser C1100 Printer
Epson c1100 print problem
you can try this:
remove the toner and photoconductor then tip it GENTLY from side-to-side
reseat them and print
Dec 18, 2007 | Epson Aculaser C1100 Printer
Print quality Epson C1100
It sounds as though a cartridge is faulty. To determine which one, the easiest way is to run a page of text/block of colour through in yellow then cyan then magenta. which ever page comes out with the streaks on it will tell you which cartyridge to ditch and replace. Hope this helps Cops Pete@wedotoners.com
Oct 10, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
