Question about Refrigerators
My freezer will only achieve approximately 33 degrees. the fans are running on both sides. have the temp on max. it 11 years old. is it worth fixing?
  • 57 Answers
Brand, model, and serial number needed. Side by side or top mount unit? Any unusual noises? Do you observe any ice build up on back wall of freezer section? I will give you the best advise that I can.
Posted on Mar 30, 2011
    Guru:
  • 683 Answers
Have you tried cleaning the condensor?
When Message EC 40,tech said it was the fan & something else.I asked if compressor needed change & was told no need. Temperature in freezer up and down to 35 degrees.
Hallo
If a compressor gets change so should the driers gets change and also they need to clean the condensing coil.
Regard
May 19, 2016 | Sub-Zero Refrigerators
HOW DO I FIX
I see nothing about checking freon level .
Nov 24, 2015 | Refrigerators
Freezer is cold but food isn't frozen
Deforst freezer and ref. wipe dry. Reset controls to starting point.
Check temp. 0 in fez. 38-40 in ref. keep advancing settings until you reach temp. Also, vaccum behind unit
May 02, 2014 | Amana 22.6 cu. ft. Side-By-Side...
VAUXHALL MERIVA COOLING FAN
Change the relay, situated in a black plastic box up in front of the battery. Costs about 7 pounds / 11 dollars USD on ebay and takes 30 seconds to do. Until you get it fixed, protect the engine when temp get over, say, 90 degrees celcius, by opening up your side dash vents, turn the in-car fan on max and the temp up to max. The hot air will go directly out the windows and you will see the temp gauge drop back to about 80 degrees. I did this for a year until I figured out the relay needed replacing.
Jun 28, 2012 | Cars & Trucks
Freezer is warm at top and cold on the bottom.
Sounds as tho your evap fan is not running. Open door to freezer and should hear a fan running smoothly. If not most of the time the problems is with the main control board on back of refrigerator.
Jan 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Our GE artica, 6 years old has freezer temp at 35 degrees , and refrigerator at 50 degrees. Water is flowing from dispenser, as normal but there is no ice. Ice/frozen things in freezer melted and water...
Check the back wall of the freezer for a ice buildup.
If ice is there you have a defrost parts issue.
That will cause the temps you report.
Also, check the freezer fan motor.
Is it running?
Also check the condenser fan motor at the compressor. Is it running?
Mar 03, 2009 | GE Refrigerators
Kenmore side-by-side with thermo switch problem?
Acting like a bad thermostat, One thing to check is make sure compressor isnt overheating. If really hot you could have a relay problem on compressor.
Jan 05, 2008 | Refrigerators
Kenmore trio 569. Fridge No getting cold Temp is now 81 degrees Freezer ice cold
Mark, check to see if the fan is running in the freezer section. Common problem on these 596's trios. If the fan is running, you might have a defrost problem. If it isn't, your part number for the motor is 67002778. No fan, no cool upstairs...Catriver..post back.
Mar 04, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
