Question about Moen & Replacement Cartridge
After I installed the moen cartridge on the cold side, The water comes out only when the handle is turned about 90 degrees. The new hot water cartridge is OK.
  • 66 Answers
Pull the cartridge back out and spin it 180* and reinstall.
Posted on Mar 30, 2011
Why does moentrol bath valve give hot water pointed to "C" and vice versa?
Easy one.
Feel the pipes. The pipe on the right should be cold. If the pipes are correct, turn the cartridge 180 degrees.
Jan 20, 2013 | Moen & One Handle Tub & Shower Faucet
Moen water flow restricted and only warm
Not sure about your particular valve, but most newer shower valves have an anti-scald limiter that stops the handle from turning too far to the hot water side. Check for a ring or a pin under the handle that can be set in different positions. It will need to be moved clockwise to allow the handle to rotate farther to hot.
Hope that helps. If you have trouble finding it, try looking up a diagram for the valve model.
Jul 03, 2017 | Moen & Replacement Cartridge
Replaced my Moen cartridge, finally got the leaking to stop, but now have no hot water no matter which direction the single handle is positioned
Turn on hot water supply
ok to easy but maybe
take valve cartridge out of valve It may be put in 180 degrees out
compare cold side inlet to warm side inlet: spring, little black gaskit/s seal maybe a ball/s
The cold side works right
Nov 28, 2010 | Moen & Replacement Cartridge
No hot water in shower but have hot water in sink
Is your shower valve a single handle. If so I would reccomend you change cartridge. To do this shut off water to valve or house. Remove center cover on valve handle,most of these are just friction fit so gently pry off with knife point or small screwdriver. Remove handle by pulling straight out,then remove chrome cover that fits around outside of valve. Ther is a small copper retaing clip that holds valve in place. It should have a small hole in tab that is on top of valve. Grasp this with pliers and pull up to remove. Then remove cartridge by pulling on cartridge stem. If it's doesn't come out you can get a moen cartridge puller at hardware store. Remove old cartridge,install new one and reinstall retaing clip. Reinstall chrome cover and handle.Turn water back on and try shower valve to see that cold is on the right side. If it's not remove handle and turn center stem 180 degrees.This will change cold side to right. Put handle back on with cover and you sould be done. Hope this helps. Thanks
Nov 19, 2010 | Moen Home
The water doesn't seem to get hot . New cartridge installed . If turn right (Hot direction ) the knob will turn until water gets cold again ???
The cartridge sounds like it was put in 180 degrees out.
Pull it back out, and rotate 180 degrees and re-install & try that.
Jan 18, 2010 | Moen 1 Handle Lever Shower Faucet With...
Waters hot instead of cold when you turn it on
You have to remove cartridge and rotate 180 degrees then re-install. Was it removed or replace lately?
Jan 06, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Apr 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen & Replacement Cartridge  Logo
77 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
