Question about Carrier Heating & Cooling
4 ton carrier horz ac fan coil. seems to wick water off the a coil surface and in time floods the bottom of the fan coil case. Pan good, fan speed ok drains good. the cooler the home the more condensate seems to show uo.
  • 1,420 Answers
Over time the AC coil collects oils from the area it cools. Get some good coil cleaner and soak the coil down. Rinse off with a small but continuous flow of water that your condensate drain will drain away. Apply a second time if necessary. Rinse very good because the cleaner will eat away at coil if you don't get it all off.
Posted on Mar 30, 2011
My carrier condenser fan has stopped running.can i just pour water over the coil and use the condenser untile the repairman gets here on friday
Messy - why not just hook up a regular fan and hook it up to the power line that ordinarily powers the condenser fan.and have it do the blowing until the repair person comes out on Friday. The ideal fan is one of those old floor fans that used to blow air in a 360 direction.
Jul 02, 2015 | Carrier 3 Ton Infinity Puron A/c outside...
My Carrier Infinity system Model FE4A is leaking water from the bottom of the unit on to the basement floor. How do I stop the leak?
have your HVAC technician check the pressures in your unit...sounds like you may have low pressure. You should NOT be having any ice build up to melt off.
Sep 13, 2014 | Carrier Infinity Series Variable Speed...
WHY does it not cool for more than 10 minutes, than shutsoff
low refrigerant charge look at the sight glass if you see bubbles your low on freon. check your condencer coil outside clean the coil with condencer coil cleaner spray on wait 10 minutes hose off. most times a dirty condencer coil is the culprit
Jul 28, 2014 | Carrier 519exx042000aaaa 3-1/2 Ton Ac/hp...
How to connect a fan motor for a 7 ton carrier ac unit
7 ton, sounds like a commercial unit, if this so could be three faze. is this fan for cooling the outside condensor coils or the blower motor for moving air through the inside duct work
Feb 02, 2011 | Heating & Cooling
I have 2 Gibson AC's that are thru mounted that have worked well over the years with some water issues. WE have cleaned them without removing them from the windows with good success each year. Now, both of...
DONT DRILL A HOLE! It is to easy to drill through a refrigerant line and that's big problems. Water in the bottom of the unit is normal and there is usually a water slinger on the outside fan that blows the water on the condenser coil. Its good that you have checked the slope on the unit. It seems odd that both units started doing this at the same time. The water flows whereever it can from the front of the unit to the back. Probably the units are quite dirty and need cleaned. The dirt in the corners of the pans where the coils set can stop the flow of water through the pan.
Jul 05, 2010 | Gibson Thru-Wall/Window Air Conditioner
Intertherm Air Handler Coil leaking water
replace it it's junk - going to do that this time because this is the fourth year of the same problem on the hottest days this intertherm junk downflow ac unit condensates where it will not and con not be captured by the pan - built by relatives of the guy who designed the titanic -
Apr 07, 2010 | Intertherm P3RA-024K Air Conditioner
Water fills up the drip pan under the frig in about 3 hours. Why is this pan filling up?
The water accumulation is the result of the defrosting process that occurs in every frost-free refrigerator and is directly proportional to the humidity and the amount of time the door spends open. Aother factor is the door seals. If the doors do not seal correctly, outside air will infiltrate the compartments and also add to the accumulation. The door seal problems sometimes are just simply due to the fridge not sitting on a level surface thereby skewing the box out of square. If the seals are bad, they can be replaced. If the box is not sitting square, there are leveling adjusters on the bottom. The time that the door spends open is up to you.
One more thing, there is a condenser fan under the box that moves air under the box to cool the condenser coils. The air movement also speeds the evaporation of the water in the pan. If the fan is not running, it can contribute to this problem, but will also cause problems with the refirgerator keeping it's cool. It might be a good idea to check the fan.
Hope this answers your question
Jul 06, 2009 | Whirlpool Refrigerators
Water leak
HI,
Please CLICK HERE for some very useful info.
This is a very common problem that is easily solved. The way your air conditioner dries your house is by removing moisture. That moisture must go some where. The moisture is removed by condensing it on the cold refrigeration coils and letting it run down a drain pan.
The problem is that dirt and crud will stop up the drain line and clog the pan. This will eventually happen to every system out there give it enough time.
While this problem makes a terrible mess and seems like to end of your system it is really quite easy to fix. Most system simply use a 3/4 inch PVC pipe to drain the water to a floor drain or sink. when (not if) this drain clogs the drain pan over flows (especially when the fan stops) and you have a mess.
Fixing this problem is rather easy. Simply take a wet dry vacuum and **** the drain line clean, 9 times out of 10 this will fix it and that is the last of this problem you will have for a few years. If the drain pan is really dirty then you will have to take the covers off the unit and vacuum it out. In extreme cases you may have to use compressed air, nitrogen or CO2 to blow out the drain line (expect a big mess at the other end).If you don't have either avaliable you can use the Garden hose to flush the line backwards (expect an even bigger mess on the other end)
In rare cases you may actually have a hole in the coil drain pan in which case the coil or the pan will have to be replaced especially if it is steel (but this is rare). In other rare cases we have had situations where grease or oil fumes from the furnace have condensed on the coil and caused the water to fall off the coil. When this happens you must clean the coil with soap or some solvent.
If the coil is totally stopped up the back pressure from the fan/blower can force the water out of the pan by undermining the bottom of the coil. When the coil is this dirty the coil usually needs to be replaced. You will also notice little or no air flow.
In most cases these condensate leaks are a do it yourself repair. Only if you must take the unit apart and can't, do you really need to call for help.Here is a device that will allow you to clean the drain with ease and
not have to take it apart each time.
Goodluck,
Please don't forget to rate or accept the solution
Jun 07, 2008 | Heating & Cooling
Heating & Cooling Logo
42 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
