Question about Car Audio & Video
I have a 2000 dodge stratus im putting in my own radio i cant figure out where i put the black wire coming out of my car into my jvc radio?
  • 274 Answers
If the wire has a connector on the end it will go into a hole in the back of the radio. If it is just a regular black elec. wire that is the gound and you will need to connect the black wire comeing from the radio to it. I hope this helps!
Posted on Mar 30, 2011
2000 dodge stratus alternator wire caught fire
Possible parasite draw putting too much voltage on alternator
Nov 24, 2013 | 2000 Dodge Stratus
2005 dodge stratus radio wire diagram
2005 Dodge Stratus with Infinity Radio Wire Harness Colors
Car Radio Constant 12V+ Wire: Pink
Car Radio Switched 12V+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Dimmer Wire: Orange/Brown
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: Dark Green/Red
Car Radio Amplifier Location: Amplifier is Mounted Under the Front Passenger Seat
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Dark Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Violet
Right Front Speaker Wire (-): Dark Blue/Red
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Dark Blue/White
Right Rear Speaker Wire (-): Dark Blue/Orange
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 08, 2012 | 2005 Dodge Stratus
How do i install the visors in my dodge stratus 2000 SE 2.0, and where exactly do i connect the power cords to to get the power to get them to work, and how do i connect them to my car video stereo ? if u...
connect the red wire to the red/white wire here is the wiring diagram
2000 Dodge Stratus Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Yellow
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Orange/Brown
Car Stereo Dimmer Wire: Black/Light Blue
Car Stereo Antenna Trigger: Orange/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
pls rate
Aug 17, 2010 | Pyle PLVSR72GR Sun Visor Monitor
I have a 04 dodge stratus and the dome lite and radio and data link connector and power locks and trunk dont all work.the fuse is good i put new one in and still wont work.now what do i do?
I have the same problem with my 04 stratus cant get car inspected cause data link so the cant inspect emmisons, anyway i was told it may be the bcm (body control module) if it is buy a used one from junk yard they are a little expensive. or it could be relay since fuses usually dont do so many things (dome llight, power locks, radio, data link)
Jan 31, 2010 | 2004 Dodge Stratus
My 1996 dodge stratus idles rough, shaking the steering wheel. Also just recently driving my normal comute to college and back which is 40 miles round trip, in turn is now consuming 4 gallons of gasoline....
Seems like we need a tune up . Change the plugs wires, air filter fuel filter. Is the check engine light on. If so have the codes pulled on the car.
Jan 19, 2010 | 1996 Dodge Stratus
Need a wiring diagram for car stereo f65f-19b165-bd A speaker wire diagram is needed for a 1997 Ford Expedition with stereo part number F65F-19B165-BD.  I have purchased a JVC HD Radio and will be...
why not put a belson car radio that uses a sd chip card and a usb connection ,a 1gb sd card is about 30 cds so why mess about with the cd changer ,old technology ,would you put an 8track in it ?? or a mobile vinyl 45 record player
Jan 14, 2009 | 1997 Ford Expedition
Engine won't turn over
Sometimes the connection on the battery is good enough to run small things like that but not put off the power to start an engine. You either need a new battery, check to see if it has corrosion on the terminals or check to see if a terminal is loose. That might not be it.. but it will defintely eliminate somethings.
Aug 11, 2008 | 2000 Dodge Stratus
2001 dodge stratus radio
i have a similar problem with my stratus except mine is a 95'. I haven't fully figured the problem out but i have been told to check all of the grounded wires you have hooked to your car.
Jul 21, 2008 | 2001 Dodge Stratus
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
