Question about Panasonic KX-TDA50 Phone
I have 3 CO lines coming in. I want the 3rd to be available, but not to ring (it is the fax line). How can i have the first two ring, but not the 3rd?
  • Panasonic Master
  • 2,460 Answers
TDA ringing is controlled by ICD groups. If the fax is part of the system (an extension) then you need to set up an ICD group (like #2) that puts the fax extension in it and rings only the fax. If your fax is external to the phone system but you still want to use the fax line, then you take the incoming CO out of any ring group at all (leave the column blank). All of this requires installer access or a really good read on the PTPM manual.
Carl
Posted on Mar 30, 2011
Hooking up fax to KX TG7871 Panasonic Phone
There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
Need model number of your fax - google that!
Service manual for your phone.
http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00059780#Dist_ring
Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
  1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
  2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
Mar 06, 2014 | Lands Phones
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
I cannot receive incoming fax, what setting do I have to use
Please go through the following checklist:
  • Make sure to plug the telephone fax line from the phone jack in the wall to the Line port on the back of your printer. For more info, please refer to the Lexmark X4200 User's Guide.
  • Make sure the fax machine is connected to right phone jack in the wall and is assigned with the correct fax number.
  • If you have an answering machine connected to the same fax line, be sure to configure it so that it answers first before the fax machine (e.g. if your answering machine picks up on the 3rd ring, set your fax to pick up on the 6th ring or more)
  • If the line has a voicemail feature, disable it or request for a distinctive ring from your phone company.
Sep 13, 2011 | Lexmark X4270 All-In-One InkJet Printer
Hi would like to know how to set an extension not to ring when any of the co lines is ringing since i have a fax machine connected to this extension and it is programmed to answer automatically
Ringing for each extension and line is done in Panasonic system programming commands 408-410 for Day/Night/Lunch. You turn off ringing for all lines to your fax extension and then just turn on one line for that phone.
Be sure to turn off or delay the fax line ringing to all the other extensions at the same time.
Carl
Nov 03, 2010 | Panasonic KX-TA308 Phone
Can't send or receive faxes
it's most likely the compression on the phone line or you need to set up your fax machine for proper receive mode.
Contact your phone service provider to see if they support faxes.
(Faxes cannot handle nearly as much compression as standard voice)
Jun 09, 2010 | Canon PIXMA MX300 All-in-One Printer
How do I use use a distinctive ring to separate the incoming fax from the incoming normal calls I want to direct to the answering machine. I am from S. Africa. I am using an all in one Samsung SCX-4521F. I...
Firstly, you will need to get a 2nd ringtone from your phone provider. Most of them will provide a designated "fax ring" (not a new number) for little or no cost.
In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. “Distinctive Ring” is a telephone company service which enables a user to use a single telephone line to answer several different services.
Using the Distinctive Ring Pattern Detection feature, your fax machine can “learn” the ring pattern you designate to be answered by the fax machine. Unless you change it, this ringing pattern will continue to be recognized and answered as a fax call, and all other ringing patterns will be forwarded to the
extension telephone or answering machine plugged into the EXT. jack. You can easily suspend or change Distinctive Ring
Pattern Detection at any time.
Before using the Distinctive Ring Pattern Detection option, Distinctive Ring service must be installed on your telephone line by the telephone company. To set up Distinctive Ring Pattern Detection, you will need access to another telephone or someone available to dial your fax number from outside (a cell phone will do!).
To set up the DRPD mode:
1 Press Menu until “Fax Setup” appears on the top line of the display.
2 Press the scroll button ( or ) until you see “Receive Mode” on the bottom line and press Enter.
3 Press the scroll button ( or ) until you see “DRPD Mode” on the bottom line and press Enter.
4 When “Set” displays on the bottom line, press Enter.
“Waiting Ring” appears on the display.
5 Call your fax number from another telephone. It is not necessary to place the call from a fax machine.
6 When your machine begins to ring, do not answer the call.
The machine requires several rings to learn the pattern.
When the machine completes learning, the LCD displays “End DRPD Setup”.
If the DRPD setup fails, “DRPD Ring Error” appears. Press Enter when “DRPD Mode” displays and retry from step 3.
7 To return to Standby mode, press Stop/Clear.
When the DRPD feature is set up, the DRPD option is available in the Receive Mode menu.
To receive faxes in the DRPD mode,
you need to set the menu to DRPD;
NOTES:
• DRPD must be set up again if you re-assign your fax number, or connect the machine to another telephone line.
• After DRPD has been set up, call your fax number again to verify that the machine answers with a fax tone. Then have
a call placed to a different number assigned to that same line to be sure the call is forwarded to the extension telephone or answering machine plugged into the EXT. jack.
• In Tel mode, you can receive a fax by picking up the handset of the extension phone and then pressing the remote receive code Alternatively, you can press On Hook
Dial
(you can hear a fax tone from the remote machine) and then press Start on the control panel of your machine.
• In the Fax mode, the machine answers an
incoming call and immediately goes into fax
reception mode.
• In Ans/Fax mode, the answering machine answers an incoming call, and the caller can leave a message on the answering machine. If the fax machine senses a fax tone on the line, the call automatically switches to Fax mode.
• In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. This option is available only when you set up the DRPD Mode.
The full user manual for your machine is located here
Hope that is of help to you :)
Nov 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Our IntelliFax 4750e will not receive faxes. The line has a dial tone, and rings when called. It is set to "fax" and not "fax/tele." Suggestions?
There are a few possibilities. 1) The phone cord coming from the wall is plugged into the phone port on the fax instead of the Line port. It should be on the line port.
2) The fax have been set for distinctive ring. This causes the fax to ignore the normal incoming ring tone and is instead waiting for the distinctive ring from the phone co.
3) The modem in the fax has gone bad. If you have had any power failures or electrical storms/problems this is a possible cause.
Some models will also not answer if the machine is out of toner or paper.
Oct 21, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
When I get a phone call the fax kicks in. How can I adjust the setting to turn on only if a fax sound comes in?
You can add more rings to answer, but the only real way is to get distinctive ring from your phone co. or a separate line for fax. When you change the setting to manual receive, you have to answer yourself and if you hear fax tones you hang up and press fax start, or receive.
Oct 12, 2009 | HP LaserJet 2840 Printer
Is my fax shutting off?
Make sure your your phone line is ANALOG not DIGITAL
Jan 09, 2009 | HP LaserJet 3055 All-In-One Printer
My fax comes on when my phone rings
You need to purchase a cross-over cable to use on your fax machine. This cable will change line 2 to line 1 for the fax so it will pick up the line when line 2 rings and not line 1.
If you want to use a regular cable you'll have to have someone rewire the jack in the wall to swap line 1 and line 2, then just plug the fax machine into this jack.
Dec 23, 2008 | Brother IntelliFax-2820 Laser Fax
Panasonic KX-TDA50 Phone Logo
146 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
