Question about Garden
I don't know how belt goes on deck - Garden
    President:
  • 3,074 Answers
You did not state what type of mower, here is a thread for MTD:
http://www.howtomendit.com/answers.php?id=142623
Posted on Mar 30, 2011
I need to know how to install drive belt on cub cadet that has hydro drive with diagram
That will depend on the model of your mower. Generally you have to remove the deck and deck belts. The drive belt usually goes from the engine pulley to the transaxle pulley. There may be a tensioner pulley as well that keeps the belt tight.
Jul 11, 2016 | Cub Cadet Garden
Dont know wheter to get primary mower belt or secondary mower belt for craftsman gt3000 48 inch deck mower...?
primary belt goes from the engine to the deck the secondary goes on the deck and connects the blades together
Aug 24, 2012 | Craftsman 48" Cut Riding Lawn Mower Deck...
Belt smoking
I just had a problem with my belts smoking also. Replaced belt and the same thing happened. Removed deck, flipped it over and their it was. I large stick had somehow gotten wedged between one of the blades and the deck frame, causing the belt to turn but the mandrel would not. Removed the stick and problem solved. I don't know if your problem will be solved as easily as mine but for me it was just a reminder to ALWAYS check the simple things (and normally the ones that doesn't cost) first and you may be surprised.
Jul 31, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The play, rewind switches won't stay down
I have advised people before that replacing belts is not the only answer and sometimes people that are not experienced can upset some part of the deck without knowing it. We don't yet know the model or brand of the unit and from the description this kind of points to a Piano key or lever key type deck. I could also be a cam system deck. This complaint of buttons not staying down would not apply to a tack switch or solenoid type transport.
Like Jerry says a visit to a good Tech is the answer. I have been doing tape decks for 40 years and have worked at Sony and Teac service shops. If you need my help let me know. I am near Chicago.
Jul 20, 2012 | Audio Players & Recorders
Mountfeild self propelled mower works nearly perfect pull the leever for the mower to move on its own nothing there cheked the slack on cable not the problem now it only works by pushing the mower any...
There is usually a belt that runs from the blade shaft to a small gear box. Front drive mowers have this belt mounted atop the deck, and rear drive mowers under the deck. The problem is usually a broken or worn out belt if all the linkage is working properly. Sometimes however, the gear box goes bad, or the parts in the wheels fail... (depending on the drive style) Check that belt! Good luck, and don't worry. Lawn mowers are pretty simple to figure out!
Oct 01, 2011 | Troy Bilt 5.5hp Self Propelled Mower
DO NOT KNOW HOW TO REPLACE THE BELT TO THE DECK MOWER
Me to ... you want help but you don't give any description of the mower! There must be a way to remove it ... think about this ... someone put it on! so it has to come off! You may have to disconnect part of the deck, I don't know ... You may have to cut the old one off and pry the new one on (on cheaper models) I don't know, you will not tell me what we are working on. It SHOULD be reasonably easy - some company made them by mass production - they wouldn't make it hard for them to assemble (unless it is a really cheap one).
I suggest you get on the ground and study the deck ... look for levers or tension pulleys. Make sure the mower is OFF, OF COURSE. ALSO, disconnect the SPARK plug as turning the belt COULD START THE MOTOR!!!!!!! I don't know what this machine is so I am stressing the safety aspect of what you are about to do!!!!!!!!!
If you will post additional information on this machine, I may be able to offer more suggestions.
Thank you for using FixYa.com
Jun 05, 2011 | Garden
I have an early-2000s Troy Bilt Bronco, 42 inch deck, 18hp Briggs Inotek engine, hydrostatic drive. It broke or threw a drive belt (not for the mower deck, but a transmission belt). How to you go about...
While mowing the yard, the mower went dead. I tried to recrank it and it won't crank. The gas pedal goes straight to the floor and doesn't work to crank the mower. I do not know anything about mowers and don't know where the problem could be. Can someone help?
Jun 14, 2010 | Troy Garden
MTD JE145H cutting deck keeps throwing belts
Usually the reason a mower deck is throwing its belts is there is a bearing that is starting to sieze up in one of the quill assemblies, which is the assembly that the blade is attached to . Either that or one of the belt tensioner pulleys is starting to go bad, easiest way to check this is remove the drive belt, take off the cover over the tension belt and remove that belt know check all moving parts for tightness or excessive looseness. Hope This Helps You Don
Dec 02, 2009 | Garden
I need to change the deck belt, but i don't know what to loosen to accomplish this
loosen the belt tension lever on the left side of the deck .... then remove the right side blade pulley black plastic cover to remove the old belt..... the new belt goes on easily.... 15 min. job
Jun 23, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
