Question about John Deere Garden
When you turn the blades on a high pitch sound comes from the deck. Our LA175 is only two years old.
    President:
  • 3,074 Answers
Either the belt/blade is rubbing on something or one of the pulley bearings are going out. they do have grease zerks you can grease them with a grease gun and it may or may not rid the sound. Hope this helped Tim
Posted on Mar 30, 2011
John deere la175 deck blades spin quit and fast. hook up to pto and engage engine boggs and tries to die
Maybe the travel speed is too high for it or the fusible link in starting circuit is blown.Check and adjust timing belt tension if necessary.Visit john deere expert or dealer.
Jul 21, 2016 | John Deere Garden
As soon as blades are engaged, deck makes a high pitched metallic noise.
the brake lever spring may have broke or you may have a bad bearing. see if you can wiggle the blades up and down. if you can the bearings are bad. or you have hit something and bent the deck or blades
Jun 05, 2016 | Garden
La175 54 inch deck
Here is a belt diagram that I drew for a Deere LA175 (100 Series) 54 inch deck.
Apr 21, 2012 | John Deere 22HP VTwin 48" Riding Mower
Our indestructible deck has made mowing impossible, it clogs all the time and then "coughs" like it's dying. We have to stop mowing and turn off the blades and turn them on again to shoot the...
Hi and welcome to FixYa I am Kelly.
Maybe I am missing the obvious but I have had a couple of people that had this problem with since new use of a mower. One of them had the wrong blades with the deck and the 2nd one the baldes were installed with the air foil side DOWN. If you have Air-flow problems under your deck the above is possible or your blade deck drive belt is routed incorrectly. The decal for the blade deck belt routing should still be on your deck. Look at the decal drawing vs the actual routing of the deck belt. It is highly possible that one or more of your blades is driving backward.
If you can not find your decal (would be hard not to find it on a deck not 1 year old!), I will try and look it up but I need the model number of mower and the DECK (2 ea model numbers 1 for mower 1 for deck)
Thanks for choosing FixYa,
Kelly
Apr 22, 2011 | Garden
High pitch/humming noise from Frigidaire Refrig.
You have to isolate this problem. It could be one of three things. The compressor, the condenser fan motor or the water valve that feeds the ice maker and wtaer dispenser. Also if the high pitch sound is compared to that of a bird then it is definitely the condenser motor. To isolate the problem take the back cover off. LISTEN FOR THE HIGH PITCHED/HUMMING NOISE! Use a flash light and see if you can tell where it is coming from while it is doing the noise. Dont try this unless you know what your doing. Stop the condenser fan blade with the end of a hard object, but stop it gradually. Dont try this cause you might brake/bend the blade. But if you did and the noise stop then you figured out your problem. If not ythen disconnect the water valve. It has to doulble harness wires attached to it. if problem still exisit then it has to come from the compressor. Unless you have a warranty then theres nothing no one can do except change it. $300-400 job easily.
Mar 27, 2010 | Frigidaire FRS26RLECS Side by Side...
Blades lose power when deck lowered
SOUNDS LIKE YOU NEED A NEW BELT
Oct 01, 2009 | Garden
My john deere lt 133 mower with a double blade mulching deck, 1 blade stopped working and only 1 blade cuts now, how do i fix this. Thanks Patrick
This model mulching deck uses a flat/ribbed serpentine belt that is set at very high tension.When belt breaks under the cover only one blade will turn due to IT being driven from PTO clutch as the other blade being turned from serpentine belt.This deck was Deere's first and last shot at making a true mulching deck and only made it a couple years.When you buy the VERY expensive belt it will come with detailed instructions on how to install it.Goog luck.
Aug 07, 2009 | Garden
Buzzing sound when the vent fan is turned on. Sound is high pitched, and I can't tell if it's coming from the top or bottom. Any suggestions?
I don't know if this applies in your case but I have had fans with metal blades that would resonate with a high pitched ringing sound. It may also be that a blade is slightly contacting a metalic mesh filter cartridge.
Jun 25, 2009 | GE JVM1860 Microwave Oven
High Pitch Sound From Samsung TXN3071WHF 30" TV
I think its the flyback and its starting to leak. this is a component responsible for the high voltage of your tv set. always observe safety in dealing with this. Have it check by a qualified technician. Good luck!
Feb 25, 2007 | Samsung TXN3071WHF 30" TV
Garden Logo
150 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
