Question about HTC Aria Cell Phone
My htc phone dosent want to come on anymore. i put it on the charger all night and it still dont come on
    Scholar:
  • 118 Answers
Assuming your phone is simply out of power follow these possible solutions:
1. check to make sure that there is power running through the wall socket.
2. make sure your battery is properly placed inside the phone.
3. make sure the cable is connected securely and that the cable is undamaged.
(take special note of the actual plug that goes into the phone, sometimes it can get bent or damaged)
4. try a different cable if possible and attempt to put the battery into the phone while its charging, this sometimes gives a jolt which is strong enough to initiate the charge up process.
if your phone is damaged in some way then you might try following these:
1. remove all parts of phone that can be easily opened, and clean with a dry cloth and if possible with condensed air. take care when removing sim and battery to not damage anything.
2. make sure nothing is stuck inside any of the sockets or buttons.
3. a rare problem is sometimes if the phone is damaged, the battery does not get locked in place properly, try to keep the battery container open while charging and moving the battery around slightly or pressing on it with your hand. please do this carefully.
Posted on Mar 30, 2011
    Scholar:
  • 113 Answers
Your battery may be drained or is not seated correctly. Remove the battery and inspect the contacts. Remove any debris/residue found on the device or battery contacts with a soft, dry cloth. Attempt to charge the device. If the battery is dead, the device will need to charge for a few minutes and then should power on once this happens. Attempt to power the device on by pressing the Power Button for 3 seconds. Try another battery. If the device still will not power on, contact your wireless carrier for further assistance.
My htc wont change and just fashes a red light
your power supply is overloaded, check the power supply of your phone
Jun 08, 2012 | HTC One X Android Smartphone Glamour Gray
Htc aria wont fully charge
I had the same problem with my droid 2 before i got rid of it for my iphone. I took it back to the store and they said," the battery is done with its life." lol. i got a new battery and it fully charged after that until i sold it. Also my friend had the same problem but his was his charger.
Hope this helps
May 30, 2012 | HTC Aria Cell Phone
My phone wont charge anymore what can I do
Sometimes with these new chargers after a while it gets worn and you dont get a good conection so you have to break down and buy a new charger
Mar 22, 2012 | HTC Cell Phones
Yesterday my htc desire was discharged so i pluged it at computer when, but in same time i was using it. In one moment it switched off.. i took battery out and put it in back and switched on but it only...
It would be best to bring your phone to diagnose the problem. It could be a number of things, from software to hardware, so your best bet is to bring the unit to a service technician
Apr 02, 2011 | HTC Desire Cell Phone
My htc touch pro wont turn on after being charged all night
Had the same problem. You need new battery! (borrow from friend, if anyone has HTC to test if phone is OK with different battery).
Sep 25, 2009 | HTC Touch Pro Smartphone
I have a motorola v3 it shows it is charging but dosent charge ..
Get the appropriate charger for that phone you may not being charging it at all
Hope it help
Jun 25, 2009 | Motorola Mobility RAZR V3m Cellular Phone
I can't turn on my cell phone htc 3125 now after i left it in the car conected to it's charger over night .any one can help?
remove your battery and try to clean its contacts,as well as the power connector from the main board.
May 12, 2009 | HTC 3125 Cellular Phone
HTC TOUCH HD charging problem
Well hope so you didn't damaged the sensors! try this : use the phone until battery is empty and switches off. then put it on the charger for 4 hours. If no joy,try different battery to make sure that device is not damaged and get a new battery.
May 12, 2009 | HTC Touch HD Smartphone
HTC Aria Cell Phone Logo
97 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
